Question about Lexmark P3150 All-In-One InkJet Printer
Lexmark p3150 i have had thi printer about a year and my black ink ran out i have inserted a new black 1 and it keep asking me to remove tape and have but still requesting that i remove it please help thanks ada
This problem is as a result of the contact not detecting it. this may have resulted from long period of in operation. Hope Lexmark technical service gurus maybe able to resolve this issue since these printers are really cutting edge for what it does(All-In-One).
Posted on Oct 07, 2007
Cartridge may have a short in it
Posted on Jun 03, 2007
    Problem Solver:
  • 9 Answers
Problem with printer motherboard. Proceed with service center.
Posted on Feb 24, 2007
I have a Lexmark Z2390 inkjet printer and have just purchased new ink cartridges but do not know how to change them can you help ?
hello,here is how to replace or change ink cartridges: 1. make sure the printer is turned on. 2.lift the top cover or access door. sayurisan20_19.jpg
3.press down on the cartridge level to raise cartridge lid. sayurisan20_20.jpg
5.for new inks,remove the tape from the back and bottom of cartridge before you install it.DO NOT REMOVE NOR TOUCH THE COPPER CONTACTS OR NOZZLES ON THE CARTRIDGE. sayurisan20_23.jpg
6.insert black cartridge in the left slot and the color in the right. 7.close the lid and make sure it is closed properly. sayurisan20_24.jpg sayurisan20_25.jpg
you can align them to improve print quality by clicking on start,all programs or programs and then click on the lexmark folder,click maintenance,align cartridges,then print.
Jun 09, 2011 | Lexmark Office Equipment & Supplies
How do i change my lexmark x4650 print cartrige?
Installing/Replacing your ink cartridges:
1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
May 15, 2011 | Lexmark X4650 InkJet Printer
I need to know where the ink cartridge goes on my x6575 what cartridge goes where
1.Turn on the printer.
2. Open the printer by grasping the printer's top lid, to the left of the control panel and just below the scanner cover ,( approx. 1 inch ) to expose the ink cartridges.
3.Press down on the cartridge carrier levers.
4.Remove the tape from the black print cartridge, insert it in the left cartridge carrier and close the lid.
5. Remove the tape from the color print cartridge, insert it in the right cartridge carrier and close the lid.
6. Close the printer.
Your ink cartridges are installed.
Feb 17, 2011 | Lexmark X6575 All-In-One InkJet Printer
My Lexmark P3150 printer says the black ink cartridge is full but when I print, the paper comes out blank. any help?
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 27, 2010 | Lexmark P3150 All-In-One InkJet Printer
Don't know how to install ink
Installing print cartridges
1 Open the printer, and then press down on the cartridge carrier levers.
2 Remove the used print cartridge or cartridges.
3 If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid.
Warning—Potential Damage: Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridge.
4 If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid.
5 Close the printer, making sure to keep your hands out from underneath the scanner unit.
Removing a used print cartridge
1 Make sure the printer is on.
2 Lift the scanner unit.
The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid.
4 Remove the used print cartridge.
Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
Apr 13, 2009 | Lexmark X4650 InkJet Printer
Cartridge number for lexmark P 3150
#90 --> OEM Photo colour Ink cartridge (Lexmark 12A1990)
#20 --> OEM Colour Ink cartridge (Lexmark 15M0120)
#50--> OEM Black Ink cartridge (Lexmark 17G0050)
**OEM stands for: "Original Equipment Manufacturer
Hope this helps and please don't forget to give my answer a rating!
Thanks,
OpenSource13
Apr 06, 2009 | Lexmark P3150 All-In-One InkJet Printer
Lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
Jan 01, 2009 | Lexmark All-in-One Printer with PictBridge
Changed color cartridge and getting error
I had the same problem with my X8300 printer. As the printer was less than a year old Lexmark sent me a new printer. I will keep this printer until it to goes wrong and then buy another brand. Lexmark - cheap and nasty, I am afraid.
Ivanhoe.
Nov 13, 2008 | Lexmark X5495 Printer
Refilling lexmark cartridges x2500
There are a couple ways to trick it into accepting the cartridge. You can put a different one in, take it out and then put the filled one in. Or you can find a refill kit with instructions on what contacts to cover with tape and you have to do it 2 or 3 times to get the printer to reset. Sometimes you can shut off the computer and printer for 20 min and start it up again. Or you can get the sledge hammer and smash the stupid printer before it sucks up your life savings and vow never to buy from a company that profits from causing problems that they tell you can only be solved by using more of their overpriced solutions.
Aug 10, 2008 | Lexmark X2550 All-In-One Printer
Lexmark P3150 All-In-One InkJet Printer Logo
32 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
