Question about Frigidaire FEB30S5D Electric Single Oven
When oven is set on bake it will not reach temperature-
Frigidaire Gallery Series electric wall oven model # GLEB30S8ABA. The oven will not get hot enough on bake. Broiler works properly but bake stting will not reach temperature. Broil coil does come on when bake is on but does not stay on or get red. Can only get oven to 200 when on bake.
  • tmarevans Dec 09, 2008
    We have checked the thermostat and it is okay. We are beginning to think it might be the control board. Has anyone had a control board problem?
  • tmarevans Dec 10, 2008
    We have had the thermostat checked- It is not the problem.
  • Frigidaire Master
  • 3,463 Answers
On most electric ovens there is an external thermostat that cuts the supply to the element if for some reason the oven overheats
I have known situations where the thermostat cuts out prematurely thereby cutting off the supply to the heating element. Lack of ventilation can also cause problems, check that all vents and grills are clear.
Also most ovens are fitted with a fan motor that draws air in to help keep it cool, these have been known to fail.
Check to see if it is working o/k.
Initally I would have suspected thermostat being faulty, but from what you say then it would appeart that this is not the case.
I would also be inclined to check the temp with a good thermometer against the temp set on your thermostat.they can drift out of range.
Hope that this helps with your prob.
Plz leave feedback.
Thanks.
Posted on Dec 10, 2008
  • Barry Coates
    Barry Coates Dec 10, 2008
    Have you checked that the supply voltage is correct? and if there are any internal fuses, are all these o/k?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
As you described, there are two heating elements in the oven, bake and broil. Components that would require checking with a continuity tester:
  • thermal circuit breaker, must read 0 ohms;
  • both the broil and bake heating elements, must read very low;
  • in some versions (Canadian) there is relay between the thermal circuit breaker and the heating coils;
  • the relays, relay terminals/pins mounted on the electronic control PCB;
  • if everything checks out, then the electronic control board would require a close checking.
This wiring diagram would be of help.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
    Sergeant:
  • 306 Answers
Here the upper element is for broil. It may come on briefly during bake, but usually at half power. It doesn't glow red.Does the bottom element glow red? If not, inspect lower element, which is the bake element, for pits and rough spots. These may be signs of failure. unplug it!! Remove bake element and check for continuity. If it shows open, replace. You can probably take to parts store and they can test it for you.
  • AbdulRahiman S Dec 10, 2008
    else Check burner. and Remove foil.
  • 10,515 Answers
  1. Make sure the controls are set properly: that the oven selector switch is set correctly and that the temperature switch is set to the desired temperature. Where applicable, make sure the oven timer is set to manual.
  2. If nothing else on the Range, Oven or Cooktop is working then:
  3. Check the circuit breaker or fuse.
  4. Test for power.
  5. Test the oven elements.
  6. Test the oven thermostat.
  7. Test the oven selector switch
Click the link in order for explanatory procedure....
Posted on Dec 09, 2008
  • 519 Answers
Sounds like a problem with the thermostat switch. Have the thermostat switch checked by a qualified artisan.
    Sergeant:
    Champion:
  • 201 Answers
  1. Check on your door is the rubber still ok that keeps the heat inside the oven?
  2. Your thermostat can also be faulty
Hope this is helpfull to you
Posted on Dec 08, 2008
  • Jonathan Van Rensburg
    Jonathan Van Rensburg Dec 29, 2008
    Did you check if the Seal at the door is ok?
    Novelist:
  • 167 Answers
It sounds like the thermastat sensor needs to be replaced; this triggers the oven to shutoff once it reaches the set temperature.
    Sergeant:
    Champion:
  • 291 Answers
When you turn oven on the broil will come on with the bake to pre heat but it dont stay on and if the bake isnt coming on and only warms up then you have a bad bake element / larry
  • 365 Answers
The problem is that the the heating coil is not heated up to the desired level.try to change the coil after checking that or check what had made this to damage.thank you
  • JITHIN ANTONY Dec 14, 2008
    does the problem solved
  • 734 Answers
There is a problem in thermo sensor of your oven.
Need to be replaced.
Thanks
  • futureloginn
    futureloginn Dec 10, 2008
    There is a problem in thermo sensor of your oven.Need to be replaced.
    Genius:
  • 1,550 Answers
It is due to faulty thermostat .
You need to replace it .
    Genius:
  • 1,199 Answers
The thermastat needs replaced! this should fix it!
How do i test a control panel of a frigidaire wall oven
Good Morning Friend,
I understand that you want to know how to test the control panel on your Frigidaire wall oven, model# FEB386WECH, due to the bake element not working. I also see that you have changed the bake element and only the broil works. Typically, this is not a do it yourself job, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why the bake element is not working. Hope this is helpful.
-Best Regards-
WP
Jul 07, 2014 | Frigidaire 30 in. Electric Gallery Series...
My 30" wall oven oven won't heat up. the clock works and it allows me to put in bake, 350 degrees, but the elements don't heat up. we had a storm and the power flickered on and off several times. is there...
There is a safety thermostat (thermal fuse) on the back wall of the oven that interrupts power from L1 to the Bake and Broil elements. This fails open on an over-temperature or over-current condition. The oven needs to come out of the wall to replace it - best left to a tech unless you are experienced in such things.
Best Regards,
Bruce
www.fixyourboard.com
Jun 21, 2010 | Frigidaire 30 in. Electric Gallery Series...
The oven wont heat up.
Hi.
Since the oven has two heating elements, if the oven does not heat up on any condition, and both broiling and baking element are not working, then the most common fault causing the problem is a faulty temperature probe.
The temperature probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electronic oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reaching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Mar 03, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
Frigidaire FEB30S5D Electric Single Oven Logo
313 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
