Bought new aoc monitor and plugged in and all I get a floating screen safer saying "input not support".
  • Dan
    Dan May 11, 2010
    Have you tried new drivers?
    Link
    President:
  • 2,992 Answers
Your display resolution is set to something outside the range your AOC supports.
Start Windows in VGA mode (pick that option from the startup menu you get when you press F8 after the manufacturer's logo comes when you turn the computer on). Then set the display mode to 16-bit color and 800X600 resolution. This will allow Windows to start up next time with settings just about every monitor can handle.
Once WIndows is up and running, make sure you change your display settings to something the monitor can handle. Specs are in the manual or on the manufacturer's website, but resolution of 1024X768 should be another safe choice. You should also think about installing any driver software supplied with the monitor.
Posted on Dec 08, 2008
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
AOC 1" - Monitor Says "no signal"
Sounds like a connection problem. Make sure BOTH plugs are securely located. Ian.
Sep 20, 2009 | AOC LM729 17" LCD Monitor
Osd lock in my LCD
Check your switchers resolution settings .....
You might have to change your resolution settings....
This solution is for AOC Monitors......
Setting the Optimal Resolution
The recommended resolution for this monitor is 1680 by 1050. To setup the monitor to this resolution, follow the steps below.
  1. Click START.
  2. Click SETTINGS.
  3. Click CONTROL PANEL.
  4. Double click DISPLAY.
  5. Click SETTINGS.
  6. Set the resolution SLIDE-BAR to 1680 by 1050.
External Controls
Press the power button to turn the monitor on or off. The other control knobs are located at front panel of the monitor (See Figure ). By changing these settings, the picture can be adjusted to your personal preferences.
* The power cord should be connected.
* Press the power button to turn on the monitor. The power indicator will light up.
203-35.jpg Hope this helps ,
Rate me please,
Cheers Misterdj
Aug 12, 2009 | X-10 LM929 19IN LCD 12X10-.294MM SPK BLK
Bought Samsung 2233BW Monitor, hooked the two plugs, power and DV1 cord started computer and switched on monitor, NOTHING HAPPENED. Silly thing just unhooked Samsung and hooked back up the AOC monitor no...
You might need to go into the monitor's setup menu and select the digital input. (That's DVI, by the way, for Digital Video Input, and not DV1.) Some monitors automatically detect the input but not all of them. Obviously, this doesn't apply if the Samsung has only a DVI input. It might also be necessary to tell the video card to turn on the DVI output. You can do this with your old AOC connected and use the video setting utility supplied with the video card.
May 22, 2009 | Computers & Internet
INPUT NOT SUPPORTED
Start your Windows in Safe Mode (pressing F8) during boot process and adjust your Display Settings to a lower resolution.... say 1024 x 768. Once fixed, you can play around again increasing the resolution a notch at a time. Fix ya!
Aug 28, 2008 | AOC A15X221 15 in. LCD Television
How do you remove the on screen display?
Sorry, seems like the cctv hardware does not like the type of monitor your using. How you tried a different display and does that correct the problem?
Jun 24, 2007 | X-10 LM929 19IN LCD 12X10-.294MM SPK BLK
Computers & Internet Logo
147 people viewed this question
David Payne
David Payne
