Question about GE (PSS26MSRSS) Side by Side Refrigerator
Wheels for GE fridge won't budge
I need to move my fridge and I can not get the wheels to budge. When they were installing the fridge it rolled very easily. How can I get it roll on the wheels underneath?
3 Suggested Answers
HVACRH20
  • 237 Answers
SOURCE: How to move the fridge
The wheels are probably OK, the tech likely lowered the leveling feet in the front to keep it from rolling by accident. Turn the little level legs (the screw up into the fridge) until the weight is back on the roller wheels, then you should be able to move it. A pair of "channel lock" pliers on the rubber feet work the best depending on how much weight is on them.
Posted on Dec 30, 2006
tech master
  • 120 Answers
SOURCE: GE fridge, wheel locks
if is a ge there are no locks on wheels just try to be care full it should move easier when emptied and buy a scratch plastic the you can use when moving unit that is what we use every time and i am a sears tech
Posted on Oct 12, 2008
Front wheels on ge refrig squeak when opening the door(s).
What is the model number of your GE refrigerator?
Jul 21, 2011 | Refrigerators
My 1992 wrangler won't roll at all. It starts fine, and stays running but when I try to put it in gear it stalls out. Even in neutral, I can't seem to push it to get it rolling. Any suggestions?
This sounds bad, even in neutral it stalls, you cant even push it. i would start by putting the transfer case selector in neutral and see if it rolls, if this jeep is only two wheel drive then start by jack the front wheels up and do this for the four wheel drive also, this is to see if its in the trany or the wheel, check and see if you can spin the wheels in the front, if this is two wd then if the wheels dont spin then you have a problem with the brakes but what concerns me is that it stalls in neutral, i would have to say the problem is in the trany and if this is a stick shift trany i would say the clutch broke and will not release but when its in neutral it should roll. anyway do the same in the rear wheels, jack them up and see if the wheels move, if they dont then remove the driveshaft at the rearend and then see if the wheels move. if the wheels turn with shaft off then theres a problem with the trany oor transfer case if its 4wd, if its 2wheel drive then its something in the trany, if the wheels dont spin with shaft off then start truck and see if it still stalls but dont let it go into gear with driveshaft off you will not be able to stop driveshaft when disconnected, just see if it stalls in neutral. good luck.
Mar 13, 2011 | 1992 Jeep Wrangler
When i put the key in the ignition i try to start the car but it wont budge its like locked up in one spot which is all the way to the back. So when i try to move it around while moving the steering wheel...
take a flashlight and look into the lock and see if the tumblers are loose ir have worn out. try a lil bit of w-d 40 or something and see if the wheels are straight if not, try to pull the wheel in the direction of the wheels and then try it. sometimes if they get into a bind they are a pain... also, check to see if the vehicle is in park or neutral
Mar 10, 2011 | Pontiac Grand Am Cars & Trucks
I need to level the refrigerator. The back needs
Hello Monty, If you can roll the fridge out, you'll likely see the adjustment screws for the rear wheels, (if equipped). If the rear wheels are fixed, as most are, you can put a couple of wooden shims down on the floor where the wheels will be and roll the fridge back into place and then make the leveling adjustments from the front wheels.
If the amount of height adjustment is greater than a half an inch, you can use a solid piece of plywood the width of the fridge and about 4-6" wide and place that at the back. Roll the fridge in until it hits the plywood and tilt the fridge forward about 2 inches and push it back until the rear wheels are on the plywood. You can then, again, level the fridge using the front wheel/leg levelers.
I've found that it's easier to get a good idea of just how much out of level the space is where the fridge is being placed. Then you can make the changes using the best materials for the situation. Shims are fine for small adjustments, while the full width plywood is more consistent and easier to adjust, as the fridge will likley get moved out every 6 months or so, for cleaning of the coils and behind the fridge.
Remember that ideally, you want the front of the fridge just slightly higher than the back, so the doors will close by themselves, when opened almost 90 degrees and released by hand. Gravity should then take over and automatically close the doors, ensuring a good seal to keep the fridge closed and running properly.
I hope you find this Very Helpful and best regards!
Dec 24, 2009 | Maytag MFI2568AE Side by Side French Door...
We just bought a Series 430 push mower --- had no trouble adjusting the rear wheels. Can't get the front wheel levers to move at all. Even propped up front of mower to take weight off wheels -- the...
They usually put spring washers in there to keep things tight.
Try some good penetrating oil on the pivot bolt.
Last resort--loosen the bolt, use oil on it, retighten.
Apr 25, 2009 | Garden
I need to move my Kenmore fridge for floor installation
you have to raise the front by runnung the wheels down in the front with either a large screw driver ir a socket wrench the bolts are uvderneith the cover by the floor.
Apr 03, 2009 | Kenmore 65232
Aiwa nsx-ma845 cd tray stuck
CD drives have rubber belts and wheels - 5 years is a long time, perhaps these are worn out. A new CD/DVD drive is very inexpensive.
Dec 28, 2008 | GE NSXMA845 Shelf System
Oct 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Creaking Sound when Opening Door of GE Profile PTS22LHSCC Refrigerator
My GE creaks too, and it started after we pulled it out for cleaning. It is normally the door hinges. Spray them with Jigaloo which is a dry silicone lubricant.
Try this. Go to your local tire repair place. Ask them for an old inner tube. Cut a double thickness square with scissors and put it under the 4 corners under where the wheels are. It should help them to become self leveling and also sound insulating..
Mar 23, 2017 | GE Profile PTS22LHSCC 33" 21.7 Cu. Ft....
Dec 30, 2006 | Amana ARB2217CSR Bottom Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
185 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
