Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
Lcd screen don't work after I remove cam from dock
The LCD screen was working just fine when it was on the dock. After I finished transfering files from the memory card onto the pc, I offed the cam, removed it from the dock, and on it again. But it displays nothing. I can still hear the beeping sounds as I shift from different modes or press the recording button. Even the touch screen seems to work (beeps as I press on the black screen). I don't think it's the wiring that is faulty. It was right after I took it out of the dock that the screen refuse to work. Could it be because I didn't press the "remove drive safety" option from my pc before I offed my handycam? I tried the reset button too. Thanks
    Problem Solver:
  • 4 Answers
As your buttons are working when you press buttons on LCD panel ,The LCD strip which connects LCD Panel to main circuit board (called main board or mother board) is partially dammaged.The symptom changes as per the actual cutting of that strip. after replacing the strip FP-*** will solve the problem. FP-is the part No. If you want correct part code I can give you later as I have to chk in service manual Thanks
Posted on Mar 12, 2007
Does this work with the ipod touch 4th gen
Here are it's features
Product Features
  • Portable speaker/display system designed for all "dockable" iPods**
  • Crystal-clear, 7-inch widescreen LCD display with 480 x 234 resolution
  • Pair of aluminum cone neodymium drivers and Class D digital amp
  • Built-in iPod docking station; 3.5 mm auxiliary input for other devices
  • Measures 8.7 x 1.7 x 6.5 inches (W x H x D); 1-year warranty
Notice
Notice it say ALL iPods, as long as its not the 5th gen ipod with the new dock connector it should work fine.
Oct 14, 2012 | Sonic Impact 5090 Video-55 LCD Video and...
My screen goes dark when I use my laptop. I have a docking station with monitor and the machine works fine. However when I undock or start up with just the laptop the screen goes black. I can still see...
Hi wilhejl,
I see that you are experiencing a video issue with you back light on this case,
you mentioned when docked on your docking station you see the video on you monitor but when undocked you get a black LCD screen and see shadows of what is on the LCD screen.
this is a back light issue that you are experiencing.
We can try and check some settings regarding this concern and se if there is anything we can do to correct what you are experiencing with your laptop
As soon as you turn your Laptop on keep on tapping F1 to will bring you to the BIOS screen if the BIOS shows up on you LCD screen without going black then most probably yo may need to change some settings in windows regarding the the LCD and power options.
  • Try docking back into your docking station and inside windows go to power options, and set your system power options to balanced.
  • On your Desktop right click anywhere on an open space to get the menu list click on personalize then click on display then click on advance settings, look for screen refresh rate change it to 59Hrtz then undock from your docking station and try booting into windows without using the docking station to check if the video will show on the LCD again on this issue.
I hope that this can help regarding your case,
Have a nice day.
Apr 07, 2011 | Dell Latitude E5400 Laptop
What can I do to fix my hp pavilion tx2000 because it shows a black screen when I turn it on but everything else works fine and it even worked perfect when I connected it to another monitor by vga
You might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 15, 2010 | HP Pavilion TX2000Z Notebook
My HP G60 lap top has a blank screen, when I plug it into an external screen, it works fine. Help me guys.
This might be a sign of a faulty LCD cable or screen inverter board.
Aug 29, 2010 | HP G60-120US Laptop
Syncmaster 2333- connected fine to laptop on docking station for 3 months. Then all of a suddent it is causing my laptop to crash. laptop works on its own. Connected, the monitor shows my encryption...
Disconnect the monitor from the docking station and plug it directly in the laptop connector. If all is well it might be the docking station. I had one crash a computer and had to rebuild the operating system to make it work again.
Mar 09, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Inspiron 600m,"no input signal check video cable"?
Do you have an external monitor for use when the laptop is on the docking station? If so, does your laptops screen come on when it's not docked?
If you're using an external monitor while the laptop is docked, make sure that the screen selection is for external monitors, by pressing/hold the FN key and then press the F8 key to cycle through the choices between LCD, Monitor/LCD or Monitor only.
Mar 10, 2009 | Dell Inspiron 600M Notebook
MY N1 LCD GONE WHITE
you have a damaged LCD screen ..
goo & get it fiiiiixed. yourwelcome .
Jan 24, 2008 | Sony Cyber-shot DSC-N1 Digital Camera
LCD display is not working
the flex wire of lcd monitor has being cut.....and a message 'cover is not open' there switch inside the cover of the lens that is losing contact....
Aug 29, 2006 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
