Question about Samsung SyncMaster 920N 19" LCD Monitor
I cant able to install my SAmsung 19'Monitor Wide.Its gresults VGA card failure
    Scholar:
  • 68 Answers
It sounds like you are having a problem with your VGA Card (Video Graphics Adapter) and not with your monitor. Most monitors do not need to be "installed"
Go into your Device Manager and see if there are any items that have exclamation marks next to them. If there are, those are problem areas. Under Display Adapters there should be a specific item (Intel 845G, nVidia GeForce 9800 GT, Radeon 4850, etc.) and under Monitor should be "plug and play monitor".
Posted on Dec 08, 2008
I am using windows XP SP3 and got a new 19" VisonQuest monitor but can't set the resolution.
Depending on your motherboard (or VGA card if independed) the maximum resolution may be lower than the requested by the monitor. The only solution for this is to add (or change) the VGA card with a newer one that can support the screen resolution (check the VGA's specifications). Another one solution is to use the screen at the maximum resolution that your VGA can handle. This is the easiest and cheapest solution but your on screen image quality will be reduced.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Jun 17, 2011 | Computers & Internet
Lg logo appears then goes in to power saving mode LG Flatron Wide Monitor
Hello davidhague99 ,
Check your VGA cable if connected properly to your CPU or Video Accelerator Card,if connected properly,try another VGA cable and if the problem persist you need to try another source.
hope it helps thanks
Jun 11, 2011 | LG FLATRON L1919S-SF 19 inch LCD Monitor
Just bought new tower pc,when connecting to monitor getting error box which says"not optimum mode,reccomended mode 1280 x 1024 60hz ? any thoughts?
hi,
I think the operating system your using has less color drives or on board VGA has less color dives which would work with the monitor .
An upgrade of your operating system would fix it .or buy a VGA card and this will come wit its color drive installation CD ie
Good luck
Jan 16, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
Cant get size from display settings for external 19" Samsung Sync Master 931B cant see start button everything to large
See if you can pull up the menu on your monitor. If you can reset it to factory defaults.
If you still can't see the screen properly then you need to on your computer. Go into the device manager and make sure its seeing your video card properly. Look underneath display adapters and be sure its seeing something other then standard display vga.
If not then your display adapters are missing so once you install those, the computer will recognize your monitor.
Dec 18, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Monitor is blinking green light but no dark screen
does you cpu have a built in vga or you use a separate card? check at the back of the cpu, if you are using a cpu that has a built in vga and youre using a separate vga card may you have just connected your lcd monitor on the built in in which many cases will not work you need to connect your lcd on the separate vga card, if that is not the case and you head a beeping sound with intervals then there a problem with your vga card now if you use built in video you need to put on a separate vga card agp or pci-e which ever is supported by your motherboard, hope this help
regards
michael
Nov 20, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
W17e says "input not supported"
Hi - here's what I found about your wide screen monitor:
The HP Pavilion w17e LCD wide-screen monitor has the following features:
  • 1440 x 900 factory-set resolution
  • Supports VGA analog signal video input
  • Plug and play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
  • Energy Star compliant
Download & install the drivers for the monitor based on the version of Windows you are running from the HP site below:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=pe&dlc=es&product=3377546&
Once the drivers are installed, your issues should be resolved - the driver will allow only the modes that can be displayed on the monitor - probably giving you options for resolutions you hadn't seen before.
Sep 29, 2009 | Acer AL1916W 19" LCD Monitor
Display problem with ViewSonic VX1962wm 19" wide monitor
id say this is a compatability issue before interference from other sources(Undefineable)
Jan 30, 2009 | ViewSonic VX1962wm LCD Monitor
I have lines over my monitor
Dear Mihajlo,
Your problem isnot monitor but VGA adapter, you have to install different(adequate) driver or if it isnot useful to change VGA card. Check for new driver at the VGA card manufacturer site.
Best regards.
Jan 05, 2008 | Samsung 793DF 17" CRT Monitor
Resolution Problem
you need to be installing a graphics driver for your onboard graphics or your graphics card, the monitor driver won't change the resolution, when you installed XP there wouldn't have been a graphics driver installed, only a VGA driver to enable a 800 x 600 resolution.
Find out your card manufacturer or your onboard graphics or use the cd that came with the motherboard or card.
Oct 22, 2007 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Samsung SyncMaster 920N 19" LCD Monitor Logo
64 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Brian Sullivan
Brian Sullivan
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
