Question about Philips 37MF231D 37 in. LCD Television
I have no picture, the power green light just flashes
My Magnavox 37MF2310/37, only the green light just flashes when turned on, no picture.
  • cbran353 Dec 20, 2008
    pover light just flashes no picture.
IrishDruid
  • 2712 Answers
SOURCE: Magnavox 37MF321D/37
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try plugging in the TV through the USB on its panel to a computer or USB charger, and it may work. However, this is only a temporary solution.
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
4. A circuit board may crack about some of the larger components mounted on it. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
5. If you want to go in for a long term solution, you can easily replace the whole power board or just change the faulty capacitors. You will have to open the back panel and take a look. You can make out which are faulty, because their caps will be swollen on top. Here's a sample pic (not same model):
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you, or get a qualified technician. Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified technician to do it for you.
REMEMBER there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
thekleppinge
  • 5 Answers
SOURCE: My magnavox 37mf321d 37 LCD tv
This is a bad power supply and an easy fix. Their are several electrolytic capacitors on the power supply. If one is bad it will have a bulge on the top. Mine had a bad 2200uF and a bad 1200uF capacitor. About $7 worth of parts at Radio Shack. Radio Shack had the 2200uF but it was axial leads instead of radial. (leads come out of each end instead of one end) but It will still fit. They only had a 1000uf capacitor so I combined that with a 220uF capacitor and wired them in parallel. Make sure you put them in with the correct polarity.
Posted on Dec 06, 2008
  • 8 Answers
SOURCE: magnavox 37" flat screen model no.37mf23id/37
Yes, he means 2200 microfarret (called uf from here on out). Another important concern when buying a replacement is the voltage. You need to get something that is at least 25v. I recommend a 35v or better. Another notable point is that this may not always fix the problem. As with mine, there was also a 1200uf (microfarret) 35v capacitor that was blown. You can tell this because they bulge at the top. I have both of these caps (2200uf 35v and 1200uf 35v) on order and they will be here tomorrow. If I do not post back here then they fixed the issue for me. I suspect that this will resolve the problem. Look for bulges on top of the caps. This is an indication that they are blown. Most all of you experiancing these symptoms will see the 2200uf cap bulging but you may also see others bulging too. If you do then you need to replace those too. No electrolitic capacitor should be bulging at the top so if its bulging its bad, and if its bad then your tv will definitely not work. Have fun.
Posted on Oct 13, 2009
SOURCE: magnavox 32mf23id/37 wont tun on
highldnr1 is a genius.. both those power supply caps had a bulge on top, fixed in 10-20 min, once I figured how to disassemble..
Two caps, μ1200/35v, 63¢ x 2= $1.26 labor, 20 min, less steak dinner, = $0
gratitude?? the customer (my dad) is ecstatic ~!!!
Posted on Jan 19, 2010
SOURCE: philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
Posted on Mar 06, 2010
The light on my magnavox converter keeps flashing green then goes to stand by mode
mine is doing this too, i called Magnavox support and they aid it is an internal power issue and cant be fixed by troubleshooting, it has to be serviced. imo, probably cheaper to buy another.
Nov 06, 2012 | Magnavox (TB100MG9) Video Converter
The power light on my Magnavox 42mf531d 37 flashes green
Download its service manual from internet. It will have all details with illustration.
Sep 16, 2012 | Televison & Video
Powers on but no picture or sound
i need a screen off a 47inch magnavox if u coudent fix urs and ur interested in selling me ur screen let me know
(47mf437b/37) noe28cervantes@yahoo.com
Jan 04, 2010 | Toymax Magnavox 47MF437B 47 in. LCD TV
No sound, no picture` MAGNAVOX 51MP6500D/37
SSB board it is over next to tuner stands up behind it . Call Mats for Part 1-800-628-1118
Sep 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
My magnavox 37MF321D/37 will not turn on. It
I had the same problem with the blinking green light. These are the parts one the power supply I replace to repair it. note: If the power supply is repaired you will get a solid green light and the backlight will light up almost immediately.
Aug 01, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
No picture
if it is dropped you most likely would have a cracked ciruit board. you would need a qualified tv repairman to check tv
Jan 14, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Phillips Magnavox
Sounds like your Convertion bord pops. Tv Technical Prop, Take for service.
May 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Tv problems
i have a sony hdtv 60" and when I try turn the tv on the power light flashes 5 times green then it turns red
Nov 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips 37MF231D 37 in. LCD Television Logo
126 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
