Question about LaCie Electron IV 19" CRT Monitor
"Monitor communications failure" at completion of calibration
The screen has started dimming the controls at the bottom say OSD locked out.  I don't know how to operate any of the buttons below the screen.  I get no menus when I push them.  These may be two separate problems.
The screen is now too dark to use.
  • 734 Answers
There is a problem in picture tube of your monitor.
Need to be replaced.
Thanks
Posted on Dec 08, 2008
  • futureloginn
    futureloginn Dec 08, 2008
    ok try a mathod -----
    Hold the menu/ok button for ten seconds, to unlock the OSD.
    If this doesn't solve the problem, then it's probably the button that got stuck.
    There are two things you can do to repair it, but both require that you dismantle the casing, which voids any warranty.. so, if the monitor's still covered by the warranty, or if money is not an issue, have it repaired by professionals on an accredited brand shop (check your warranty details for more information on this subject).
    If not, remove the casing, locate the menu button's contact switch on the circuit board, and try to release it using something thin like a screwdriver, x-acto knife, or set of plyers.
    If this doesn't work, chances are the menu button is stuck on a loop, sending a continuous signal to the board (which keeps locking/unlocking the OSD).
    If so, your only solution (other than take it to a repair shop) is to remove it, by prying it off with a screwdriver or set of plyers.
    Of course, you'll lose access to the OSD features, but I guess this is better than to have a message stuck on front of your screen all the time..
    This is a tried and working solution, since I had this problem myself (with a Philips 190B monitor), and solved it successfully, with this method.
  • futureloginn
    futureloginn Dec 10, 2008
  • 6,487 Answers
Lets try first check what is the real problem here, because this can be a problem of the monitor or with the video card of your computer, first thing to do here is to try a different monitor so we can make sure that the monitor has the problem or a different device...
    Scholar:
  • 68 Answers
You will need to unlock OSD (On Screen Display) to be able to adjust the brightness and other settings. Here are the instructions to do that.
To unlock the OSD on the Electron Blue 4 monitors:
  • Open the OSD by pushing the “EXIT” button. (If you open it with the <,>, - or + press “EXIT” once). You should have one green tab (if it is yellow, press the “EXIT” button to turn it green. You should see the message “OSD LOCKED OUT”.
  • Press simultaneously “+” and “SELECT”. (If the tab becomes yellow it means that only “SELECT” was taken into account.. Press the “EXIT” button to turn the tab green and try again).
  • Note: Do not hold down the buttons if the operation fails. Try again by releasing both buttons and pushing them one more time. If it still fails, test the “SELECT” button before trying again.
    Osd locked fujitsu
    If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
    - Flickering screen
    - Screen image disappears after several seconds
    - Dim screen
    - Slow start
    - Power LED on, but no picture
    - Unusual colors and/or lines
    The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
    If they appear bulged on top, then they need to be replaced.
    New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
    Check the cables, connectors and connections.
    Take it to a repair shop.
    Apr 19, 2014 | Fujitsu Siemens Siemens Basic Line B17-1...
    Philips monitor osd locked
    you have to carefully force open the clipped back case of the monitor and disconnect completely the cable to the front control buttons, then the monitor works fine though no adjustments can be made
    Jan 12, 2014 | Philips 190WV
    Ihave an view sonic E70fb moniter. and am having problem with osd lock. osd lock strip often and often see in my moniter screen. and i coulden't solve this problem. so, please give me the solution as...
    · The OSD Lock Out Message
    Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
    · 2
    Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
    · 3
    Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
    · 4
    Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
    · 5
    The OSD Settings Menu
    Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out
    Jul 22, 2011 | ViewSonic E70f 17" CRT Monitor
    My HP 1730 monitor is showing "OSD Lock Out" message. How can I remove this msg?
    The following site has step by step instructions on steps you can try: http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
    I'll paste them below: All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on screen display (OSD) lock out that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lock out setting, there are several different ways you can remove the lock out, depending on the make and model of your particular computer monitor.
    1 Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
    2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
    3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
    4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
    5 Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
    Mar 01, 2011 | HP 1730 LCD Monitor
    Too bright
    hi,
    change the brightness button of your monitor. you can find that button on your monitor. it has a "sun" icon, then change to your desired brightness.
    Feb 19, 2011 | Acer Computers & Internet
    "OSD LOCKED" box on my screen
    The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
    * If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
    * If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
    OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
    If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
    If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
    VOTE ME
    Dec 07, 2010 | Dell Computers & Internet
    My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
    This is from the user manual for the monitor. You can download a copy from hp here:
    http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
    Click on the "monitor user's guide" link to download.
    There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
    To change OSD settings:
    1 Open the OSD setting screen under the Advanced menu. See
    “Using the On Screen Display” on page 25.
    2 Press the Browse buttons to select the option you want to adjust.
    3 Press the Select button to check the option.
    To change OSD lock setting:
    1 Press the Browse button to select yes (lock) or no (unlock). The
    setting is automatically saved when you change the value.
    2 Choose Exit sub-menu and press the Select button to return to
    the OSD Main Menu or press the Menu button to exit OSD.
    NOTE: Once OSD is locked, all OSD functions including the
    shortcut buttons are disabled. If OSD is locked, pressing
    any button on the monitor directly opens the Lock OSD
    settings window so that you can unlock OSD.
    Dec 02, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
    Help with my 190S monitor
    I have Philips 19C monitor. From today, every 5 secs an attention message
    "osd main controls locked and unlocked"
    The AUTO(OK) bottons for 10 sec not give nothink
    What i can to do with this?
    Gregory
    my mail - communar@agry.gov.il
    Thanks
    Aug 22, 2008 | Computers & Internet
    OSD locked out
    hello you have Resolved ?
    thanks andrea
    Jan 25, 2008 | LaCie Electron 19" CRT Monitor
    LaCie Electron IV 19" CRT Monitor Logo
    42 people viewed this question
    Top LaCie Computers & Internet Experts
    Raj Patel
    Tony
    Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
