Question about Maytag MER5775Q Electric Kitchen Range
Neff U1420 oven gets hot then cools.
The main (lower) oven of our Neff double oven gets hot when it is turned on then after a few minutes starts to cool down and never regains the correct temperature, the top over and grill are working perfectly.
Any thoughts would be most welcome
  • home180 Dec 09, 2008
    Many thanks for comments, however (and sorry if I did not make it clear) the Neff U1420 is fully electric.
    Any other comments would be greatly received.
    Habit-Forming:
  • 171 Answers
There are is an ignitor nest to the oven burner. that part gets red hot when you turn the oven on, but when starts to go bad it takes longer and longer time to open the safety valve that supplies gas to the burner. or i can turn on but it will not stay on it go es of again. the ignitor needs to be replace.
Posted on Dec 08, 2008
Neff u1421 double oven , both ovens work fine but the grill trips the circuit breaker after 5 minutes of getting hot
you need to check size of breaker the oven is wired too if this is to small it will trip also cable size
Sep 18, 2013 | Neff U1421 Double circotherm Electric Oven
Neff u17 built-under causes fuse to blow on all the kitchen electrics a few seconds or minutes after the bottom oven is turned on. No problem turning top oven on. Have changed element in bottom oven with...
There could be a fault in the lower oven , or it could be overloading the circuit. add the watts of the two elements and divide by line voltage, this will give amps , now check the fuse rating amps , it must be higher than the oven. If that checks out ok the fault is in the oven.
Jan 03, 2018 | Neff U1721 Double circotherm Electric Oven
I have a Neff U1420 double oven and the hinges on the main oven do not close the door fully. I have read that it is possible to correct this problem by putting washers under the screw of the hinges but I...
Hi.
If the door does not close properly then the fault is a faliure in the door hinge springs. Sorry but using washers will not cure the problem..
The only way is to replace the two door hinges. You may NOT need to replace the hinge backs.
If you would like to email me the full model number (numbers after U1420) then i can source the part numbers for you.
regards
Aardvark Repairs
aardvark.repairs.btinternet.com
Nov 17, 2009 | Ovens
Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Oct 25, 2009 | Neff U1421 Double circotherm Electric Oven
Oven not achieving correct temperature, 50 degrees too low
Thermostat is not working properly and needs replacement.
Apr 14, 2017 | Ovens
Neff U1452 tripping electrics
Hi
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
regards dan
Mar 19, 2009 | Neff U1452 Double circotherm plus Electric...
Neff oven u1420
Hinges not fitted properly,or possibly wrong hinges
Nov 03, 2008 | Neff U1661 Double circotherm super...
Main oven tripping the fuse
probable fault to earth of circular element - gets worse when element hot. you will need a megga to confirm this.
May 22, 2008 | Neff U1721 Double circotherm Electric Oven
Auto Timer
hi there switch your oven off at the mains switch for one minute thenswitch back on and set the time this will disable the auto on the timer.
Dec 09, 2007 | Neff U1661 Double circotherm super...
Maytag MER5775Q Electric Kitchen Range Logo
125 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
