Question about VillaWare 2010 Waffle Maker
Broken part of handle
On a Villaware Waffle Maker Model 2010, the small plastic bit on the upper section of the handle has broken off, so it is not possible to flip over the unit. Anyone know where to get the part? Or another solution?
4 Suggested Answers
jerryg50
  • 1673 Answers
SOURCE: waffle iron top not heating
I don't know for your model type, but in many of these the heating element can be replaced. Check with an ohm meter to know if the element is actually defective, or if it is the thermo safety cutoff fuse that is blown.
If you were to do this yourself, and you know about appliance servicing, have instruments to check for proper temperature and current draw, and you will need the proper crimp-fittings (stake-ons), and crimp tool to do any of the wiring inside.
Jerry G.
Posted on Jun 27, 2008
sandrineFY
  • 268 Answers
SOURCE: I ahve a wonderful conditon villaware waffle and
You can download the manual from this site:
http://www.retrevo.com/samples/VillaWare-manuals.html
Recipes:
http://www.mrbreakfast.com/article.asp?articleid=29
Bon appetit!
Posted on Jun 04, 2010
jyackle5
  • 8197 Answers
SOURCE: I have 4 UNO Villaware
This is straight from the manual. Look at page 3.
Before baking the first waffles of the day, use a pastry brush to lightly coat
the top and bottom waffle grids with vegetable oil or melted shortening.
You'll find that spray shortenings work well for this purpose. Repeat this only
at the start of each day you bake waffles.
Here is the manual.
http://www.villaware.com/manuals/VillaWare/V5800_English.pdf
Posted on May 18, 2011
My maffle maker WMB505 got its front plastic handle broken. How to get a replacement handle?
mailto:homeappliancesupport@spectrumbrands.com
or call 1-800-231-9786.
Ask if they have the handle. It does not appear that you can order online.
Feb 20, 2016 | Spectrum Diversified B & D Wmb505 Belgian...
Find a leg for toastmaster waffle maker model 270 or 290
http://www.searspartsdirect.com/partsdirect/part-model/Toastmaster-Parts/Waffle-maker-Parts/Model-270/1097/0213700/00039364/00001?blt=06&prst=&shdMod=
Jun 18, 2014 | VillaWare 3600 Prego Pizzelle Baker
Need manual for villaware uno 2003 uno heart round waffle maker
http://kitchen.manualsonline.com/manuals/mfg/villaware/villaware_waffle_iron_product_list.html
Dec 05, 2013 | VillaWare Kitchen Appliances - Others
My villaware waffle model 2010 has an issue with the little metal piviting latch that allows it to turn the waffle bed. It appears that when the lid is closed, it doesn't touch the metal latch that al
the piece that seems to be not working (although you didnt show it on the video) is the top handle, and I think that if you wrap a bread twist tie around the top handle on the waffle iron side of where you grab handle, the twist tie will hit that little lever underneath when you close the lid, allowing you to spin it
Mar 09, 2013 | Kitchen Appliances - Others
Need a hinge pin for hinge opposite the handle it is broken
Buy a new waffle maker. I have the same problem. Got by with one broken hinge for a few years, but now the 2nd is broken. Called the company & there are no replacement parts available (looks like the hinge was a common problem). After looking around online, I'm not able to track anything down.
I've personally narrowed my choices down to:
The Caphalon No Peek Round Waffle Maker
Proctor-Silex 26500Y Belgian Waffle Maker
Black & Decker Chrome Belgian Waffle Maker WMB505
Cuisinart WMR-CA Round Classic Waffle Maker
Feb 17, 2013 | Faberware FWM800P Deluxe Chrome Belgian...
I ahve a wonderful conditon villaware waffle and panni sandwich maker. It has a knob with numbers 1, 2, 3 and 4. I have no idea how to cook a waffle on it. I am guessing you heat it on maybe 3 until the...
Recipes:
Bon appetit!
Jun 04, 2010 | VillaWare 6150 Mulit Baker Waffle Maker
The waffle maker just stopped being hot. Red light was on, but machine was not cooking the waffle
I see this is an old post but I was just looking for parts for mine and saw it. It seems like many have this problem. I think it is a design flaw. I took mine apart and founf the wires at the top heating element melted and shorted. Luckily there is an in line fuse that protected everything. the problem is finding replacement parts. I have just contacted the company about parts. Only the proper parts should be used to fix this. rigging something would be dangerous or worse.
Jul 04, 2009 | VillaWare 2010 Waffle Maker
Turns on but doesn't Cook
It sounds like this is a common poblem but I found what it is. I am a mechanical engineer and fix anything and everything. I had the same thing with my Villeware model 2010. I took it apart and traced with a meter to find the problem. I found the wires to the heating elements in the bottom half melted and shorted where they cross (bad design) just past an inline fuse ( good part of the design!). I can't find any place that carries parts and contacted Villaware direct but do not expect any luck in getting a new wire harness. The fix is either the proper harness or the correct fuse and high temp wire and correct crip connectors. Bypassing the fuse or using incorrect wire would be dangerous, would destroy the control board if another short would occur or possibly lethal from shock or fire.
Feb 23, 2008 | VillaWare 2010 Waffle Maker
Waffle Iron Handle Broken - Need Replacement
Go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
Sep 02, 2007 | Waring WMK300 Professional Belgian Waffle...
VillaWare 2010 Waffle Maker Logo
48 people viewed this question
Top VillaWare Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Michael Vincent Cruz
Angel Joseph Jr.
Angel Joseph Jr.
Are you a VillaWare Kitchen Appliances - Other Expert? Answer questions, earn points and help others
