Resealed intake on s-10 pickup with 4.3 and cant get to run i think the timing is not set properly has multiple timing marks. which ones do i use?
Hi there:
Fig. 13: Timing mark alignment-4.3L engine
Check cranksahfts and camshaft correctly installed.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
SOURCE: Multiple misfire code
i had same problem distributor gear becomes worn replace it and will most likely fix your problem they are known for distributor issues
SOURCE: i cant find which fuse is the right one for the
There is a fuse box under the hood. Most likely in front of engine and near battery. The fuse may be labeled "AUX PWR" or "CIGAR".
SOURCE: i need to know the correct way to install a
pull out num 1 plug bring it up too compression stroke timing mark will be lined up with indicator on timing cover and harmontiac balancer drop in distributor rotor button is now pointing at num 1 plug wire,
start it up adj dist till it is running smooth!!!
SOURCE: i have a 91 chevy s-10 pickup the truck has a starting
If its an automatic chk. for bad starter switch under dash, if its a standard shift chk. the clutch switch witch is under the dash too.
