Question about LG LRSC26980 Refrigerator
Ice tray sometimes stuck when dumping off ice
The ice tray in my LG fridge usually turn sideway to dump off the ice into the ice bin when ice is ready and then water is filled into the tray again. The problem is the ice tray remain in the bent position rather than retract itself into the horizontal posisition after dumping off all the ice. It looks as if the tray is stuck twisted sideway on one end and stay horizontal on the other end. This caused water to spray over into the ice bin and sometime all over the other part of the freezer compartment. The bottom of the ice bin is frozen stiff and I have to thaw out the tray everyday. Is there something to look for in the ice tray to fix this? how does it actually work? Thanks in advance.
  • 2 more comments
  • Anonymous Nov 11, 2007
    I have the same problem. The ice tray becomes twisted and water spills down the inside the freezer and some into the ice bin. What can we do?
  • Anonymous Dec 30, 2008
    Same here...it stinks. This thing wasn't cheap
  • Guest Jul 05, 2013
    I occasioanally have the issue of the tray getting stuck twisting and torqued. After some experimenting the solution is pretty simple. The left hand side has a rectangle tab that drives the tray to dump ice and the right hand side is has a round tab that simply lets the tray rotate. By pressing the tray to the right or left you can separate either the rectangle tab on the left or round tab on the right from the ice tray. Once separated, It releases the torque and twisted tray. Simply reinsert the same way you removed it by separateing the acttachement area to reinsert the rectangle tab on the left and round tab on the right. It almost feels like you'll break the attachment but it flexes enogh to take apart and reinsert. There is no need to remove screws. Just remove the Ice storag bin and it exposes the tray.
  • Anonymous Mar 23, 2014
    The ice bin turns a little bit then goes back to normal position there is ice in the bin It seams like it is not going thru the cycle the bin does not turn fully to dump the cubes
I had the same problem. I did the following and it now works great. The ice tray has a square tab on the rear leftside. As the tray rotates to dump the ice, the tab runs on a curved section of the the ice maker frame. The curved section becomes rough with use and causes the tray to stick when it is returning to the fill position. I carefully sanded the curved section of the frame to smooth it out. No problems since.
One does have to dismantle the ice maker to effect this repair.
Posted on Jun 17, 2008
I am an attorney near Philadelphia who is considering initiating a class action against LG related to the defective design of their ice maker. I have clients in different states who have had problems that LG fixed, but the problems re-occurred after the warranty expired. I've been advised by mechanics that leaks are inevitable based on the design. Apparently this is a design that LG had used years ago but had discontinued for a while because of leak problems. I'm usually on the defense side of product liability cases, but this seems to be a common defect. If you are interesed in such a suit, feel free to contact me at corrlaw@verizon.net. Law Office of John A. Corr, (610) 482-4237.
Posted on May 15, 2009
I had this same problem. After seeing the modified ice tray that's available, it dawned on me to cut a plastic credit card (or similar material) in half and adhere it with epoxy to the inside of the ice tray to mimic the raised edge of the new tray. No more clumped ice or water spilling down into the bottom portion of the freezer! I did remove the ice maker to add the modification, but I think it could be done in place. Just ensure that the adhesive is dry before turning the system on again.
Posted on Nov 14, 2008
Where can i get the new tray with the spill lip on it so the water stays in the tray. Part #3390JA1150A
Posted on Jul 01, 2008
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
There is a new tray out, it might solve the problem.
Part number is 3390JA1150A
Posted on Jun 03, 2008
Manitowok ID0452A-161 water not draining one water tray is filled causing water to over flow into ice bin melting ice. Need to know where the float switch is and dump valve solenoid. FOR TROUBLESHOOTING
Remove side panel on left. Dump valve and drain hose usually blocked with silt, but may be dump valve coil open circuit. No float switch, water level sensor above tray.
Mar 04, 2014 | Manitowoc ID0452A-161 Dice Cube Air Cooled...
My LRSC26923TT side by side fridge/freezer has stopped making ice. It still dispenses water but it would not dump the last tray produced. I removed the cubes from the tray by hand, emptied the freezer, and...
Unfortunately, Ice Makers are notoriously unreliable and most require more expertise than a handyman possesses. Most require replacement of one of the 4 main parts (usually not generic): drive motor, water solenoid, heating release element or bin full ice arm control switch.
A Certified Technician should be able to diagnose the problem and suggest a repair or replacement.
Apr 22, 2017 | LG Refrigerators
LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
Mar 21, 2009 | LG LRSC26910 Side by Side Refrigerator
Ice not dropping
Press the little button on the bottom right of the ice maker and clear the tray of ice. The maker has to be turned on for the tray to tilt and empty. This corrected the problem for me. The freezer side may have been left open and and the ice maker filled the tray while the door was open, I suspect.
Nov 12, 2008 | LG LRSC26940ST 36" Side-by-Side...
Ice maker problem
Clear the Ice tray by pressing the button under the ice maker. The problem is that the ice is in the first couple of slots is not dumping and the tray tries to fill again and over flows. I pressed the button and cleared the tray of ice (This will tilt the tray and twist it to empty it) that was re-frozen several times without dumping. My ice maker works perfectly after I did the above. I think the problem arises if the door did not close completely. I stopped hanging the dish cloth on the door and on my LG Dish wisher. I hope this helps
Oct 03, 2008 | LG LRSC26940ST 36" Side-by-Side...
Icemaker
did you find out how to fix it ? please let me know
Jul 06, 2008 | LG LRSC-26922 Side by Side Refrigerator
LG SXS Refrigerator LSC26905 ice maker
I was able to order the ice tray myself and install it in the fridge - it's not hard. I ordered from one of the parts sellers linked to at the LG website, not those listed in other posts here.
Here's how to replace the tray:
You need to remove the tray dumping mechanism to do this.
  1. Remove the ice bin, set it aside (don't forget to deal with the ice melt).
  2. Turn the ice maker off (LG says to unplug the fridge, I didn't).
  3. On the left hand side of the ice tray dumping mechanism there is a screw helping to keep the entire thing suspended from the ceiling of the freezer. Remove that screw- don't worry, the mechanism will stay put for now.
  4. The dumping mechanism can now slide forward- note that you can't completely remove it from the freezer yet, but slide it forward and it will no longer be suspended from the ceiling. Don't let it drop or hang.
  5. You need to disconnect its power supply now. On the left hand side you should see a small bundle of wires coming from the back of the freezer to the dumping mechanism. It connects to the dumping mechanism's set of wires with a pair of white plugs. Pull these plugs apart. You may need to pry the catch on these plugs apart while you pull.
  6. Now you can take the dumping mechanism out of the freezer (and close your freezer).
  7. To remove the ice tray you need to slide the housing that contains the rotating motor out of the housing. This is on the right side of the mechanism. If you have trouble identifying it look at the underside of the entire thing and you'll see a small "test" button. That button is on the motor.
  8. To remove the motor you'll see two catches on the right side- you'll need to pull these catches out without breaking anything. You'll be able to slide the motor down and out when you get it right.
  9. Sliding the motor out lets you get the old ice tray out now. There is probably a set of white wires routed through a little catch on the old ice tray that you'll need to free.
  10. Put the new ice tray back on the motor. You'll need to get the left side secured at the same time you get the motor housing in its catches of the dumping mechanism.
  11. Reroute those white wires back on the new ice tray.
  12. Reconnect the electric wires to the housing.
  13. Slide the entire dumping housing back onto the ceiling of the freezer and screw in on the left side.
That's it. You can press that test button on the underside of the motor. This will dump the tray and immediately refill it with water so you can observe if everything is working.
Jun 03, 2008 | LG LSC26905TT Side by Side Refrigerator
Your icemaker tray has an update for the water flowing over the tray.  You will need to call a qualified LG technician to get it replaced.  Also, the tray is twisted because it binds itself against the hinge pin on the left side.  To stop this, spray some cooking spray oil in the left hinge pin and it should unbind itself and return to normal.
Mar 24, 2008 | LG LSC26905TT Side by Side Refrigerator
Ice-maker problem
it will respond better if you fill it with scotch
Apr 16, 2017 | Refrigerators
Samsung Icemaker Problem
I also had the ice tray stuck in the dump position. I unplugged it waited 5 minutes and pluged it back in. And the Ice tray moved back into the correct fill position, and the arm did drop down, But now it has not filled with any water. So now what should I try?
Feb 20, 2007 | Samsung RS2534 Side by Side Refrigerator
LG LRSC26980 Refrigerator Logo
1,392 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Mike
Mike
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
