Question about Simplex Kaba Ilco Unican 1000 keyless lock
Erased the code
The back of lock was opened and now the existing code does not work
Thanks
  • Anonymous Mar 31, 2014
    Door wont stay locked. Tried resetting the code per instructions and still doesnt work. Code has been set and works correctly when taken apart.
  • 71 Answers
FOR YOUR SECURITY THE
COMBINATION MUST BE CHANGED
WHEN THE LOCK IS INSTALLED.
The door must be open.
On models with the passage feature, make
sure the passage feature is disengaged: turn
knob or key should be in vertical
position (A) (see figure 14-1).
1. Insert the DF-59 control key (B) into the
combination change plug assembly (C)
and unscrew the cylinder by turning the
key counterclockwise. Remove the combination
change plug to gain access to
the combination change sleeve (see figure
14-1).
2. Turn the outside knob once clockwise
(all the way, until it stops) then release.
The latch should not retract (see figure
14-4).
3. Enter the existing combination. On new
installations, use the factory-set combination:
depress 2 and 4 simultaneously,
(release), then 3 (release). You should
feel a slight click as each button is
depressed.
4. Insert the spanner wrench as shown in
Figure 14-2 to engage the combination
change sleeve (A). Gently turn the
spanner wrench clockwise to the stop
position (a slight click should be felt),
then turn the spanner wrench counterclockwise
to the stop position (A) (see figure
14-3). Remove the spanner wrench.
5. Turn the outside knob once clockwise all
the way until it stops, then release. The
latch should not retract (see figure 14-4).
6. Choose your new combination, write it
on page 26, then enter the new combination
— depress buttons care-fully
(a slight click should be felt as
Posted on Dec 13, 2008
  • flyingtarzan Dec 13, 2008
    thought this might help, if not I would need a picture of the combination chamber to tell the combination.
Remote won't work
Take the remote back to the dealer and have the codes erased and re-set. You can do this yourself if you want to. You can find the sequencing instructions on youtube for your year and model of jeep. sometimes it works and sometimes it doesn't. The dealer has a machine that hooks to your wiring harness and fixes it in 5 minutes but they charge you $50.
Feb 10, 2014 | Jeep 2004 Grand Cherokee Laredo
HO2S FAULT CODE COMES UP BRINGING THE ENGINE MANAGMENT LIGHT ON I CAN ERASE THE CODE BUT KEEPS COMING ON WHAT WOULD THE ISSUE BE? I HAVE GOOGLED IT BUT DOESNT SAY MUCH ONLY JUST ABOUT THE OXYGEN SENSOR.
Some fault codes like these can not just be erased n expected to stay erased. Once the car is driven again n the car system relearns itself. The ECU registers the fault again which brings up the code. Since its an existing problem it is only after the existing problem has been solved can the codes be erased. Check O2 sensors connectors to be sure they are connected, if so, check to be sure they are still functioning.
Sep 11, 2011 | Ford Fiesta Cars & Trucks
I got a 2000 Ford Explore that I got about 5 months ago. I don't know the codes on the door to unlock it. how can I get the codes or reset it.
You will need the original factory programmed keyless entry keypad code to program your own code. To locate the original keypad code, open the right/rear door. Pull the on-body rubber weatherstrip out, around the rear side of the door closure. Fold the right/rear seat back down into the locked position to facilitate access to the right/rear seat belt anchor. Carefully pry the upper plastic panel that houses the height adjuster and seat belt anchor off the body taking care not to damage the panel. Now pry the lower panel outward just far enough to enable access to the Vehicle Security Module, where you'll see three electrical connectors plugged into it, colored green, gray, and blue. On the module will be a series of digits on a label similar to 2L2T-15K602-EA. Beside those digits are five numbers. Those five numbers are the key-less entry keypad code. Once the original keypad code has been obtained, you will need to enter it, press the 1/2 button within 5 seconds to activate the programming mode. Holding the 1/2 button for more than 2 seconds after activation will erase the the code you programmed. The existing code will not need to be erased to program a new code. Within 5 seconds, enter the new 5-digit keypad code. The door locks will lock and unlock to confirm the new code is programmed. Hope this helps Tim
Apr 06, 2011 | Ford Explorer Cars & Trucks
Dear sir, i forgot my wallet code so plese help me my hendset nokia 3230
If you forgot wallet code for Nokia 3230 phone,please use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Thank You
Aug 11, 2010 | Nokia 3230
When.try.to.send.messages.it.does.not.go.and.it.says.memory.full.close.some.applications.and.try.again........i.tried.to.put.it.from.phone.memory.to.memory.card.that.didnt.work..........i.have.a.n73
reset your phone bernard..*#7370# then enter locked code..be sure to back up all your data because it will erased..enjoy texting after doing that..the default locked code is 12345....
if you find this helpful ,vote...thanks
Jun 10, 2010 | Nokia N73 Cellular Phone
How to change the keypad code on a 2001 mercury grand marquis
look for the permanent code on the plastic card in the owner manual packet. Or, pay dealer to extract code from computer.
Keyless Entry Keypad Code Programming NOTE: The system only allows one code to be programmed.
  1. Enter the permanent factory keyless entry keypad code.
  1. Press the 1/2 button within five seconds to activate the programming mode. Holding the 1/2 button for more than two seconds after activation will erase the stored customer code . The door locks will lock, then unlock, confirming the code is erased. The existing code will not need to be erased to program new a code.
  1. Within five seconds, enter the new five-digit keyless entry keypad code. The door locks will lock and unlock to confirm the new code is programmed.
Feb 08, 2010 | 2001 Mercury Grand Marquis
NEED TO REEPROGRAMING A REMOTE CONTROL FOR A MALIBU 1998 HOW '?
1. Make sure ignition is in the OFF position.
2. Locate the Programming Connector in the trunk (center of rear shelf). It is a plastic connector with
two wires leading up to it. The connector is not plugged into anything. You may have to pull back
trim to access the connector.
3. The programming connector should have two terminals. Connect both terminals with a suitable
jumper wire. The Keyless Entry Module will lock then unlock all the door lock motors once. Make
sure the terminals remain connected throughout the programming procedure.
4. Press and hold the LOCK and UNLOCK buttons on the transmitter simultaneously for at least 15
seconds or until the vehicle automatically locks and unlocks the door locks. Your new remote has
been accepted and all existing remote codes have been erased.
5. Repeat the previous step for each transmitter to be programmed. Do not remove jumper wire in
between programming of transmitters.
6. Remove the jumper wire from the Keyless Programming Connector.
Dec 15, 2009 | 1998 Chevrolet Malibu
What is the factory code for kingavon safe 25
how do i change code on my safe kingavon 25, i can open and close with my existing code just need the instructions to input new code thanks
Oct 10, 2009 | Safe International Digital Electronic Safe...
Keyless entry
watch this video if the video dosent work go to www.vehix411.com to see the video " />
Dec 03, 2008 | 2000 Chevrolet Venture
1999 NISSAN ALTIMA KEYLESS REMOTE PROGRAMMING
1999-2003
Enter vehicle, close and lock all doors.
slowly insert and remove key from ignition 6 times within 10 seconds. The tail lamps will flash to indicate original code has been erased. Turn ignition to the ACC position.
Press any button on 1st transmitter.
Hazard lamps will flash to confirm programming.
TO enter additional transmitters, unlock then lock the doors using the power lock switch located on the driver door.
Press any button on additional transmitter (up to 4 tansmitters total possible). Hazard lamps will flash to confirm programming.
open the driver's door.
Turn ignition off.
You must re-program all existing transmitters as this process erases codes from car.
Jun 25, 2008 | 1999 Nissan Altima
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
586 people viewed this question
Top Simplex Locks & Locksmithing Experts
Michelle Balcom
JonSnell Electronic
JonSnell Electronic
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
