Question about Sceptre X20G-Naga II 20.1" Flat Panel LCD Monitor
X20G Fails To Power Up - Soloution Found
I bought an X20G-Naga II and was very happy with it, until it dies on me. This seems to be a common problem with the power circuitry. The symptoms are that it fails to power on after a hard power cycle. If it's plugged in, the power light flashes blue once or remains a steady purple. The problem is that it is switching on, but it fails to initialize completely. Sceptre fixed it once, but it failed again after the warranty expired. I've found that I can get it working again by doing this; 1) Power off. 2) Disconnect monitor cable. 3) Power on. 4) Wait for power light to flash once. 5) Quickly insert monitor cable before the power light flashes a second time (if you are too slow, the screen will 'hang' with no screen display). 6) The screen will now work.
  • 1 more comment
  • Scott
    Scott Jan 13, 2008
    I have the same issue. I have a X20WG and the monitors led power
    lights go purple when it first starts up and stays that way. No sound comes through and not one notion that it is doing anything but powering the power leds. I talked online to a Sceptre tech support guy and when he found out my warenty expired three weeks back he wouldn't tell me anymore than it can be sent in for service for 175$+shipping for a chance at fixing it.
    I have completly disacembled the monitor and then reassembled hoping something just came lose while moving the monitor..nope no change. I did however find something that might be a quick fix..and it was obvious. On the main pcb there is in white type "Cation for continued protection against fire please replace with fuse of same ratings"; so there is a fuse and a white arrow pointing to one of two components. My goal is to find out which one the fuse is sodier a new one in and try it out. If this is a quick fix all go with it. I dont know what else this might be. If those turds at Sceptre wanted me to pay 190$ to change a fuse the monitor will not be the only thing that will need a new fuse....errr!
    Any help would really help me out, I paid good money for a monitor that I thought would last a while..nope..I wasnt planning to shell out more cash for a new one...Thanks
  • Anonymous Apr 20, 2008
    Mine does basically the same, except, when you power it up, it flashes blue once, the all goes out. Nothing on the screen. No LED. absolutely nothing. Please help.
  • LGColeman Nov 29, 2008
    I have the same problem of the blank screen. I also get the
    flickering & bad image quality on start up. In the past I was able
    to just disconnect the power cord at the monitor, count to 10 &
    plug it back it. That would usually fix the blank screen problem.
    Today it wouldn't come back, but MikeCharlie's solution worked. Thanks!
    Still, my monitor is over 3yrs old. Maybe it's time for another one.
    L:)
My monitor (SN517A1108SC1246) has same power on problem issue. This particular monitor was 'repaired' three times by Sceptre all within 4 months starting when 11 months old. The problem seems to occur when the monitor looses AC power completely so I've got mine on an UPS. The "reset" fix by MikeCharlie does work to get it back working. Key is timing, plugging in the power cord then monitor cable just after LED blinks. Tricky but can be done.
I do have another Sceptre X20 (SN505A1108SC2638) on same computer that although a year older, has not had any problems!
Posted on Jan 15, 2008
X20G Fails To Power Up - Soloution Found - 05e19d8.jpg Here is a pic!
Posted on Jan 13, 2008
    Problem Solver:
  • 5 Answers
I have exactly the same problem with my X20G monitor. There is a design problem with the LCD controller board and the Power supply board. The problem is the power sequencing of the power supplies feeding the LCD controller chip. The 2.5V rail has to come on first before any other power rails. Also, some of the power rails don't discharge completely during power down. I was able to fix my X20G by adding a wallmount power supply to feed the 2.5V DC-DC converter input (blue wire) and adding bleeder resistors on two of the power rails on the LCD controller board to discharge it during power down. With this setup, I do the power sequencing by plugging the wallmount power supply first before the plugging the main AC power of the monitor. Only try this fix if you have good knowledge of electronics.
Posted on Jun 23, 2009
I bought my monitor in the 20 inch Sceptre monitor in November of 07 and it worked fine until about 8 months later. I bought an extended warranty at Microcenter in Dallas and when it started acting up, I took it in. They said they couldn't find anything wrong with it, (even though this seems to be one of the most common problems with these POS Septres) and they told me the typical brain-dead "make sure the outlet you're plugging it into has power" solutions.
A solution I found that worked well for awhile was to keep it plugged into a power surge and NEVER turn it off from the monitor itself, only from the power surge when you turn off your machine. Also, I set the monitor to never turn off in Windows display properties.
That worked for about 4, until I hadn't turned on/off my monitor in about a week. I tried my old tricks (unplugging for about a day then plugging it back in, switching power cords, etc.) and finally I gave up and came to this forum to see if anyone had a solution. Frusterated after plugging and unplugging my monitor for about 15 minutes I laid it screen down on a soft CD case and hit the back of the monitor. I swear to god it turned right back on!!! I'm actually typing on it for the first time in 2 weeks! I wonder how long this will last.....
Suffice it to say, I freaking HATE this monitor and I only bought it cuz it was the brightest, cheapest thing they had at Microcenter. I wouldn't recommend Microcenter or the Sceptre monitor to anyone.
Posted on Feb 11, 2009
I had the same issue with my X20. You will need to disassemble the unit and reset it by touching a wire lead to the white wire on the Microprocessor circuit board (which leads to the button circuit board) to each of the other color leads, one at a time. This should reset it and you will see the red leds lit. You will need to do this while AC is connected! Be careful.
Posted on Oct 01, 2012
I just changed the eight 470uf 25v capacitors on the power supply and the unit came back to life.
pretty easy job took 1/2 hour.
Posted on Oct 14, 2009
I have two of them, Both do it
Posted on Nov 25, 2008
I just got this monitor. where is the on/off button
It looks like the button on the far right on the front panel is the power button (highlighted in picture below).
(Original picture from http://www.sceptre.com/)
Jan 31, 2014 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
My sceptre X20G-Naga II , it doesn't turn on, the fusible is good, one of the 2 small led's in the usb board is flashing but low intensity . Do you know about this problem?
Do the caps look OK at least with no leaking/bulging tops. Do you have +5vdc for the logic bd and 12~18vdc for the backlight inverter circuits, those are the first to check. You need to have +5vdc for the set to turn on.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 30, 2010 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
I have a sceptre x20g naga III screen goes blank
if you have the warranty, return it and get a new one free. ok
Feb 19, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre X22 Naga Will not power up.
Start looking at the power supply for bad caps, see some example of a couple yeras old monitors that failed due to cheap caps being used: http://s807.photobucket.com/home/budm/allalbums
Jan 08, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre X20G Naga II 20.1" Widescreen monitor
I am working on one of these for a customer. Found leaky cap on 5 volt power supply. replaced it, still no backlight. Looked at the inverter with an o-scope and it runs for a few seconds then shuts off. I hooked a ccfl across each of the transformer secondaries on the inverter and it lit up! I believe the problem is failed ccfl units. There is plenty of voltage there to light them up, I have an rf burn on my thumb to show for it. I have not looked at the ease of dis-assembly of the display to replace the backlights. It does not look easy.
Oct 22, 2008 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
X20G-Naga III screen goes blank after 1-2 secs
FIXED!
Device : Spectra X20WG-Naga
Problem : monitor comes on then flickers then goes off
solution: Replace Capacitor C101 (150uf, 35V) and Fets U101 and U102 (4511GM)
Comments: This is a common problem with this monitor.
I’m happy to help further over the phone at https://www.6ya.com/expert/paul_0af9b1d5c0eb4fc3
Oct 02, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
ACER AL 1912 Colors bad screen shakes
your asking which part you want to replace. try first to check all the connections.
Jan 02, 2008 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
Sceptre X20G-Naga II 20.1" Flat Panel LCD Monitor Logo
1,242 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
