Question about HP DeskJet F380 All-In-One Printer
When I try to print, nothing happens. The printer status is "offline", though I don't know how that happened or how to switch it back. When I turn it off/on, it doesn't change anything.
  • kate1982 Dec 12, 2008
    same issue
  • 236 Answers
Go to Start | Printers & Faxes
Right-Click on your printer and choose Use Online or unpause
Posted on Dec 08, 2008
Print jobs are completed with no problems sometimes, other times the print queue shows the job being printed, but nothing happens. Printer status shows "offline", but if I click on the...
Reason behind "offline" is communication between printer & system got interrupted,check weather printer is restarting it self ? check with another USB cable,check firm ware if low version up load it, check printer USB port on formatter is it dry solder? if no check the voltage in connector 17, between pin 1 & 20 is it 5V? if not check power supply connector J201 pin1, is it 5V? if not replace Power supply PCA.
If 5V showing between pin 1& 20 replace formatter.
Sep 09, 2011 | HP LaserJet 3050 All-In-One Printer
There's a document in the Hp deskjet f2200 series that i canceled cause the printer didnt print it (of course i clicked the print button) , im canceling it and then the status changed to...
disconnect the usb cable from the printer to computer then turn off the printer, restart the computer then check the pending again if it is empty connect back the printer
Aug 07, 2011 | Office Equipment & Supplies
My HP Officejet 6210 All-in-One printer goes offline whenever I don't use it for about 15-20 minutes, and when I put it back online, nothing happens. Looking at the printer from the control panel, I see...
HP Printers have common behavior of going into sleep mode if not used for a while. If this happens every-time the printer goes to sleep mode and you find printing issue, try this simple step below
Disconnect the power cable from back of printer
While holding the # and 3 button, connect the power cord to printer.
*Note this is partial reset and doing so you may loose fax logs and other fax related setting you have setup on printer.
Click the link below to know how to resolve the print job stuck in queue issue.
Oct 23, 2010 | HP OfficeJet 6210 All-In-One InkJet...
My hp deskjet 3745 wont print because it is off line. how do i get it back on line and for it to stay that way. this happens often.
hello lblb45. Under control panel - printers and faxes - doble click on your HP printer and you will see the status of the printer (either printer offline, out of ink, or out of paper, etc. Click on printer option on the top and unselect the "Use Printer Offline" option. That usually happens because the print spooler service looses connection to the printer at some point. Did you try with another USB cable or reinstall the drivers? I hope this helps.
Jun 03, 2010 | HP Computers & Internet
Printer status offline and will not print.
if you are using windows xp then try this document please this hould fix the problem for you
if still nothing happens try this
hopefuly this should resolve the problem for you
let us know what happened so that we can help you further
Mar 01, 2010 | HP 5510 4-in-one Printer
When trying to print nothing happens just a green
please check ur printer connections
check the printer statuse offline or online keep it online
if its not working please install printer driver
Sep 29, 2009 | Office Equipment & Supplies
Nothing happens when i tried to print from my computer the status is offline what is wrong
same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
Sep 02, 2008 | HP DeskJet F380 All-In-One Printer
How to change "offline" status to "online"
Assuming you are on a PC:
Go to your control panel in Windows, open the printers box, choose your printer by double clicking on it, then click on 'printer' on the left edge of that window. Scroll your mouse down to where it says 'use printer offline' and uncheck that option. This should release any documents you have waiting in the queue.
you will also need to check your manual on how to set its sleep function, as some printers like to go to sleep really quickly - and that causes Windows to think it is offline.
May 21, 2008 | HP PhotoSmart C4280 Laser Printer
Compaq a3000 all-in-one printer
try new drivers..stranger things happen with printer drivers..should be able find them here, under hp
Mar 16, 2008 | Compaq A3000 All-In-One InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
300 people viewed this question
Ben Johnson
