Question about Beyond Micro MobileDisk 500GB 3.5 External - 7200, 8MB, eSATA, USB 2.0 500 GB Hard Drive
My "Beyond Micro external eSata Drive has stopped spinning up
500G drive stopped spinning up and fan is not working, it was part of raid and the other drive is still working. Is there anything i can do to re-start this unit or is it possible to buy a different drive with the same specs to replace it?
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
Cant open files in seagate drive
The first thing to do is to remove all the connections and re-insert them. Power and USB are the usual connections. You might try eSATA if you have the module. This is an old drive and even with only infrequent use, due to the lack of cooling on the drive, these will have an early failure. If you put your ear really close to the drive, do you hear a spin/stop/spin/stop sequence. Like the drive is spinning up and then stopping over an over? If so, that may indicate a crashed drive. Do you hear another noise or no noise at all?
Jul 30, 2014 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Driver window7 bm160md3u28m
You shouldn't need a driver for this. Windows 7 should detect it and be ready to go. Are you sure the power cord for the drive is working? Put your ear close to the drive and plug it in and listen to see if you can hear it "spin-up". It doesn't appear that Beyond Micro is even in business anymore.
Jun 01, 2012 | Beyond Micro Mobile / 160GB / 7200 / 8MB /...
My fabrik simpltech 500g hd doesnt work on anything but my macbook, is it locked?
If it's formated under MAC OS, windows will never see partitions on your hdd.
Dec 25, 2011 | SimpleTech 500GB SimpleDrive Pro External...
Beyond Micro BMMDU2 250 GB external hard drive not working
It is highly unlikely that it will work. A circuit board from the same make and model hard drive would be a better choice, but I think a fire damaged hard drive would not work with a functioning circuit board. It depends upon how much heat the hard drive was subject to.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their services. Depending upon how valuable your data is, I suggest you get a quote first.
Apr 01, 2010 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
The hard drive fell over and now it wont stop making alarm noises and it wont work
I'm afraid the disk got damaged internally. If it was set to RAID 0 mode (speed), at least half, possibly all data is probably lost.
If it was set to RAID 1 (safe) mode, maybe the data can be recovered. It's not very likely, I'm afraid, because in this case the drive would make noises but would also work. I fear you had two 512 Gb disks configured as RAID 0. For RAID 1, it is sufficient to open the enclosure - it has three small screws on the side - and unscrew the four internal screws holding the drive caddy. Extract the caddy, unscrew both hard disks, and try connecting them, one at a time, to an external SATA to USB adaptor (Kraun makes a very handy USB to SATA-EIDE3.5-EIDE2.5 adaptor with external AC, but many exist).
In RAID 1, one of the disks might be detected and work (of course, both could have been damaged, but that would be real bad luck).
In RAID 0, sometimes it is possible to partially recover one of the disks (with half the data). It takes lots of luck, not all RAID 0 enclosures support this.
If you can't recover the disks easily (the RAID 1 trick is almost immediate), I'm afraid your only option is a data recovery service :-(
Nov 04, 2009 | SimpleTech 1TB SimpleDrive Pro Duo...
Didn't come with drives so now I need setrup raid
It looks as if this unit comes with raid pre-installed and does not have any downloadable software for it. One option would be to research Windows Software Raid which would be a "free" option.
Nov 03, 2009 | SimpleTech 1TB SimpleDrive Pro Duo...
Computer does not recongnize connection
External is damanged or you have problem with USB drivers...
May 10, 2009 | Beyond Micro MobileDisk 500GB 3.5 External...
RAID 0 on Asus motherboard
Hi macjax,
I agree Asus wasn't using their noodle when they came up with that one. With the JMicron Controller your sort of forced to use an external for raid. But getting another Raid controller is simple. I like High Point Rocket Raid, and it's simple to install and setup. HERE's a link to there site. The main reason that they should be using an external is for hotswapability. But for some reason JMicron wanted to allow for more drives. Can you image having for external drives!!! Crazy.
Anyway, if you get another controller card, you'll go through needing to load the drivers and change Bios to accept them, and at the same time you can disconnect the JMicron raid. As far as speed is concerned, you're still on the SATA platform, I find no difference on speed unless you have two drives of different sizes.
Good Luck
Mark
Please provide a rating based on this solution.
Thanks
Mar 28, 2009 | ASUS Computers & Internet
SATA Raid card on PCI unable to detect eSATA Hard Drive
if you install the raid controller drive,it means it will shown the drives..but it not shown? is this what you mean? did you try to see in the computer management? if you dont know, check this out..right click my computer-manage-select disk management and check if your drive is there......this is only what i know about what you mean.
Mar 03, 2009 | Intel Motherboard
External hard drives not recognized by MacBook Pro using SIIG eSATA II 2 Port ExpressCard-M
I am having the same issue wd external drive on my mac book pro and also a seagate
they both work intermediately on a firewire
Jan 17, 2008 | Computers & Internet
Beyond Micro MobileDisk 500GB 3.5 External - 7200, 8MB, eSATA, USB 2.0 500 GB Hard Drive Logo
64 people viewed this question
Top Beyond Computers & Internet Experts
terminalcon
richie46
James Grady
Level 1 Expert
Are you a Beyond Computer and Internet Expert? Answer questions, earn points and help others
