Question about Casio Parts Cash Register PC Desktop
My cash register is not printing.
The paper ran out, while doing a sale. I changed the paper roll. and tried to re-enter the sale and nothing prints. It has no error code on it.
  • artist830 Dec 08, 2008
    I got it to work thanks, i had the wrong paper in there.
  • 45 Answers
If it is a thermal printer, make sure you are using Thermal till rolls,
2nd have you fitted the till roll in the correct way, Going through the printer (past the platen)
Posted on Dec 08, 2008
  • 737 Answers
Hi.
If it is a thermal printer, make sure you have the paper coming from the bottom of the roll, not the top. If you have the paper the wrong way around, it will come out blank.
If this is not the problem, please let me know the model number and any other information you can give.
Mark
  • ahwaldick Aug 02, 2011
    I have a Casio PCR-275 and it is not printing even though the paper is correct, the printer is fine and ink is still good. Any Suggestions?
How to change paper
This product uses 2 1/4in (57/58mm) wide standard thermal paper. Use the feed keys only when changing the paper. Do not pull the paper manually.
1. If prompted during use, or when setting up the printer for the first time, open the printer compartment by lifting up on the tabs located toward the back of the register. This will expose the printers.
2. Depending on each sides needs, use the release buttons to open the paper wells and release the print rollers.
3. Place the paper rolls into the paper well so it feeds from the bottom of the roll towards the front of the cash register (not the back). Pull the paper up and past the print heads towards the front of the cash register.
4. Once done, close the printer arms and use the feed keys to advance the paper.
5. To attach the journal roll to the back of the winding wheel, remove the wheel from the comparment. Put a small fold in the end of the journal roll and feed it under and around the tabs located on the wheel. Spin the wheel manually to take up paper slack.
6. Once the paper is attached, place the wheel into the holder in the back of the printer compartment. The part of the winding wheel with two discs should be on the right side.
Dec 23, 2015 | Royal 29445B Alpha 9500ML Cash Register
My shape XE-A207 cash register won't roll out the receipt paper when a sale is made. It is trying to print a receipt but the paper isn't rolling out.
Usually a broken feed gear in the printer. If you can hear the feed motor whirring but no paper movement, it probably needs a new printer.
Sep 07, 2015 | Retail Supplies
I change the paper and now it wont print what do i do?
samer650 requires 2 1\4 thermal paper to work. make sure the paper you are using is thermal...also it is only thermal coated on one side so try it upside down if it still won't work.
Phil
Jul 10, 2014 | Samsung SAM4s ER-650 Cash Register
Till roll re-placement not printing
Try turning paper around or make sure you have thermal paper if it is a thermal printer model
Jun 18, 2014 | Casio Parts Cash Register PC Desktop
How do I get the register to print everything that is rung up?
It may be possible that your macghine is in training mode. Just remove the batterries blow the paper roll and plug it off for about 5 mins and put them back then plug it on
May 15, 2014 | Royal Cash Register 500dx
Not printing
You cash register may use thermal paper (not ink). Try using thermal paper rolls.
Apr 12, 2014 | Retail Supplies
Till roll print says power fail. cannot open the cash draw.
The power has been turned of before the sale was finished. Make sure it has a new roll of paper in the printer, then turn key to PGM and switch the power off. Hold down the SUBT key while you turn on the power - display will say INITIAL or something similar. Turn key back to R and see if it works.
Dec 23, 2013 | Samsung SAM4s ER-650 Cash Register
Cash register not printing
your paper is up side down. try the other side
Nov 23, 2013 | Computers & Internet
My casio PCR -T2000 won't print receipt paper. The paper is not moving. There is no error on the screen. There is no jam. It is the correct thermal paper. I've tried turning power off and on and...
You haven't mentioned the journal roll, so I will assume it prints the journal but not the receipt. What happens if you press the post receipt button at the end of a sale. Does it print daily reports on both rolls? --------------------------------------------------------------------
If anyone needs a Casio PCR-T2000 manual, C-tech collective have it here: http://the-checkout-tech.com/manuals/cashregisters/Casio3.php
Jul 25, 2011 | Casio Parts Cash Register PC Desktop
Sharp Electric Cash Register XE-A203. I just put a new paper roll into the register because it was out of paper. The register screen is showing all numbers and transactions but when the paper comes...
Hi whitwall,
Please make sure that you have the right paper roll.
Your machine takes a thermal paper roll, which means it actually burns the print into the surface of the paper as opposed to printing with a ribbon or ink roller like other makes.
The thermal paper will only show a print on one side of the paper, in other words if you do indeed have the right roll and it is in upside down you will get a blank printout.
An easy way to see if it is the right paper hold the roll in your one hand and scratch a line with the thumb nail of your other hand accross the surface of the roll,if you get a black line on the paper then it is the right one, otherwise you have what we call a "bond" paper roll and it will not work in your machine.
If you got the "black line" with your thumb nail, then lift the printer head arm (green lever) place the roll in position with the paper rolling out from the bottom of the roll towards the front of the machine, pull the paper out past the catch mechanism and close the printer ****.Tear off the excess paper and replace the printer cover.
You should be ready to go ahead with sales.
This should solve the problem .
Regards
Gavin.
Oct 16, 2008 | Sharp Office Equipment & Supplies
Casio Parts Cash Register PC Desktop Logo
247 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
