Question about Dryers
Need to replace the motor on my 90 series Kenmore electric dryer. How do I get into this area where the motor is located?
SOURCE: motor removal and replacement on a kenmore electric dryer 90 series model# 110.86984110
remove screw at each end of console. pull & flip back out of way. remove top, remove bottom panel, slide putty knife to release both retainer clips. remove screws to remove door panel assy. remove belt, remove drum. remove motor clamps & remove wires from motor conector.good luck.
Posted on Aug 07, 2008
SOURCE: my kenmore series 90 electric
FOLLOW GAS LINE ON DRYER may have a switch to allow gas into the unit then check outlet at wall to make sure it is getting fuel
Posted on Sep 21, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore 90 Series ~ Model
The following link explains the dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Make sure you perform all component checks with the dryer UNPLUGGED. Dangerous voltages are still present inside a dryer even with the unit turned off.
Pay particular attention to the paragraph that discusses proper dryer ventilation. Most dryer heat related problems are attributed to poor ventilation that leads to dryer overheating to the point of failure. If you can't remember the last time you had your ventilation checked or cleaned, I would recommend you do so before replacing any failed components. Failure to do so may result in undesired drying results and premature failure of any components you have replaced.
The most common cause of dryer heat failure is a blown thermal cut-out (TCO). This component acts as a fuse and will blow when an overheat condition occurs. If it is determined that the TCO is bad, it is strongly recommended that you replace the hi-limit thermostat at the same time. Failure to do so may result in premature failure of replaced components. In many cases, the manufacturer sells these parts as a set (more cost effective to purchase this way, too). Both these components are located on the heater box adjacent to the heating element.
To access, remove the lower panel under the dryer door. This is accomplished by inserting a putty knife along the seam at the top of the panel about two inches in from each side. There is a retaining clip that needs to be depressed to release the panel. With the panel removed, the heating circuits are located on the right hand side under the drum. You can view drawings of your dryer at searspartsdirect.com by entering your model number. Use model number "110.66912690" for your search criteria. The heating circuits are listed under the "Bulkhead" heading. The heating element is listed as item number 14. The thermal cut-out is listed as item 47 and the hi-limit thermostat is item 48. NOTE: You can find the TCO and hi-limit thermostat sold as a set at appliancepartspros.com as part number AP3094224 (Your Kenmore dryer is manufactured by Whirlpool). This could save you some $ if one of these components is your problem.
If you have questions along the way, or require additional assistance, please let me know. I hope this helps you.
Posted on Jan 13, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you still have questions, please let me know. I hope this helps you.
Posted on Feb 27, 2009
TheMobilian
  • 8220 Answers
SOURCE: kenmore dryer- remove fan to change motor on
The wheel has left handed threads. Use an impact wrench and an adjustable wrench to get it off or get a vice grips or pipe wrncha nd lock down the shaft then get a stick of wood or a hammer handle and shove it in between two fins at the 3 oclock position. Slam downwards on the wheel and it should pop loose.
Posted on Mar 22, 2009
Need help with gas dryer Kenmore 90 series serial
Check the lint caught in the exhaust vents. If it is clear replace the spark ignitor if no click is hear upon starting up
May 14, 2010 | Kenmore 73952 Gas Dryer
Kenmore dryer- remove fan to change motor on dryer.Do I need a gear puller to remove ? 7 yr old 90 series dryer ,seal drum came lose from damage to dryer when purchased. Did not relize damage until motor...
Mar 22, 2009 | Kenmore 659 Electric Dryer
Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Jan 15, 2009 | Zanussi TC7102W Electric Dryer
Kenmore dryer replaced heting element now it does not blow any air
HI danon this dryer its common to have the blower wear out, it slides on the motor shaft, and what they do is wear out the flat in the blower. that could have caused the element to fail. check the blower thanks the appliance doc. please rate my answer. thanks
Sep 30, 2008 | Kenmore 62602 Electric Dryer
Kenmore 90 Series Electric Dryer won't start
Hi.Thanks for the question I would look to see if the belt is ok.Some dryers have a belt break switch, which is located by the motor.I would check the door switch.on the door try that thanks
Sep 29, 2008 | Kenmore Elite HE4 Electric Dryer
Motor removal and replacement on a kenmore electric dryer 90 series model# 110.86984110
Aug 07, 2008 | Dryers
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Kenmore 90 Plus Series Electric Dryer trip
It sounds like the motor switch which is actually inside the motor on the model. It is very expensive to replace motor so it may not be worth fixing......
Although I stick to the above statement; I have seen cases where a thermal fuse wire has come loose and perhaps sometimes touching(allowing heat) and sometimes not(hitting something blowing the breaker.... Check all wires on blower vent area... GOODLUCK!!!
Dec 17, 2007 | Dryers
Dryers Logo
Top Dryers Experts
