Question about Tascam 2488 Portastudio Multitrack Recorder System
Annoying buzz produced from all monitor/line-out jacks
I bought a used (though claimed to be untouched) 2488 about a month ago, and me and my guitarist have been trying to figure out how to eliminate a buzz that comes out of our monitor source no matter which output we use. We've tried a couple power amps (an older Sony and a newer Pioneer) and both of them buzz. I don't believe it comes from within the machine because headphones are completely silent. Anyone know how to get rid of this or where I should send the machine to fix it, or is this beyond repair?!
  • therippah Dec 11, 2008
    Thanks for the suggestion, but the buzz is created without recording anything. If I play the Tascam demo track or play a CD through the CD drive the buzz is still there unless I listen with headphones. I know it's not the RCA cables or the power amp because I've tried different cables, two different power amps, and the kicker is that if I use my guitarist's Boss BR-8 recorder there is no buzz through the output.
Hi, you have a bad cord on one of your instruments. Its that or you have a bad instrument connection. Same thing happened to me. Switch cords until you find the noisy one.
Posted on Dec 11, 2008
Connecting aux send on Tscam 2488 to input of TC Voiceworks
A 1/4 inch short instrument (mono) cable between the AUX unbalanced 2488 and the 1/4 inch of the Voiceworks should work. Operate ALL the equipment from the same power source to avoid ground loops.
You will lose 3 Db since you will only be driving one side of the balanced VW input, but there is plenty of gain. The sleeve of the mono into the VW will ground the - balanced input of the VW. The connection is absolutely safe. Should you encounter noise on the connection, use an isolation device like a DI and use ground lift with the 2488 into the mono jack of the DI and XLR out of DI into the VW. I think you will find this unecessary though in your use.
Jul 21, 2010 | Tascam 2488mkii 24 Track Recording...
Turtle Beach x1's make an annoying beeping noise
If you're using the Play n Charge kit, then you might be hearing some buzz/whine through the USB power. Use the X1 without the Play n Charge. Does that help?
If you unplug the chat-controller cable from the X1 volume control box, can you now hear shots and explosions without the annoying beeping/buzzing noise? If so, then you may have a bad chat-controller cable, and you should have it replaced.
Mar 05, 2010 | Voyetra Turtle Beach Ear Force X1 Headset
Shade difference in lg lcd diaplay
Based on your description, it appears that the monitor is faulty. Since it is only a week old, you should have no problem exchanging it.
Aug 22, 2009 | LG L1915S 19" LCD Monitor
Modifing the Tascam 2488 for external display
Check out
www.hgr2488.co.uk
They sell a module to install in the tascam. Works really well.
Jun 02, 2009 | Tascam 2488 Portastudio Multitrack...
Plugging in keyboard
MIDI only carries digital information, not audio. Midi is used to communicate patch settings and note value information. If you want the recording to know the note value, then you should use midi. This is useful if you want to do things like adding rythm tracks, etc.
If your keyboard has audio/line out (as opposed to headphone out), use that, as it is matched much better in impedance. If it doesn't have audio/line out, then you can use the headphone jack, but you will have to turn the attenuation way down because the headphone jack impedance is much higher. This will tend to distort on the recording if you are not careful.
The first thing to know about digital recording is that distortion is much more of a problem. I won't get into the theory of this, just know that impedance mismatching is more of a problem with digital.
Sep 08, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio screen.
You could add an HGR monitor interface module to display the 2488 on a PC monitor.
www.hgr2488.co.uk
That way you don't need to look at a damaged display and the 2488 (MK1, MKII and NEO) work just like before.
Aug 31, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488
Repartition and format the hard drive. There are specific instructions elsewhere on the Internet. I did this about six months ago. I believe my problem came about after I stored my 2488 on top of my monitors - I believe the exposure to the magnetic fields corrupted the boot partition on the drive.
Apr 10, 2008 | Tascam 2488 Portastudio Multitrack...
2488 Mk 1.
Hi Mike,
To reset the 2488 to factory defaults: Simultaneously press quick routing/shift/send/shutdown & turn on the unit.
The 'stop' button problem may require a look under the cover to see if the button is dirty or damaged under there. A good cleaning might do it. As for the 'no guitar out the monitors' issue, this sounds like it might have something to do with the setting of the monitor selector. Make sure it's set to 'stereo' and not effect loop or effect send or even muted. You might want to also make sure your monitor level pot is working properly.
Best of luck.
D.
Feb 20, 2008 | Tascam 2488 Portastudio Multitrack...
Good picture for 30 seconds then screen goes black with a faint ghost of the image
the 12V is for speakers.. the 245bw takes regular 120V AC (same cord as your computer)
the buzzing is annoying, though. i don't know if it's a "feature" or just a side effect.. ie, if i could take the case off and poke around, i would. 4 times out of 5 it's some dumb piece of tin reverberating from a transformer or something..
Dec 03, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Tascam 2488 Portastudio Multitrack Recorder System Logo
109 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
