Question about Cobra 29 LTD CB Radio
Cobra 29 nw
Will not transmit ,pa works the and antenna is fine checked with a good radio also lite works
    Guru:
  • 773 Answers
Yes, sounds like the final is blown. If you are not sure about what you are doing in the radio, you can take it to a radio shop. they are usually at truck stops.
Posted on Apr 25, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls check the final and pre-final (TR15 & 15) and that it gets modulated TX+12 through D8 from T1 which in turn is the output of IC4 through C48.
Perhaps a schematic diagram may be of further help.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 18, 2008
My cobra 29ltd will transmit but want receive
three things you need to check the mic must be plug into radio, make sure that the radio is set to cb not pa,check your rf gain is turned all the way up and last of all check the antenna.Now that being said if the radio does not receive you might have to take it to a radio shop.
Jun 11, 2014 | Cobra 29 LTD CB Radio
My radio just recently incurred this problem. It receives WX band, uses PA correctly (mic transmits over PA). It will not receive or broadcast over any standard CB channel (1-40). The needle is just...
Hi, do you have the switch in CB mode ? Might be the audio chip, or the Finals, you will need a tech to do the job so he can set the ma on the finals. Hope this was helpful....My name is John. Thanks....good luck...
Aug 28, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
29 cobra ltd c.b. wont transmit or receive. mic antenna coax are good
make sure the RF gain is all the way up, and the dynamic is all the way up or most of the way up.
When you say the antenna is good, have you checked the SWR's and or have tuned the antenna to be the correct length for the radio? If this has not been done ever, your radio could be a brick.
Also, make sure the PA/CB switch is on CB. if its on PA(public address) it will not receive or transmit because it is on PA mode, which if you have one hooked up, a PA speaker, then you can talk to people through it out side your car.
Also, make sure the S/RF SWR CAL switch, its the first one on the left, is all the way up on S/RF. this is your signal/ receive setting for the meter. When you hold the key, does this needle swing forward? As well does the RX/TX light turn red? If it does, then the radio is transmitting.
There is another light on the radio under the TX/RX light. It is the Antenna warning light. If this light comes on when you transmit, or has come on all the time during transmit, and now it doesn't then the radio is a brick. That is a warning light. It means that the antenna is not matched, or has not been tuned to the radio. If this has not been done ever, you have killed the radio.
Here is why. When you transmit, you are sending off a radio wave. This radio wave, at 27mhz, is about 36 feet long. In order for the wave to radiate off the antenna, the length of the antenna has to match the length of the radio wave. Now it does not have to be a full 36 feet. It can be an exact multiple of 36 feet. In other words it can be 1/4( one quarter) or 5/8(five eights) of a wave in length. 1/4 of a wave is 108 inches, or 9 feet long. Your antenna is still probably does not seem 9 feet long, but there is usually a loading coil that is not exposed making up the rest of the length of antenna, so that it matches the length of the radio waves electrically. If you were to stretch the coil out with the antenna whip, it would be 9 feet long.
When the antenna does not match the wave length, part of the RF energy does not leave the antenna, and goes back down the feed line(coax) and hits the transmit transistor. Prolonged reflection to the transmit transistor, otherwise known as the final will blow it out. As well depending on how bad the length was off, the more off, the more reflect energy, the more RF energy you are blasting back into the radio, and this causes more things then just the transmit to blow out. Some time the receive goes along with it when it finally goes.
So if the RF gain is up all the way, which by the way is basically how much receive you have, and there really is no reason to have it down at all, and the CB/PA switch is on CB and the needle does not swing forward when its on the S/RF setting, chances are that the radio is now no good.
It is fixable, but if there are no CB shops near you then you will have to send it out. And Cobra will not cover this under warranty because its stated in their warranty that they do not cover damage due to high SWR.
Apr 06, 2010 | Cobra 29 LTD CB Radio
I have a cobra 29 nw ltd classic i cannot hear or be heared
Start with the antenna that you have hooked to it, is it grounded, is the coax in good shape, is the connector in good shape. stuff like that.
Jun 14, 2009 | Cobra 29 LTD CB Radio
Cobra 29 wx st
IF YOU CAN RECIEVE THAT IS A VERY GOOD SIGN THAT YOUR SWR MATCH IS OFF....I DONT KNOW IF YOU MATCHED UP YOUR RADIO WITH YOUR ANT.IF NOT YOU CAN BUY A CHEAP SWR METER @ RADIO SHACK...CHECK THAT YOUR COAX CABLE IS OK TRY TO REPLACE THE COAX......GOOD LUCK
Feb 14, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 nw ltd won't transmit
Have you cracked the radio open yet?  check for loose connections etc.  get back to me if that doesnt yeild any results
Dec 23, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD Classic not transmitting or receiving
ant. light should only come on if you have a high vswr a bad thing did you check that cb/pa switch is set to cb check your swr this is not a good place to mount ant. as it is close to metal of back of cab
Dec 20, 2008 | Cobra 29 LTD CB Radio
As I understand from a tech friend of mine, most truck beds are not grounded well enough. Perhaps you could borrow/purchase a magnet mount antenna and locate it on the roof, for testing. Then you would have it narrowed down to the location.
Dec 05, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
208 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Iron
Iron
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
