DTI program liberary when recording is actioned causes set to fr
My Thomson DTI, when on progam liberary will not play back any listed recording and if any action (ie curser move up or down) is taken the whole dti freezes and has to be switched off for 10 minutes. Is there a reset button anywhere on the set to cancel all recordings
Phoned the manufactures and got a replacement set
Posted on Dec 09, 2008
THOMSON DTI 6021. I NEED REMOTE CODES
0183,0188. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Jun 17, 2015 | Thomson Televison & Video
Playback of Topup TV Sky / ESPN Recordings
I am just guessing but you may have an ant-copy signal embedded into program signal causing to when you are trying to look at a recording to another source. If that is the case then there is one way that would work. You need to connect inline with the video line out to the in of the other unit (yellow) and that would solve the problem. Go to xdimax.com and check out a dimax signal adaptor( can not recall what it goes by,description-wise) This is almost like trying to use a hdmi output and a audio/video connection at the same time.This also happened when doing the same with some video decks (vcr)
Sep 02, 2017 | Thomson Televison & Video
Freeview box thomson dvb 160 need remote digi code 2 marry up with digitrex tv
free view magic box when trying to set program recording it sometimes says cant perform this action code 2 what is code 2
Sep 15, 2010 | Televison & Video
Hi, Please can someone help? I can not find my manual for my Thomson DTI 6300 does anyone have the codes for a toshiba tv?
0538 0090 1538 0065 1319 0066 0100 0132 0744 0271 0247 0139 0225 0221 0648 1938 0039 0067 1194 1193 0748
These are the list of codes to try for your toshiba tv for connection to thomsoo dti 6300.
Hope i`ve helped
Dec 04, 2009 | Televison & Video
Thomson DTI1000 DV3 STB
since switch over I cannot get any progammes everything is connected OK ,rechecked aerial connection with another digibox thats Ok all I get is a blue screen . Can anyone help ?
It is a Thomson DTI 1000 DV3 model
Nov 11, 2009 | Televison & Video
Thompson DTI 6300 16 Red light all the time
hi
The solution has been listed as a Samsung recorder rather than the Thomson listed above
regards
manby
May 18, 2009 | Samsung HDTV Digital Terrestrial Receiver
Thomson Digital TV Recorder DTI 6300-16 volume control
The manual is not very clear.
The volume control will work after entering the code for your TV make.
Press TV
Press AV and OK together and wait. The TV button will flash twice eventually.
then using the numeric keypad enter the code ie 0680 for Panasonic,
a list was provided with your instructions.
On entering the code the TV button will flash twice again t confirm.
Now the volume of the TV can be controllled using the buttons on the Thomson remote.
Teletext and other functions like "mute" are now present.
peterh
Dec 25, 2008 | Televison & Video
Thomson DTI 6300 Digital TV Recorder freezes
try this forum http://kafkasworld.com/phpBB2/ they have tons of stuff on thomson dtis
Dec 08, 2008 | Televison & Video
User manual needed
remove power at plug socket
when you plug power back in start to repeatedly press the standby button on the front of the box
when this causes the orange light to stop flashing press the buttons up, down, left, right
(these buttons are on the front of the box not the remote)
this causes the hard drive to reset itself
WARNING
this will cause the box to completely reformat meaning you will loose all data recorded
but after this reset the box will work as new
Dec 01, 2008 | Arris DCT2608
Thomson dti 6300 16 top tv version box tuner works but programe lbrary where recordingd are available has frozen cannot access or delete
Hi! This is not a great solution and a bit long winded, but aimed at those who've lost the receipt! Start by recording a new programme - the box should still record. Now the corrupt recording is not the first one in the library. When you press library now, all appears to be well. You can find which is the corrupt recording by scrolling down slowly. The corrupt one should be the one with no thumbnail picture (plus it'll be the one that freezes the box up again!). Restart the box agan and press library. If you have recordings before the corrupt one you should be able to scroll very quickly past it and delete them now. Now the corrupt programme is at the bottom of the library list - you can't delete it but at least you can avoid it now...
Like I said far from ideal, but it works on mine. Still no word from Thomson. Hope this helps.
Apr 27, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
