Question about Lexmark X5495 Printer
Have a error message left cartridge incorrect
We moved our computer and printer to a new house. Everything worked fine prior to the move. After we set up the computer and printer a message came up "left cartridge incorrect." This printer has rarely been used and it only about 6 months old. There was no need to change the cartridge and we have not changed the cartridge.
    Problem Solver:
  • 8 Answers
Hey!
Are you using Jet Tec ML32 Cartridge re-manufactured cartridges or genuine Lexmark Cartridge?
If it is the Jet Tec cartridge then it is known to be faulty - purchase a Lexmark cardridge and you should be fine.
If it is the Lexmark Cardridge then I would recommend taking all of the cartridges out, turning the printer off (from the power), turning it back on, inserting the cartridges again and checking if it works.
If none of the solutions work, then your cartridge is damaged and should be replaced.
Cheers,
Matt Newelski
Posted on Dec 08, 2008
I replaced the black in cartridge on a Canon MP620 with a non-OEM cartridge. Everything seems to work fine, bu I keep getting a message that the cartridge is empty. I moved the chip from the original...
When you moved the original chip to the new cartridge, the chip is saying the cartridge is empty. Try removing the chip and the printer should know the cartridge is not empty, but might give you a message that it is not a genuine Canon cartridge.
Fred
May 09, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Canon Pixma MP600 - Error Message U052 ... incorrect print head
Hi, sounds like you need new printhead, take a look on amazon for replacement Amazon com canon mp600 printhead I hope this was helpful. Cheers
Nov 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Hi, I have a Lexmark X7170 Multi-function printer/copier/scanner and it is showing an error message "left cartridge incorrect". I have not charged the cartridges and I have tried to re-align it. Any ideas?
it means your left cartiridge got some problem, might be it got short and you have to replace that.
try this remove your left cartiridge and then try to print if it work then its clear that your aother cartiridge is gone and you need to change it.
Oct 04, 2009 | Lexmark X7170 All-In-One InkJet Printer
Error message after installing new tonner
Check the little switch/door on the left hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Oct 30, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
6A00 Service Error
Had this error and did the following to solve the problem.
Turn the printer off.
Open the top cover and move the printer cartridge to the left.
On the right you can see a white part.
Press it down.
Turn the printer on.
Sep 15, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Toner sensor error after replacing cartrige...
Hopefully this will clear up a little confusion I had:
1. Follow instructions for replacing toner cartridge.
2. Remove drum from printer. Take care not to handle the drum surface. Look for a small rectangular window or depression. The window will be completely or partially blocked by a flap.
3. Use a fine pointed instrument to move the flap up, so that the sensor underneath is visible.
4. Replace the drum. The error should clear after the print engine has reset.
Sep 09, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
Dell 942 carrier jam
This morning I replaced the cartridges in the Dell 942 printer, they jammed to the left which made a loud grinding noise and the cartridge jam error came on.
I solved the problem by turning the printer on with the top up which moved the cartridges to the right a little so I could reach back, push one down a little manually which freed them to move over to the middle.
Feb 28, 2008 | Dell 942 All-In-One InkJet Printer
Lexmark P4350 AIO incorrectly identifies cartridges, will not allow printing
Some times refilled cartridges works fine,and in Lexmark cartridges
they do not support refilled onces ,Try a new compatible cartridge it should print ..
Feb 12, 2008 | Lexmark P4350 All-In-One InkJet Printer
Resetting Toner count onprint settings PRINT SETTINGS report
I don't suggest refilling cartridges as I work on printers every day but seems to me that you have done everything correctly the only thing I think you have done is either filled with incorrect toner thus giving a incorrect reading or when moving gear you have dislodged the pin that activates the reset procedure.
Thanks J
Jan 14, 2008 | Brother HL-2040 Laser Printer
Lexmark X5495 Printer Logo
480 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
