Question about Lionel Fastrack O36 Manual Right Hand Switch 612018
Lionel 027 Right-Hand Manual Switch - I am trying to add both a right hand and left hand manual switch to a track layout but am unable to connect the "switch" piece to the track because there is no room for the pins to into the "switch". Any suggestions?
SOURCE: I accidentially broke the signal flags off my sons
My son broke his off as well. We had just added the outer loop expansion pack and it was broken within 10 minutes. I found the replacement part on the Lionel website after much difficulty. I plan to buy a replacement to use one day when we have a more permanent track layout. I removed the flag from the other switch for safe keeping while he continues to play with it on the carpet. This is very poor design by Lionel. I think they should include a replacement part with the switch, or at least provide instructions in the manual for ordering a new part. I have wasted several hours today instead of enjoying the train with my son.
6102017094 RED SIG/LVR ASSY-MAN 036 FT SW $4.00
Posted on Dec 20, 2010
  • 16614 Answers
SOURCE: I have 6 each 027
Are the trucks on the cars metal or plastic? This appears to be shielding problem on the solenoid. What is the voltage on the system? Put a regular magnet near the switch and see if it stops
Posted on Jan 18, 2011
SOURCE: need track layout instructions for
Need track layout instructions for Take along Thomas & Friends 75pc w/ cranky
Posted on Apr 06, 2011
  • 38 Answers
SOURCE: Ι've just joined 2 ovals
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Posted on Jul 23, 2011
  • 40 Answers
You must use an insulation pin on the 2 inside rails. These are the 2 rails extending from the frog.
Posted on Dec 04, 2013
Wiring 1122 switches for crossover
Question is unclear. But if you want both switches to throw at the same time all you need to do is connect the 3 terminals on one switch with the matching terminals on the other switch. Run a wire from left to left, center to center and right to right. If the switches do not switch into the same track just reverse the right and left wires on one of the switches.
Nov 27, 2013 | Lionel 40 Watt Transformer Train Set Track...
Switches
Make sure you have the insulation pins in place.
Mar 11, 2012 | Lionel 027 Left Hand Remote Control Switch...
I have a pair of vintage 027 remote switches (right & left hand). When I flip the lever on the remotes, the track will only switch in one direction. I can't get it to go back.
First reverse the remote wires and see if the switch track throws in the direction it didn't before. If it does then there is something wrong with the remote switch. If not, then you can wire the switch terminals directly to the power source and turn on the power and see if the switch throws. First do center and right terminals and then center and left terminals. If no sound or buzz the solenoid may be bad. If buzz then see if the rails are stuck and can't move. May need grease.
Jul 30, 2011 | Lionel 027 Left Hand Remote Control Switch...
My 2-8-4 Locomotive stops at the right hand switch and will not reverse. It is the only train of my three that does this
This is a common problem with FasTrack Remotes and Manual switches. It is relative to where the center roller pickup is in relation to the wheels (common connection to outter track rails). Solution is to put electrical tape on the outter rail that forms a V between the turn in and the straight away. This elliminates about 1.5" of track discontinuity. It also eliminates wheel sparking that pits the surface of the outter rail. Wish I had a better solution short of taking the switch apart and doing some rewiring.
Jan 31, 2011 | Lionel Fastrack O36 Manual Right Hand...
I have Lionel Fastrack 048 switch. I extended the controller wire and all of my slices are perfect. The switch operates but the light in the controller does not operate - neither red or green. I checked...
You will need to check continuity of the yellow RSC wire from inside the controller to where it enters the switch connection block. Neither light will work if this wire is broken.
2nd: Lionel quality control is so poor that if that is not the problem, remove the plate from the bottom and make sure the five plugs are firmly in place on the electronic board. Since both green and red do not work it is most likely not the micro switchs but an issue with the circuit board.
Jan 01, 2011 | Lionel Fastrack O36 Manual Right Hand...
I accidentially broke the signal flags off my sons manual switch. The Lionel website is terrible and I can't find any part listing for the switch to order a new piece. Any suggestions?
Nov 27, 2010 | Lionel Fastrack O36 Manual Right Hand...
Whenever a piece of rolling stock sits on any portion of the switch track, the solenoid begins to vibrate. This happens with all 6 of my Lionel 027 switches. How can this be stopped? I sometimes have to...
You must use insulator pins on the inside rails than come off the frog. Also make sure each track after the switch is wired with the same polarity. Keep power to center rail and ground to the same outside rail.
Nov 16, 2010 | Lionel 027 Left Hand Remote Control Switch...
Lionel Fastrack O36 Manual Right Hand Switch 612018 Logo
198 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
