Question about Zebra 170XiIIIPlus Thermal Label Printer
Zebra 170PAX3 not printing the top half of label
I have a Zebra 170PAX3 and it's not printing the top half of the label. I've checked all the setting and calibrated everything, but it only print the bottom half. Thanks for any help.
  • hrjc Dec 08, 2008
    Is there a way that I can install a USB cable to this printer?
  • 54 Answers
If you print a power on test label, see if the print is aligned, id so, use the top of form setttings to get all the print on the label.
As far as a USB, the printer will only take RS232-422,485, and parallel, and you can add the factory Nic card or use an external print server.
Posted on Feb 25, 2009
TLP 2844-Z prints half the label info on half the label
check the label megerments at driver, or reset printer to default settings. you can also print settings direcly from printer without connect with computer, if still doing than, its possible the printhead its faulty. but before replacet please run test after factory default. hope it helps. Paulo.
Mar 28, 2014 | Zebra TLP 2844-Z Thermal Label Printer
2 partial labels being printed on 1 label
most likely to do with sensor --- label has a notch in it it in middle make sure it is clean --- do labels have a hole that align with sensor?
Look at Cleaning printer to locate sensor
Mar 18, 2013 | Zebra QL420 Plus Portable Thermal Barcode...
On the Zebra it was printing 4x13 labels without a problem. However when I tried to print a 4x6 label it still thought there was 4x13 stock in the printer. I played around with the label format size, even...
I think this is more related to the calibration of the label each time you change the new label size. I use ZM400 and your printer should also have the same setting. Under setting, put the When Head Close setting to Calibration. This will let the calibration perform automatically when ever you load a new label size and close the print head. Well 2 label will be lost every time.
Aug 31, 2011 | Zebra 105SL Thermal Label Printer
Using MS Access, I am printing labels to a Zebra 110XiIII printer. The output truncates the label to 2" instead of the 3.5" I have the report page settings saved as. I have been through the setup...
First check printer. Change setting "Print Width" to maximum width, save. Switch off. Hold down pause key while switching on (untill all but power light turns off). the subsequent prints should print across the full width. If this is OK fault is with label format.
If you are using windows printer driver check settings there this can over ride printer settings. If using ZPL the problem is most likely in the label format.
Jul 05, 2011 | Zebra 110XIIII Thermal Label Printer
Losing half of top line when printing
Label definition in printer driver may need adjustment. Try calibrating printer, printer on solid green light, hold down feed key & release after light blinks 4 times, (blinks once, twice, three times then 4 times) Download the Zebra setup utility and use it to configure printer.
Sep 29, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
An extra, blank label prints from a Zebra 2746e.
Check media settings in the printer driver. Check version of printer driver. Zebra printersuse an internal printer driver with their Zebra Designer software (Zdesigner driver) or a ZUD (Zebra Universal Driver) for other windows applications. These drivers can be downloaded directly from the zebra website.
Alternatively you can download the seagull scientific driver and use that instead. (used with bartender program)
Label skipping occurs if the media dimensions are not specified correctly. The important ones are label height, and media setting for type of media.
Perform a media calibration before you go changing settings. Power on printer, Hold top and bottom buttons in on control panel for 5 seconds, release bottom button only then when printer starts feeding labels release top button. When printer finishes press feed button.
Mar 16, 2009 | Zebra 2746e Thermal Printer
Zebra 2488-z
Have you tried cleaning the sensor? It is underneath the labels oppoistethe print head.
Oct 18, 2008 | Zebra LP 2844 Thermal Printer
Zebra TLP2844 Prints Centered and Half the Width
create a word template document with the page size the same size as the label. Set the margins to 0 and fill the label up with text. This should make the printer print right the way over the bale.
Nov 21, 2007 | Zebra Eltron TLP 2844 Thermal Label...
Zebra 170XiIIIPlus Thermal Label Printer Logo
602 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
