Question about Bernina Activa 130
Bobbin thread not picking up
My machine was working fine until recently (when I had to have the foot fixed). I tried it. It started to sew, then the bottom thread knotted up. I changed the needle, cleaned out the bobbin casing, cleaned any dust. It now does not pick up the lower bobbin thread, so I cannot sew.
  • Lindsay Dunseith Mar 11, 2007
    I have solved the problem. I realised that the needle shaft must have moved up slightly when I tried to move the needle from the knotted thread. I noticed that the needle head did not drop low enough for the thread to be caught by the hook in the bobbin area - there are some really good diagrams of this on sewusa.com. I removed the side casing (a screw is on the left side of the machine). There is a small screw on the needle shaft which requires a small torx screwdriver. I loosened this screw slightly and the needle shaft dropped a bit. I carefull lowered the needle into position - I did not mark the shaft, and wanted to make sure that the needle shaft was not too low, otherwise when the needle lowered it would catch on the hook and damage it. It seemed ok, I tightened the screw on the shaft, and so far it seems to be working. Normally I would have taken it to a technician, but for me that would involve driving about 250 kms!!
  • 106 Answers
Glad you managed to fix it yourself, in addition to the 250kms I would guess the cost would have been a lot.
Posted on Apr 01, 2008
Bobbin case jammed when sewing vinyl. Thot thread locked in bobbin case but it wasn't. Could it be the timing is now out of sync? Is it something I can fix? Quantum CXL
Are you able to remove the bobbin case from the machine? Remove the needle and then work at gently removing any knots of thread in the bobbin area until you are able to remove the bobbin case.
Once the machine is cleaned of all the excess thread, lint, etc., install a BRAND NEW NEEDLE, reinstall the bobbin, and rethread the top thread. Then retest your machine on regular woven fabric. If it stitches, then you are probably okay. If it will not pick up the bobbin thread, then the machine is probably knocked out of time.
Search for: sewing machine timing
or take it for service.
FWIW, vinyl presents issues when sewing. A roller or teflon foot may help. Also, placing tissue paper between the presser foot and vinyl could be beneficial. Look at using a top-stitch needle to prevent the thread from hanging up on the vinyl. Search for web sites or videos on how to sew vinyl.
Feb 12, 2018 | Sewing Machines
Thread started bunching on underside of project & tangling around bobbin. Now the needle won't pick up bobbin thread, even after changing needle 2x and re-threading upper thread. What's wrong?
Hmmm, could be several things.
Try a brand new needle. Try a different brand of thread.
Remove the top thread from the machine. RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
If it still will not pick up the bobbin thread, the machine could be out of time.
Jan 19, 2018 | Singer Sewing Machines
Why does the top thread sometimes picks up the hook and then picks up bobbin but bobbin then crosses over and makes a mess? Wont work
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? n
May 21, 2015 | Sewing Machines
When attempting to free motion quilt, bottom thread is not being picked up
You must lower the presser foot to use the free motion/darning foot.
Dec 04, 2013 | Brother Sewing Machines
I bought a #7442 last Christmas and have not had a chance to use it until now. BRAND NEW, w/Carry Box and all. Anyway, my husband and I have spent ALL DAY trying to get it to work! We watched the DVD 5...
Not sure what brand of machine you have but generally after threading the bobbin the thread should be pulled out through a spring like device and by pulling on this thread and holding the bobbin case loosely in your hand, the bobbin case should turn clockwise inside the case. Clockwise is essential.
Then turn the machine by slowly by hand and let the needle go down and up once. Then pull up the end of the needle thread which should then lift the bobbin thread with it. Pull both through the back of the presser foot and start to sew. I hope.
Dec 08, 2010 | Sewing Machines
Top thread will not pick up bobbin thread makes a big loopy mess
This is sometimes caused by the upper thread not threaded correctly. You need to thread it first with the pressure foot in the up position. You need to "floss" the thread into the clear plastic guide as this is where the tension is. The tension should be set to E for embroidering. Also make sure you get the bobbin thread in the slot on the bobbin case. Also, lower your pressure foot before you begin embroidering. Hope this helps!
Sep 20, 2009 | Singer CE-100 Futura Computerized Sewing...
I need to know how to thread a bobbin?
TRY THIS, itma not be your model, but should help Title:
ac093.jpg Pre-tension disk ac094.jpg Bobbin winder shaft ac095.jpg Bobbin
1. Pull up the spool pin as far as possible, and then put a spool of thread on this pin. windingbobbin_a0991.jpg
2. Pass the thread around the pre-tension disk. Make sure that the thread passes under the pre- tension disk.
windingbobbin_a0992.jpg ac098.jpg Pre-tension disk c_b4.jpg Pulling it in as far as possible
Caution If the spool of thread is not in the right place, the thread may tangle on the spool pin.
3. Pass the end of the thread through the hole on the bobbin from the inside of the bobbin. windingbobbin_a0993.jpg
4. Put the bobbin onto the bobbin winder shaft and slide the bobbin winder shaft to the right. windingbobbin_a0994.jpg
5. Turn the bobbin clockwise, by hand, until the spring on the shaft slides into the groove of the bobbin. windingbobbin_a0995.jpg ac099.jpg Spring on the shaft ac0991.jpg Groove of the bobbin
7. While holding the end of the thread, gently press the foot controller or press start/ stop button (for models equipped with the start/stop button) to wind the thread around the bobbin a few times. Then stop the machine. windingbobbin_a0997.jpg
Note
  • If the sewing machine is to be operated using the foot controller, connect the foot controller before turning on the machine.
  • When the foot controller is plugged in, the start/stop button cannot be used to start sewing (only for models equipped with the start/stop button).
Caution Make sure you follow the instructions carefully.
If you do not cut the thread completely, and the bobbin is wound, when the thread runs low it may tangle around the bobbin and cause the needle to break.
9. Slide the sewing speed controller to the right (to set the speed to fast).
(For models equipped with the sewing speed controller.) windingbobbin_a0999.jpg ac0992.jpg Sewing speed controller
10. Press the foot controller or press start/stop button (for models equipped with the start/stop button) to start. windingbobbin_a18.jpg
11. When the bobbin seems full and begins spinning slowly, take your foot off the foot controller or press start/stop button (for models equipped with the start/stop button). windingbobbin_a19.jpg
12. Cut the thread, slide the bobbin winder shaft to the left and remove the bobbin. windingbobbin_a191.jpg
13. Slide the sewing speed controller back to its original position (for models equipped with the sewing speed controller). windingbobbin_a192.jpg
Caution Not winding the bobbin properly may cause the thread tension to loosen, and may break the needle.
woundbobbin3.jpg ac0993.jpg Wound evenly ac0994.jpg Wound poorly
Note
  • When the sewing machine is started or the handwheel is turned after winding the thread around the bobbin, the machine will make a clicking sound; this is not a malfunction.
  • The needle bar does not move when you slide the bobbin winding shaft to the right.
Sep 02, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing machine timing problem
Singer sewing machine needle does not go directly down into opening of foot, it hits the back plate of foot. how can i align it.
Apr 23, 2009 | Singer 14SH654
Shuttle driver
Hi i have a Janome 350E thread got court undert the needle plate so i cut the thread from under the hoop and got it all out the bobbin shuttle but the machine wont sew now it seams to be out of timining as the needle is coming up to soon for the shuttle to pick up the thread can you please tell me how i can fix it as i dont have a sewing machine mechanic in town and i will have to travel up to 2 hours to get it looked at and they are really slow to get things back to thier clients.
Regards Sandim.
Jan 22, 2007 | Euro-Pro 473
Sewing Machines Logo
278 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Wayne Buss
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
