Question about HP DeskJet F380 All-In-One Printer
HP Deskjet F2180 Margins incorrect for label printing
When printing address labels on label paper (A4 - 3w x 7dp), the upper margin is reduced by 10mm and label text consequently misaligned with labels. If I do exactly the same print on plain A4 paper all is correctly aligned. I don't understand. Paper is identical size. I have tried setting different paper types with no effect. Does anyone know solution or have similar problem?
  • 1 more comment
  • YD06 Dec 10, 2008
    Hi, I have had the same problem with my HP PSC 1210 ever since I first tried labels on it. Didn't used to be a problem as I always just printed labels out my old Epson but that has given up the ghost and I am desperatley trying to resolve this problem. As you say the printing on plain paper is perfectly positioned so why not on the labels. I have tried adjusting the top margin etc but it makes no difference.
  • bernard_kaye Dec 11, 2008
    Thanks YD06, I have tried your suggestion but unfortunately the error is not "accurately" repeatable so trial and error will be hit and miss. I think I will have to try using different label manufacturers but this could prove expensive. May be a replacement printer would be best in long run.
    Thanks anyway
  • Anonymous Feb 13, 2009
    Same problem different printer. How can the printer know when there is label stock in the tray as opposed to paper. Very frustrating.
I eventually managed to print my labels one sheet at a time by forcing the label top edge down the page. You can insert one or two lines above the label template and adjust the font size to get the right distance. It took a bit of trial & error but got there in the end. Hope it helps you
Posted on Dec 11, 2008
Why are my paper margins shifted up when printing?
try reinstalling the printer drivers and firmware.
make sure that the calibration is correct and the test page is printing fine.
try a scan-copy test if its an AIO printer.
if that does not help .. then call 1-877-805-1027 for expert help
Jul 23, 2015 | HP DeskJet F4180 Inkjet Color All-In-One...
Printing Margins settings incorrect with Windows 7
if the printer have disk use it and install printer driver
Dec 21, 2013 | HP DeskJet 950c InkJet Printer
It will not print Word documents. it pulls a blank piece of paper through. It will print in notepad
there is something wrong with your Word printer setup. Go to Word, then from the File menu select the Print option and when the print window opens see if the HP deskjet is selected as default printer. Then, in the upper right quadrant theres a button called Advanced Settings, or Prefferences (depending on your Word version). Click that button and check to see if the HP printer is set as On Line, and is set to print odd and even pages. Also, check the margins of the paper. Ink Jet printers cant print over the full page, there's always a need of some margin on each side of the paper, so you'll need to set the margins from all sides on at least 0.5 inches
Jan 18, 2011 | HP Deskjet F2210 InkJet Printer
At school there is a printer the Dell 5100cn laser printer and we need to print labels and each time we try it asks on the computer if I want to continue because they are outside of the standard margins,...
A5 is a European paper size standard. Your label making program is telling the printer that the program needs that size label paper. You have to tell the printer to use that size paper. It may be somewhere in the menu of the printer driver on the computer or it may be on the display window on the printer, or it may be as simple as flipping a tab in the paper tray. As far as the printing outside the standard margins, most printers will allow a certain amount of that without a problem. Just tell it yes or Ok. If you solve the paper size problem and it hangs up when you tell it to print outside the margins, then the printer is not compatible with that label format in the label printing program. You will have to choose a different format. I recommend that you select a label format that is a US standard like 3 across on 8 1/2 x 11 paper.
Nov 19, 2010 | Dell 5100cn Laser Printer
Problems printing labels
may u should the paper size setting
Jun 01, 2010 | HP (139545-001) (139545001)
When I print a label, there is a blank white space before and after the printed text. How do I reduce the amount of tape printed before and after the text so as to maximize the label tape available?
you can, change the margins to narrow. you'll decrease the right margin but not the left margin which accdg to my research, is the space needed for the ptouch to print.
May 31, 2010 | Brother P-Touch 1180 Label Printer
Having problems with printer margins. It will print the first label correctly then the next 4 or 5 it will mess up the margins and print out on two labels
You Have to set label size in the printers driver. A hundred diferent label sizes can be used but the driver must know the size to layout the bitmap correctly
Goto printers and faxes then right click on your zebra printer driver. Left click properties and then left click the advanced tab, then left click printing defaults button. In the zebra designer driver size is on this page. The Zebra Universal driver you click a few levels deeper by clicking paper output then paper size. If your size is not listed in the drop down arrow then click customize, then highlight user defigned on the upper left off the screen and enter your correct label size.
May 09, 2010 | Zebra TLP 2844-Z Thermal Label Printer
When trying to print Avery Labels L7160 the top few labels print within each label 'frame' BUT towards the end of the page the labels are printed further up and therefore are out of the label 'frames' ALSO...
For Word 2007/Word 2010
1- Click on the Office button
2- Select Print then Print again.
3- In the Zoom section make sure 'Scale to paper size' is set to 'A4'
4- Click on the Properties button.
5- Click on the Paper / Quality tab, then click on Advanced.
6- In the Paper/ Output section it has Paper size. To the right you have a drop down menu . Make sure A4 is selected and not letter, then click on OK.
3- There may also be other options in your printing preferences such as 'Print Area', 'Scale to Fit Page Size' or 'Page Margins. These will all need to be set correctly for your design to print 100% e.g. Print Area set to Maximum, Scale to fit Page Size disabled and Page Margins set to Minimized.
Some printers ( for example Epson printers ) have a 'Reduce /Enlarge' facility that defaults to 94% or 97% (instead of 100%). To set this to 100% click the 'Layout' tab and in the 'Reduce/Enlarge' section select 'Custom' you should then be able to change the scaling to 100%.
Mar 12, 2010 | HP LaserJet 3050 All-In-One Printer
Cannot print avery labels, get message the margins of section 1 are set outside the printable page, or will run thru printer , printing complete get blank page
I assume this error is occuring in Microsoft Word.
  1. Create a new document, with a full page of the label you are having trouble printing.
  2. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  3. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  4. Click the Fix button to have Word change the margins
    to match your printer. You should now see the Margins dialog with the new margin settings.
  5. Click OK.
One thing to watch for- on some inkjet printers, the printable area is narrower than the labels. This will cause the labels to shift to the right on the page and be misaligned when you print.
If the labels run off the right edge of the page display, or are misaligned when you print, an extra procedure is needed.
  1. Undo ([Ctrl]+[Z]) the new margin setting, or create a new page from the label template again.
  2. Select the entire table of labels ([Ctrl]+[A]).
  3. Right-click the table, and select Table Properties.
  4. Click the Text wrapping "Around" option, then the Positioning button.
  5. Change the Horizontal position to Center, Relative to Page.
    Uncheck the "Move with text" option. Click OK to the Table Positioning dialog, then click OK to the Table Properties dialog.
  6. Left-click (or press an arrow key) to "deselect" the table, then go into the margins dialog (see above) and allow Word to fix the margin settings again.
With the labels aligned to the page, rather than the margins, the new margin settings should not cause the labels to shift.
Once you have the margins set correctly for your printer, I would save the empty page of labels to use as a "template".
Jun 29, 2009 | Lexmark P3150 All-In-One InkJet Printer
Label Printing
I had the same issue when using Avery labels, here's what resolved it for me.
Go to Control Panel, Printers, go to the active default, right mouse click, click Printing Prefrences..., change the drop down "Type is:" to 'Other Photo Paper" and apply.
You should then be good to go!
Feb 10, 2008 | HP DeskJet F380 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
684 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
