Question about Matsonic MS8177C Motherboard
Board problems.... Hi there,im trying to resurrect the MS8177C rev1.1 motherboard. Got the correct CPU in, Hard drive is pre-loaded with Win2000, I can hear when the board powers up, but the display does not switch on weather you use in on board display or the AGP. PLEASE help me out!!!!!!!!!!! Whats wrong???? How can i fix it? The previous owner gave it to me,just the board and CPU. No comments from him either......... Marc
  • 1 more comment
  • Anonymous Dec 08, 2008
    The board does not beep at all.
    The monitor does work....
    Ram is installed. I have tried DDR 333 and DDR 400.
    No caps are swollen at all either
    and lastly CPU is installed properly.
    AARRRRRGGGG!!!!!!!!!!!
  • Anonymous Dec 24, 2008
    No go Guru,
    I can hear the board powering up but still no display even if i change display cards,
    There is no sounds form the board either,and no caps swollen.
    I have removed the CPU and reinstalled it-to no prevale (solution)......
    Any thing else maybe??????
  • Boli May 11, 2010
    Does the board POST bleep? If so how many and what pattern.
    Does the monitor work on a different machine?
    Let me know...
    Matt
  • 63 Answers
If you take the Ram out and power the board with no RAM does it have a 3 beep pattern (or somthing similar)
If it does beep (complaining of no RAM) then your board should be okay and try different ram,
if it doesnt then its either your board or CPU,
remove everything from the board (RAM CPU IDE devices etc) and power it,
again if it does bleep (complaining of no CPU) try changing the CPU
If it doesnt beep your boards probably had it.
Let me know...
Matt
Posted on Jan 05, 2009
    Sergeant:
    Champion:
  • 201 Answers
You do have ram istalled? Pul the power cord remove the bios batt wait 3 min and try again. Make also sure your cpu is properly istalled. Check on board for faulty caps usualy swallen. Hope this helps have a nice day
Posted on Dec 08, 2008
The heat sink on one of the support chips came off and wedged between the graphics board and the thermaltake cpu cooler after the PC was knocked over. The resultant short circuit to ground has blown the...
clue no 1
all of the operating system, files , folders and data are on the hard drive not the mother board
you can fit a new mother board then refit the hard drive and it will be capable of restarting up again
discuss that with a computer repair shop where you buy the new mother board and graphic board
next time use the heat sink adhesive between the cpu chip and the cooling fan heat sink and install it properly
Mar 27, 2017 | Albatron PX865PE Pro Motherboard
PB Diego FX Foxconn Motherboard MCP73M04 P8 Manual Needed
check yhe board for swollen caps around the processor if the tops of the caps are not flat there bad and the board is done
Jul 10, 2010 | Computers & Internet
My computer does not start, but the ld motherboard lights up, I've tested, and the source is ok.
I don't know how computer technical you are, but it sounds like you know a thing or two about them. So here's the best way to find the problem:
There could be many things that could stop the board from fully booting, Determining what is wrong is like detective work. What I do, is open up the case and take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd, hard drive or otherwise) the CPU, a graphics card (only if required) and one bank of memory. (which is not required, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. If your going to load a IDE drive, make sure you set your pin setting correctly on it, meaning the drive (IDE or EIDE) your putting on the board is set to Master, or Cable Select if your using the cable placement method.
Now, turn it on, and you should get the power supply on, and the cpu fan going. If they start, then make the next step to have the single drive be your hard drive, and see if it boots. If it boots, then great, open Bios and make sure Bios is reading the board and all things are fine with it. If so, what ever you put on next make sure it one at a time so you can identify what it doesn't like.
In the case where the CPU or power supply don't power up, it's then either one of the six elements. The CPU, Power supply, Ram, Drive, graphics card (if required) or the motherboard.
The next step is to replace each one of the first five, starting with the Ram Chip, put another like chip in and see the results. Then do the same thing to each of the remaining 4 components, the graphics card (if required), then the drive(cd, hard drive or otherwise), on to the CPU, and last the power supply. Hopefully something will show it's ugly way to make a change. Also, on the drive (IDE, EIDE or SATA) , try a different cable to make sure it's not that,
Now If no changes happen after all that, then I take it one step further and usually get a like (doesn't have to be exactly the same, but a board that the components can be tested on) motherboard that I can test the first four, and make sure that they really work. If after that and you have tested all of the components and they all work, then it's save to say you have a bad Board my friend. It's a lot of work I know, but it's the sure fire way of finding out what isn't working.
Good Luck
Mark
Feb 05, 2010 | ASUS A7S8X-MX Motherboard
My computer will not boot up, i.e I get no video although my hard drive spins but there is no disk activity. I have a KT600A motherboard with a AMD Athlon processor. Could my motherboard have gone bad?...
The next step is to replace each one of the first five, starting with the Ram Chip, put another like chip in and see the results. Then do the same thing to each of the remaining 4 components, the graphics card (if required), then the drive(cd, hard drive or otherwise), on to the CPU, and last the power supply. Hopefully something will show it's ugly way to make a change. Also, on the drive (IDE, EIDE or SATA) , try a different cable to make sure it's not that.
Good Luck,
Mark
Jan 31, 2010 | Pioneer ECS KT600A SKT A W/SATA/400FSB/6CH...
Im running a L7VMM2 mb on my computer. It doesnt boot anymore. I changed power sources, but still nothing...no lights...no fan movement...nothing! Is it time for a new board?
HI,
There could be many things that could stop the board from turning on, Determining what is wrong is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, graphics card (if required) and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drive, make sure you set your pin setting correctly on it. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the six elements. The CPU, Power supply, Ram, Drive, graphics card or the motherboard. The next step is to replace each one of the first five with another to see if you get any change. Also, on the drive, try a different cable to make sure it's not that, If no change, then I usually get another board that I can test the first four, and make sure that they work. If after that and you have tested all of the components and they all work, then it's save to say you have a bad Board
Good Luck
Mark
Jan 04, 2010 | Computers & Internet
Am using Biostar M7VIG-400 Motherboard unable to boot but my cpu fan is running and also i removed the ram, the beep also not comming
HI,
Good :Luck,
Mark
Jan 04, 2010 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Getting on board vga video to work on asrock
As per discription provided by you, Suspect the physical RAM is having problem. Check and insert the RAM properly may solve your problem.
Hope the above solution may resolve your problem. Please give us the feedback on the solution to provide the best resolution in future.
Revert Back for more assistance or clarifications.
Dec 26, 2009 | Asrock P4i65G Motherboard
Will motherboard will support winXP pro
Hi gimondor,
The motherboard really isn't your worry. Windows XP pro requires a 300 megahertz or higher processor. You motherboard can take from 100 to 400 megahertz, so you need to know what your CPU is. If your running an intel P4 chip, and at least 128 mbs of ram, and you have at least 2 gb's of hard drive space left on your hard drive, then you can run XP Pro.
Good Luck,
And please leave a rating based on my solution.
Mark
Apr 06, 2009 | AOpen AX4BS Pro (91.89J10.001) Motherboard
I HAVE P5RD1-VM ASUS BOARD NOW COMPUTER STARTED PROBLEM
several reasons for this.
1:) CPU Overheating.
2:) RAM Overheating.
3:) Motherboard Component Overheating.
4:) FAN not operating correctly.
These are a few things that can shutdown a computer after a few minutes, also viruses/trojans et,c.
can shut off hard-drives. and even instruct the bios to change settings.
Check that the CPU And case fans work correctly.
Mike @ compurepair.
Nov 17, 2008 | ASUS P5RD1-VM Motherboard
Matsonic MS8177C Motherboard Logo
205 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Robert Karst
Robert Karst
TheJustin
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
