Code P1870 1996 Chevrolet Monte Carlo Z34 3.4litre
Very common Transmission code - solution # 1 check to be sure Fluid is full . If not trans code sent plus will turn on check engine light or service engine soon . # 2 be sure condition of fluid is Good / Not worn out . Fluid must be Red / Reddish in color Cold and When hot- warm still have red / even lighter than when cold .# 3 if a higher than 50,000 mile car used in heavy rush hour traffic during hot weather then change fluid to give it fresh oil / Trans will fight heat better and save you a $$ 2000 repair bill . # 4 most important of all you can save a Trans by adding Lucas Trans treatment it is $ 20 some places but well worth $$ to extend life of vehicle if one in need of saving $$ .This can even be added to existing fluid if color is still reddish .
SOURCE: 1996 monte carlo fault codes po300, 441, 705,
THESE ARE FROM THE GM CODE DIFINITION MANUAL, U NEED TO TAKE THIS TO THE DELAER, U HAVE SOME SERIOUS PROBLEMS TO GIVE THIS MANY CODES.
P0300 - Engine Random Misfire Detected
P0441 - Evaporative Emission Control System Incorrect Purge Flow
P0705 - Trans Range Switch Circuit
P1106 - Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
P1133 - Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
P1441 - Evaporative Emission (EVAP) System Flow During Non-Purge
P1662 - Cruise Lamp Control Circuit
P1672 - Low Engine Oil Level Lamp Control Circuit
P1870 - Transmission Component Slipping
SOURCE: need to replace alternator on 1998 chevrolet monte carlo
Nope, it has two bolts one towards the front and one at the back underneath. Be careful of the one in the back as the nut is tricky to get on. You don't need to remove the bracket.
SOURCE: vacuum line diagram 98 chev monte
No sticker on underside of hood or on rad support showing that?
SOURCE: 1996 chevrolet monte carlo
Just because you cant feel in doesn't mean it isn't slipping. The computer monitors input rotation speed and output rotation speed of the transmission. If the output isn't within a certain range the computer stores this code. The only reason for this is transmission slipping and will require a rebuild.
SOURCE: where do you put the power steering fluid
front lower edge of engine theres a small reservoir near steering column
