Question about Brother DCP 115C All-In-One InkJet Printer
Unable to clean error 46 on model dcp115C displayed
Have tried the maintenance mode but can't resolve problem what is error 46? Please
    Genius:
  • 1,239 Answers
Here is the answer to the Machine Error 46 (have just fixed my own MFC210C):
Machine Error 46 – Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Carry on printing !!
Posted on Dec 09, 2008
  • 365 Answers
SORRY I CANT TELL WHAT MAY BE THE REASON FOR ERROR 46.TRY TO CHECK THE CIRCUIT BOARD
  • 734 Answers
Brother DCP110c Reset Counter1. unplug at side of unit, switch on while pressin menu2. Enter 8 press set enter 0 press set
" by using the up arrow key & SET keys."
3. press the mono start key several times untill the purge count appears on the LCD.
4. enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero (like in 1)
5. press the stop/exit key to return to the initial stage of the maintanance mode.
6. enter 9 twice by using the up arrow & set key’s to exit from maintenance mode
  • futureloginn
    futureloginn Dec 10, 2008
    Brother DCP110c Reset Counter1. unplug at side of unit, switch on while pressin menu2. Enter 8 press set enter 0 press set" by using the up arrow key & SET keys."
    Genius:
  • 1,199 Answers
Take all the ink cartridges out unplug...wait 5 min put ink back in plug in and turn on...this should do it!
Unable to clean 46. this error display in lcd of brother dcp585cw printer. how to solve me this problem.
Machine Error 46 - Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An "initial purge", for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
Jun 26, 2011 | Brother DCP585cw AllInOne InkJet Printer
My printer says it's unable to clean 46? it's a mfc printer LC-51 Series ink
Please note that this error code appears when the container in the printer that is responsible for storing used / discarded ink is full or registers as full.
The following instructions will guide you through the process of resetting the printers self clean counter so the error will go away but in the event that the ink absorbing box is actually full and this is not an erroneous message the error message will trigger again immediately.
Also please note that if the ink box is full and the error code is reset the printer may begin to spill out excess used / discarded ink.
I suggest purchasing a new ink absorber box and installing it.
May 04, 2011 | Brother MFC 420CN All-In-One InkJet...
It says "unable to clean"
Dec 20, 2010 | Brother MFC-5840CN All-In-One InkJet...
Error 46 what is it
Here is the answer to your MFC code 46
Nov 24, 2010 | Brother MFC-5840CN All-In-One InkJet...
My printer brother DCP115C ''UNABLE TO CLEAN error code 50''
Machine error 50 is a error in Purge unit.You can't fix it by yourself and your printer need service.In most case the cost of repair is more than cost of new printer.
Nov 03, 2009 | Brother DCP 115C All-In-One InkJet Printer
Machine error 46
thanks.
Jul 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
Not printing
Nov 21, 2007 | Brother MFC 210C All-In-One InkJet Printer
Need to reset purge counter due to error 46
MFC-5440CN saved from the tip!
"Unable to Clean" message - found TrickyDicky's sltn 4 for various printers.
Went into maint mode as per sltn 4 - verified error 46.
"The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed."
Keyed in 80 - stepped through the items with "down" key and located Purge Counter.
"Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero
Press the 9 key twice to return to the standby state."
This worked brilliantly - no need to tamper with any parts of the printer. Purge Counter reset did it all. Fully functional printer.
Thanks TrickyDicky for info on verifying the error code and purge reset
Mar 27, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
57 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
