Question about IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 6 memory loss
I have an IBM Wheelwriter 6 and it losses its settings, etc after the power is turned off. I have replaced the 3 batteries but the problem persists? Any suggestions
Tired of retypping - Helen
  • IBM Master
  • 3,594 Answers
If you have changed the batteries the battery holder is probably corroded, take a piece of fune sand paper and clean the contacts, put the batteries in and spin them around to help them seat.
Posted on Dec 08, 2008
I have am IBM wheelwriter 6. When it powers on the two center line indicators stay on. All functions and keys work as they should. Fresh batteries.
try turning it on remove the batteries check the contacts for clean replace the batteries in the correct direction.
Aug 24, 2016 | IBM Wheelwriter 6 Typewriter
How do i use the memory function on my ibm wheelwriter 6?
Before we start turn it on after it completes is power on just the #1 light should be lit this says the batteries are OK. If they flash replace the batteries and clean the holder.
To store hold the store key while entering an address 1 - 99, type info then press store again.
To play press play with the address.
Oct 07, 2014 | IBM Wheelwriter 6 Typewriter
IBM Wheelwriter 3 won't type
Print hammer selenoid cap is broken, or print hammer selenoid is gummed up.
Jan 03, 2014 | Lexmark Wheelwriter 3 Typewriter
How to express a loss as a gain in dB?
Decibel is what sound is rated in.
The sound level is expressed as a line.
0 in the middle.
Negative values are to the left, Positive values to the right.
Less DB rating to the Left, more DB to the Right.
Anything above the 0 is louder. 1, 2, 3, 4, 5, 6, etc.
Anything below the 0 is not as loud, -1, -2, -3, -4, -5, -6, etc.
It would be correct to state a 6 DB loss as -6DB.
May 17, 2012 | Computers & Internet
Wheelwriter gives 3 beeps when turned on. Meaning?
Try this. Remove the batteries, turn off for 30 sec. turn back on.
This will set everything to default settings. IT WILL ALSO CLEAR THE MEMORY!!!
Mar 19, 2010 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 6 Series II beeps
Three beeps and the space lights blinking means the batteries are bad replace them and be sure the holder is clean.
Feb 14, 2009 | IBM Office Equipment & Supplies
IBM Wheelwriter 6 reprint key
There is no replay key on a WW6 however there is a memory.
On the L. side of the keyboard there are 3 keys store, play and delete, to store hold store and type 01-99 as an address release thwe keys and type info when finished press store again.
To play hold play and type address.
To delete follow same proc.
Jul 22, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 15 Series II-Program the memory
The WW15 does not have a recallable memory, it has a reprint memory that will repeat what you have JUST typed, code reprt top left kry on the keyboard will activate if you want a full memory get a WW5 or 6.
Dicky O
May 05, 2008 | IBM Wheelwriter 30 Typewriter
Programming wheelwriter 6
The WW series uses a battery pack with 3 AA batteries, located right under the top cover. If you have never replaced these the pack is probably corroded and be cleaned with a nail file.... or even Coke if you want to remove it.
When things are clean and dry replace the cells with new ones and plug the pack back in.
Sorry to tell you but the memory is gone forever. In the future, replace the batteries when the power to the TW is ON, only was IBM lets you do that.
Feb 23, 2008 | Lexmark Wheelwriter 6 Series II Typewriter
IBM Wheelwriter 30 Typewriter Logo
140 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
