Question about ASUS SiS Chipset CUSI-FX Motherboard
Updated BIOS fail
I update BIOS with wrong type.
my motherboard came without LAN but I update it with BIOS type that motherboard came with LAN. and result is can't boot after POST.
my motherboard model is CUSI-FX.
To have your problem solved you will have to send the mobo to the manufacturer so that they can flash it and put back the original
Posted on Dec 08, 2008
Bios update
How to Update Your BIOS
By Patrick Miller, PCWorld
  • Jan 21, 2010 6:00 PM
  • Check your BIOS version, without restarting your PC, by using msinfo32.exe (as described in the text).187437-versioncheck_original.jpgThe easiest way to find your BIOS version is to open up the System Information app in Windows--just type msinfo32 into the search bar (for Windows 7/Vista) or the Run box (XP), and clickSystem Summary; your BIOS version should now show up on the right under your processor speed. Record your version number (and the date that appears afterwards, if applicable).
    Step 2: Check your PC/motherboard manufacturer\'s Website for BIOS updates.
    Most PC manufacturers handle BIOS updates based on your specific line and model, so head over to your manufacturer\'s support page and check its listings for your PC, because if you download and install a BIOS intended for a different model, your PC probably won\'t work (although most BIOS updaters are smart enough to notice if you try to install them on the wrong hardware). If there is a BIOS update file available, grab it--along with any documentation it comes with, because often warnings and specific instructions are contained in the Read Me docs.
    Those of you who assembled your PC yourself will need to look for BIOS updates from your motherboard manufacturer\'s Website. If you don\'t remember your motherboard\'s model number, you can look it up without opening up the case by downloading and running CPU-Z and clicking on the Mainboard tab.
    Step 3: Read the included documentation.
    Your PC\'s BIOS handles a lot of the nuts and bolts ISO Recorder for Windows XP or the version for Windows 7/Vista) to create a BIOS update CD.Other systems will have you copy a few files to your bootable disk, restart, and open up the BIOS during startup (typically by pressing a specified key for setup options), and change the boot order so your system looks for a bootable USB drive or CD before loading the OS from your hard drive.
Dec 13, 2013 | Acer Q45t-am Motherboard Intel Q45 Ddr3...
Hello plese help me driver asus p4s133-vm bios
These Drivers are for Windows XP Only
Audio
VGA
LAN
The BIOS is very risky to update, one wrong move and your motherboard will be useless.
Hope this helps.... please rate
Dec 23, 2010 | ASUS SiS Chipset P4S133 (P4S133/PA/LAN)...
I Have ASUS P5RD1-VM series motherboard of which the LAN driver is being missing all the time. Pls. anybody help me. Regards Sachin
Open Advanced while in the bios. Than open Southbridge configuration.
Please check bios for Onboard LAN Page 2-24 in you're manual. Set this to [Enabled]
If you do not have this enabled the LAN controller will not function.
Once enabled in bios save and exit the bios menu.
Open windows update when you're system reloads.
Click the custom button when windows update open’s.
Windows update service will scan you're system and will see you're LAN is enabled.
Windows will list drivers for you're on-board built-in LAN controller.
Or you can use the Asus CD to install the LAN controller software.
If you're LAN controller does not function you may need to add a PCI eithernet card.
Mike
Apr 12, 2010 | ASUS P5RD1-VM LGA775 Motherboard - ATI...
Dear sirs, i put wrong parameters in bios. so
99% of all bios don't need to be flashed or updated. Unless you have a specific problem with your bios and you go into the manufacturer's website and can read about the bios updates and see your problem as one of the ones that the bios update fix, don't update your bios. It's not going to make your computer run any better, it's not going to cure all the problems you have. About half the time it just messes up your computer or can ruin it. A lot of motherboard manufacturers have come up with Windows based programs to flash the bios but if they fail then you have to go back to the old method and they usually require having a floppy disk which most computers don't come with anymore. If you're one of those people that want to play around with your computer and do a little experimenting you're must better off to go format your harddrive, wipe it clean and start all over. Then you can go find all your new driver updates, software updates, find all the files you just deleted off your computer cause you forgot to backup before you formatted it. It's a lot more fun than flashing and updating your bios because your computer will still work when you get done. Sorry dude if the pin reset doesn't work the only option is possibly putting a new bios chip on the motherboard but I haven't seen one of those in years. Not sure they even still make them detachable and you'd have to find a motherboard to get one off of.
Dec 05, 2009 | EliteGroup L7S7A2 Motherboard
Multimedia Audio Controller Needed as Well!
I find VGA and Audio triver for motherboard MSI-661FM3
Jun 02, 2009 | MSI 661FM3-V Motherboard
How to update Compac Evo D510Sff Motherboard bios
go to hp website /type modle number name tell them what you want and they will give you list download /and update bios from there free
Apr 11, 2009 | HP Compaq EVO D510 Intel Desktop PC -...
Bios update failed, computer will not start
the bios of your motherboard has gone , replace it,
Oct 25, 2008 | Toshiba Satellite M115-S3094 Notebook
Bios update
Can you check the network or lan setting maybe because of the update the configuration is changes. try to re install the lan driver from your cdrom motherboard driver.
Apr 22, 2008 | Intel Motherboard
ASUS SiS Chipset CUSI-FX Motherboard Logo
83 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
