Wharfdale DVDR24HD160 sound but no picture, i have connected vie the scart
Sound but no picture after system working fine?
Try pressing the HDMI button on the remote - if you pressed this in error and HDMI not connected the screen will go blank.
Posted on Dec 23, 2008
You need to connect the hdmi cable to the dvd and tv. the you will be able to go in to the settings and change it from hdmi connection to scart
Posted on Mar 31, 2009
Polaroid led tv ssdv311-11 sound but no picture, connected thru cable box
The TV electronics for the picture may have failed. Do you get any picture ever, like when you turn it on, or when you connect a DVD to it?
If you do then replace the scart cable with a good known brand. Cheap scart cables often do not have all the pins connected up.
Dec 21, 2013 | Polaroid 1521-TLUB LCD TV
Wharfedale DVD recorder, no sound. Scart lead connected to Sky Box & scart connection to TV. Picture OK & can play DVD's or record to HD but no sound.
HI if you mean scart connectors on rear of DVD recorder, try swapping scart inputs on DVD recorder and if no joys then on set top box. (some units have 1 input designated for TV and the other for Set top box input)
Mar 16, 2010 | Televison & Video
Sound only ,no picture when vcr connected,checked connections,codes ,input etc no luck
How have you connected the VCR..vis Scart or UHF cable?
Has your tv got more than 1 scart socket if connected this way.If so, have you tried using a different scart inputon the tv?
Has the tv got picture and sound when vcr is not connected?
All these answers help with the diagnosis :)
Oct 17, 2009 | Sanyo DS31520 31" TV
Get picture but no sound
If you gettting Picture but no sound this is Normally down to a scart lead not connected correctly.
Please try pushing the scart lead in fully on the back of your Dvd player also check the back of your Tv as well. This should sort the sound problem out for you.
If for any reason this does not work then please try another scart cable incase the one you have connected now is faulty.
Hope this helps you out. If so then please leave a Thumbs up
Cheers
Little Dish Fitter
Oct 03, 2009 | Sanyo Televison & Video
Just got logik ldvr 1608 dvd but it cant find any
You need an aerial to tune the freeview.
However, to record from satelite you can connect a scart lead from the satelite vcr out to the dvd in and it will record vie the av "channel" on the dvd.
Depending on your location, regarding signal strength, you can purchase an indoor, boosted aerial to tune the freeview.
Also, if the scart connection on the dvd is a 2 way connection( allowing a signal to the tv as well as from the tv) you can connect the tv to the satelite and the dvd to the satelite only and the dvd will play through the satelite even when the satelite is off.
Aug 26, 2009 | Televison & Video
No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Dec 10, 2008 | Panasonic SC-HT75 System
How do I get hdmi working on warffedale dvdr24hd160 as have lost manual
Hi
You need to set it up to your tv via scart.
Click the setup button
Go down to the video option
There is a setting there to turn on hdmi 720p 1080i etc
Hope this helps
Nov 11, 2008 | Wharfedale Televison & Video
I have got wharfedale lcd 42in and a wharfdale dvdr24hd how do you set up the hdmi cable to get clear picture i have tryed taking out the scart lead out and left the hdmi cable in but i only get a picture ...
Sounds like you either have a bad card or a bad HDMI cable. Scarts are not the most dependable when it come to HD imaging there is alot of converting going on espically if the TV isnt NTSC standard to begin.
Mar 06, 2008 | Televison & Video
Wharfedale dvdr24hd160
have you try a multy scarts socket , available in many stores , argos , currys, dixson ?
Jan 07, 2008 | Wharfedale DVD-M3 DVD Player
Televison & Video Logo
198 people viewed this question
Top Televison & Video Experts
