Question about Kitchen Ranges
Kenwood elite hood rangf broken bulb was in sockit did not know
Put another bulb an then seen sparks now the lights won twork &FAN WON T COME ON
    Sergeant:
  • 359 Answers
CHECK BREAKER OR PANEL FUSE
Posted on Dec 11, 2008
I just got my airbag fixed on the recall and now my fan won’twork In the lower speeds . did they forget to hook something up
Sounds like you have a common problem with your blower fan resistor, easy to replace and not expensive on amazon. Replace it yourself it sits right next to your blower.
Nov 12, 2017 | Cars & Trucks
My poulan won,t start ,i put new primer bulb on and new gas lines nowit won,t start
Flush old gas. Clean or replace spark plug. Check float on carb, clean carb bowl if equipped.
Jun 03, 2015 | Poulan Garden
Why won`t the fan of my venmar range hood turn off?
Sounds like you may need to replace the fan switch. The fact that it wont turn off and that it only works on low speed supports that switch is broken.
Apr 24, 2014 | Venmar Kitchen Ranges
Running lights and headlights won't work
It could be that the bulbs are broken or that the spark plug is out. I would take it to your mechanic.-------------------------------------------------------------------------------
Opel Opcom
Feb 21, 2013 | 2007 Pontiac Vibe
1993 buick park avenue heater won,t work.checked all fuses an relays
i beleive you did more than that.? you,ll probably find all have a common earth , chech and remove it , clean with a wire brush and replace, also chance the fuse you removed and replacer reguardless of it,s appearence , ensure its put back in the correct location,peter.
Sep 03, 2012 | 1993 Buick Park Avenue
Pentair pool light fiber optic won't light:
check light generator on deck light probably burned out
Jun 14, 2011 | Pentair Pool & Spa
Kenmore elite ranghood (series# 550) not working
unplug the unit and unscrew the bulbs. put 2 new in if they still dont work then you may have fried the control. there are usually no fuses between the control and light/fan. well i never saw a fuse between the 2.
Dec 07, 2008 | Kitchen Ranges
Light doesn't work on Kenmore Model 55022 Range hood...
If you're getting 120V at the lampholders, yet it's not lighting lamps that still work perfectly well in other fittings, two possibilitiesspring to mind.
One is that the cap on the bulbs isn't quite compatible with the fitting. Assuming they're some variant of Edison Screw, make sure that the centre terminal in the lampholder is sticking out far enough to touch the terminal on the bulb. Also check whether the lampholder achieves it's outer connection just with a small tab, rather than with the whole of the threaded ring. If so, make sure that this is going to touch the appropriate part of the bulb.
The other possibility is that you've got a high resistance connection somewhere - not enough of an open circuit to drop the 120 V when feeding the Megohm load presented by a meter, but more than enough to kill the supply when you have a lamp load. Only way to chase this is to use the meter on ohms range to bell out all the wiring between the lampholders and bits of the system which do work properly.
A.
Apr 05, 2008 | Kitchen Ranges
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Jan 27, 2008 | Kenmore 51840 Kitchen Hood
Kitchen Ranges Logo
240 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
