had replaced motherboard several months previous to this new problem. A couple of months ago replaced the pump. New Problem - wouldn't turn on. technician came out says pump is bad reading 55ohms, should be reading 7-12ohms. says motherboard could be bad and they don't fix the motherboards. so i took the motherboard out of its casing and found a blown fuse (bussmann gmc-v-6.3) i've down some researching and found the fuse for pennies vs. hundreds for a new motherboard. i'll still replace the pump, but is there anything else i should be looking at?
My MW511 model is not spinning although the water is running fine through it, the wash cycle is...
(More)
My MW511 model is not spinning although the water is running fine through it, the wash cycle is runnung rather slow and it makes a loud noise on rinse. please help
HI, lights 3&5 from left.are on and bleep.just as it goes onto spin.water pumps out but no...
(More)
HI, lights 3&5 from left.are on and bleep.just as it goes onto spin.water pumps out but no spin.bearings are free,i have cleaned outside of drum to remove smell.machine has done 2 full wash cycles,and worked ok. tried to get fault codes from F&P. no luck, can you help, thanks harry.
fisher & paykel smartdrive 015 stalls on rinse mode, have to press advance button , also...
(More)
fisher & paykel smartdrive 015 stalls on rinse mode, have to press advance button , also doesnt get clothes very dry on spin mode
