Question about Toshiba Satellite A100-S8111TD Notebook
RPC service --disabed--need help
I accendently disabled the RPC service on my m45-s331 toshiba.Iam new to functions on os proceedures and would like some one that has had experiance or is familiar with this because i can't get nothing working.If you know of a way to get this enabled without reinstall or if you know what its going to take to fix it etc.There is a proceedure to do for this in with recovery console but when I use the disc I can't find any way to get recovery console .The os is xp sp2 home edition pre installed at factory with recovery disc..does this have that or is it in profesional only. I stupidly disabled remote procedure, now I am unable to go onto the internet & my start button has disappeared. Services won't allow me to enable remote procedure. Do you know a way??
  • Mr Diesel Dec 10, 2008
    Thanks for trying, Ive attempted this even when I click on properties nothing happens
    President:
  • 2,110 Answers
Goto Start>Run>Type services.msc and ther u can start RPC
Posted on Dec 08, 2008
M45-s331 I was replacing the wireless card and I broke one of the terminals that snaps to the card. Where can I either get the terminal or the little harness?
this will be the best link for this part:
http://www.ebay.com/sch/i.html?_nkw=Toshiba+Satellite+M45-S331+wireless&_sacat=0&_odkw=Toshiba+Satellite+M45-S331&_osacat=0&_trksid=p3286.c0.m270.l1313
Please let me know if this washelpful and if it solved the problem! Also if the information provided washelpful, please click on the appropriate thumbs to make us aware that theproblem has been corrected or that the information provided helped you with theproblem.. Thank you and Good Luck.
Sep 10, 2011 | Toshiba Satellite M45-S331 Notebook
When my m45-s331 laptop is turn on for a long time, if i put the monitor off, maybe in not be turn on again and it's brightness become very low and hardly it can be seen! what should i do?
if you're using win xp, try to check the power option.(click start, go to control panel & power management/power option).from there, you have an option to adjust your screen brightness settings everytime you wake up your system from sleep mode/hibernation mode.
other option, you can update your video driver. here's the link http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=882862&rpn=PSM40U&modelFilter=M45-S331&selCategory=2756709&selFamily=1073768663
then choose display driver. download and install it. It will update your video display driver. It might help to improve your brightness issue.
Good Luck,
Ryan
Jan 17, 2011 | Toshiba Satellite M45-S331 Notebook
Toshiba Satellite M45-S331 notebook, os xp. Change hard drive couldn't use recovery disk, put in each driver from recovery disk after installing os. Blue screen states the bios in this system is not fully...
The thing is that windows xp ..usually does not have the drivers for teh acpi or achi mode and you need to get into bios and disable teh mode and let the hard disk to run in IDE compatible or sata as ide..
the function can be disabled in the same screen where teh hard disk and other sata and ide devices are presented..
After you disable the achi mode..it will work ..remember that you have to save changes with F10 before exit bios..
another way to make this work ..is install the windows xp in this mode..after you are done ..just install all drivers for it ..including raid and ahci drivers..and change it back from bios..It may work ..if it sees the drivers..
or ..you need to install the drivers when you get to teh press F6 to install 3rd party drivers....and you have to find a way to get them ...cause this operation is done usually b yusing a floppy diskette so ..to have a chance to do it .. you need to try to install them from a usb or install windows from usb and use the disk with drivers in the optical drive ..
If I would be in your place I would not complicate myself and just go to bios and change the bus mode for the hard disk ..save changes and reinstall operation system if needed..or go on from where it was..It will see the hard disk and no longer give you the blue screen
Sep 08, 2010 | Toshiba Satellite M45-S331 Notebook
Can't find updated ACPI Bios for toshiba satellite m45 s331. If found how to install? Getting blue screen Bios in this system not fully ACPI compliant.
I already explained in the other post ..The action required is either install a 3rd party raid and ahci driver ..and if you do not have the possibility ..just c\go to bios and enable the hard disk bus to work as ide..(disable ahci mode) I'm not sure how it will appear ..but you have to look under the bus mode..where the hard disk is seen ..It will appear as ahci enabled..and need to be disabled or ..will have raid mode enabled..and need to set it as native ..or ide compatible
The dvd rom doesnt work. What is the replacement part nr
You do not need a part number ..just order a dvd writer ..with the same bus as the one you have ..
http://www.ebay.com/itm/Toshiba-Satellite-M45-S331-DVD-RW-RAM-Drive-burner-/220775992974
this is to make an idea..
I suggest to reinstall the operation system and see if ti reads a boot-able disk ..when you try to do it ..If it does it means the drive is not gone ..but just has issues in windows and reinstalling the operation system will fix the problem ..
Even if the drive letter disappeared in windows it may be still functional
Jun 27, 2010 | Toshiba Satellite M45-S331 Notebook
I dont find sound drive for this mdel
hi
go to this link
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
1, click Download
2, select laptops
3, select satellite
4, just scrol down you will fine M45-S331
5, and select go
6, select operating system
and download
have a nice day...
Jun 02, 2009 | Toshiba Satellite M45-S331 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
76 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
