Question about Dishwashers
Black Mold growing inside dishwasher
We just discovered black mold growing at the base of the door, around the seal.
  • lfrushton Dec 11, 2008
    Thank you, this took care of the existing problem. We found the real problem to be an installation issue; the hose from the disposal was not connected properly-which hopefully has been corrected now.
  • 41 Answers
This is an easy fix use 1 part bleach to 10 parts water and wipe down this will kill the mold you may need to do this several times
Posted on Dec 09, 2008
Mold in bosch nexxt 100 series- how to get rid of it?
yes bleach and a very hot wash. but remember mold grows in damp /wet so always leave door and soap draw open when machine is not in use this will dry out parts and cut down on mold growth ,
Sep 09, 2016 | Bosch Washing Machines
Black mold growing inside of the fridge
Scrub scrub scrub with a mild bleach solution, and then keep a couple of open boxed of Baking Soda inside, changing them frequently.
Inspect your door seals, I bet you will find a rip, tear or some other leak which is allowing warm, moist air into the fridge and encouraging the mold growth.
Also consider setting the temperature much colder to inhibit the mold growth.
Although there are many mold-killing solutions on the shelf at the hardware store, a good old fashioned mild Bleach solution is your best bet, as it is acceptable for use around food.
Jan 25, 2014 | GE Monogram ZIR36NMRH Refrigerator
Samsung mold issues dishwasher DMT400
Unfortunatly there is nothing you can do except clean it out every couple days, the way it's designed the water sits there after a wash and has nowhere to go so it just festers and molds over time, I put myself on a regiment to clean it out once a week. It sucks but that's all you can do.
Sep 08, 2012 | Samsung DMT400RHS Builtin Dishwasher
How to clean water tank as water dispenses with some black stuff
If you look up inside you will mold around the spout. this is were your black stuff is coming from. THe water system is completly sealed and cant be cleaned. However you can flush it. Use a cleaner with bleach in it to remove the mold from dispenser. You also may need to change the chute door . It leaking air is where the mold came from. Ihope this helps.
Aug 21, 2011 | Jenn-Air JCD2389G Side by Side...
Black scum forming forming on rubber seal on inside of washing machine door
  • 1 Put on rubber gloves and safety glasses before commencing the cleaning process.
  • 2 Lay an old towel or drop cloth on the floor under the front of the washer to prevent floor damage as you clean.
  • 3 Fill a plastic cup with bleach and dip a tooth brush into the bleach.
  • 4 Remove the toothbrush and scrub the washing machine gasket with it to remove the black mold from it. Hold the gasket open with the fingers of your other hand so that you can clean the center grooves of the gasket where the most mold is likely to grow.
  • 5 Rinse the toothbrush in the cup of bleach and continue cleaning until you have removed the mold from the entire gasket.
  • 6 Wipe the gasket with a paper towel to remove excess bleach residue and any remaining mold.
  • Jul 02, 2011 | Zanussi Washing Machines
    Black stains on door
    If it is inside, it is probably mold growing. Front loaders are much more susceptible to mold growth as they seal up tighter, and we all tend to keep the door closed when it is not in use.
    Clean the inner door and bellows surfaces with a 50/50 bleach/water solution, applying liberally, and dump the rest into the tub of the washer. Add 1 more cup of bleach to the tub. Fill all of the dispenser cups with bleach. Run the hottest , longest cycle available with the hottest rinse cycle available. For us, it is the "sanitary" cycle. Run a normal cycle immediately thereafter to flush out residual bleach, and leave the door open. The cleaning along with the air drying will keep the mold from growing, and reduce the odors that these machines are famous for. Leave the door open between loads.
    Best regards, --W/D--
    Jan 23, 2011 | Zanussi FJS1225W Front Load Washer
    Black mold in broken Dishwasher
    bleach is always good i suggest you cover the dishwasher with a good plastic film after you spay it with bleach to keep the mould inside it till you can remove it
    Dec 17, 2009 | Dishwashers
    Black mold growing on gray rubber boot inside door.
    Leave washer door slightly ajar after use to air out any moisture. Should prevent any future mold.
    Apr 10, 2009 | Frigidaire Affinity ATF7000E Front Load...
    Frigidaire Front load washer mold
    LEAVING DOOR OPEN BETWEEN USES ALLOWS WASHER TO BREATHE. BEING A CLOSED SYSTEM, IT'S KIND OF LIKE PUTTING A TUPPERWARE LID ON A BOWL WITH RESIDUE AND MOISTURE INSIDE AND LETTING IT GROW.
    Nov 03, 2008 | Frigidaire ATF6000ES Front Load Washer
    MOLD building on inside of dishwasher
    are your dishes comming out dry at the end of the dry cycle and during dry cycle do you see steam comming out of the vent
    Dec 31, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
    Dishwashers Logo
    1,642 people viewed this question
    Top Dishwashers Experts
