Router connections I have a desktop connected through a speedstream (non-wireless) router. I recently got a used laptop and purchased a linkseys wireless router for it. How do I connect the speedstream router to the wireless router so the internet can be used on both computers?
    Scholar:
  • 68 Answers
Is your speedstream router also your high speed modem? If so, you will have to go into the settings on the Linksys and change its IP Address subnet from 192.168.1.1 to 192.168.2.1 (or you can use a different number than 2) You will then need to reboot both routers (and possibly the computers) and try again. The easiest way to get into the Linksys settings is to connect it directly to the laptop via network cable, then type in 192.168.1.1 in the web browser. No user name and admin is default password. (Make sure you change that, and the name of the wireless, and the security settings)
Good Luck!
Posted on Dec 08, 2008
How do I discover or reset the password
Your modem if it is a Speedstream 5200 does not have any wireless capability and as such, there is no need for a password. You can only use one computer connected with an ethernet cable to your computer. What you can do is purchase a wireless router, preferably a N series wireless router because it is stronger than a normal G series router. Normally your modem connects to your computer via the ethernet cable. With a wireless router, instead of plugging the modem to your computer you should plug it in router. From the router you can connect another ethernet cable and plug it in on your desktop. You can connect at least 4 wired computer to your router. For the wireless part, all they have to do is look for the strongest wireless signal then hit connect. If it ask for a password then it should be in the sticker at the side of the wireless router.
Dec 14, 2011 | Efficient Networks SpeedStream 5200 Modem
Don't have security to key to access wirelss on laptop
Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Mar 26, 2010 | Linksys WRT160N Wireless Router
I'm having a problem with my NETGEAR WGT624v3 router. I have it connected through a SPEEDSTREAM 4200 modem and have experienced no problem with the internet connection. However, after approx. 3 to 4 hours...
yes set the speedstream modem to log in. it is uner advanced, usually 192.168.0.1 address. It is most likely set to "bridged" mode and using the router to login. set login to ppoe on speedstream on one p.c. only 1st. with login ang password filled in and "smart keep alive" on.
Oct 31, 2009 | NetGear WGT624 Wireless Router
Wireless Home network will not stay connected to internet
So you have a DSL modem connected to a router connected to a wireless router connected to both your computers? Sounds like you need to just get a wireless modem and throw all the routers away.
Jun 01, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Wifi
You need to purchase a wireless router. The router will have 5 ports on the back, one in and 4 out. The wire that you have going from your modem to your computer will go to the "in" port on the router. The out ports can be used for wired connections, and the wireless antenna will connect to any wireless computers.
Any computer that you want to connect wirelessly to your new router will need to be wireless-ready. For a desktop computer, you will need to buy and install a wireless PCI network card. Most laptops have built-in wireless.
You can buy a wireless router at most "big box" stores, like Best Buy, Office Depot, even WalMart sometimes carries them. A wireless router will cost between $75 and $150.
Jan 09, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
I recently purchased a new desktop which I had linksys connected to my old pc so that my laptop would work wirelessly. Both are Dell computers. I have a Linksys WRT54G router. I have Vista and the...
I don't see why not..
are you trying to hook up both computers to your linksys router?
if you have 3 computers now... I'm assuming your old pc was connected directly to the router, your laptop was connected wirelessly and now you have a brand new computer that you also want to connect to the internet using your lynksis router.. you should have not problems doing it, wirelessly or using a wire...as long as your router has ports avaliable...
Sep 21, 2008 | Computers & Internet
Siemens speedstream 2624
you have to configer your router are you using dsl or cabel inter net
cabel you dont need to set in log on but dsl you do
secound configer your router wireless i think you are are useing dsl speed stream bell use
Aug 15, 2008 | Siemens SpeedStream 2624 Router...
Siemens SpeedStream 6520 Wireless problems! please help
um not sure, but if you have the disk that came with your router run it and fill in the wireless wizard. Also, on my 6520 the "wireless" led doesnt light up unless i have a device connected that is wireless. Your laptop may be incorrectly setup
Jun 25, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Belkin wireless set up
Hi, As you ave the modem in bridge mode and also it works ine with wired connection just follow the instruction below for wireless
1.Login in to the router - > wireless settings
2.Configure your wireless using SSID and WEP and save settings
3.Laptop : Using windows wireless client configure the client using the same SSID ,WEP as configured in the router(view available wireless network in wireless properties)
(by default OEM wirelesss client takes over the wireless configuration in branded pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seq..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | Belkin (F5D7231-4) Wireless Router
Wireless connection
messege me on aim for me to walk your through step by step. Copter64
Jan 09, 2008 | Siemens SpeedStream 2624 Router...
Computers & Internet Logo
264 people viewed this question
David Payne
David Payne
