Question about Sony KDSR50XBR1 50" Projection HDTV
Cant find the lamp location on a sony KF50WE620 WEGA TV.
Hi. i've already taken the lower back panel off the tv and now i cant see a spot where i can easily remove the lamp with out having to take all the electrical components out. so without going any further i came to you guy's. i bought the set used without a manual. any help would be great thanks in advance.
  • Dennis Emerson Dec 08, 2008
    Thanks a bunch for the easy fix.
  • 505 Answers
The lamp comes out the front. Remove the two thumb screws on the back sides to unlock the speaker grill. It will have 3 very tough snaps also holding it on. Once you get that off you will find the lamp door. If the thumb screws are stuck tight, try using a nickel to get turning.
Posted on Dec 08, 2008
I have a kf50we620 and I". Experinceing blue streaks on the left side of the tv. Big blue spot upper left. Tiny blue spots when the tv turns on
it is colour patches.many tv's are this problem set right one or two days automatically.but not clear it than you take a external degauging coil and solve your problem. thank you.
Oct 11, 2010 | Sony Grand WEGA KF-50WE620 Television
I need to replavce the lamp on a KDF50we655 50 " TV. I unplugged all the cables and have turned the TV so the rear is facing me ,, how do I replace the lamp ?
Hi,here's how : You can find your original lamp xl-2100 right here: Have a bless one!
Apr 13, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Wheres is the lamp located on the sony wega 50 inch tv
remove the two small covers left and right behind the front lower panel.remove front lower panel (its a firm fit) pull in this sequence 1 rht top, 2 left top, 3&4 lower mid. lamp behind a panel just to the left of cantre, remove two screws locating it in place .pull lamp housing out
Sep 12, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Removing the front panel -bulb replacement
There is no other screws other then at corners at back of TV that you have already removed/ loosen.
Please pull lower front from its top corners as its lower part has hooks with bottom of TV front.
Below image will help you to remove front panel for lamp replacement in this TV..
Sep 11, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
How to replace lcd tv bulb
Most of those models you replaced them through the front. The lower front panel pulls off. Some models have a knob that must be loosen on the back of the set at each end. Once the front panel is taken off the Lamp door is easily accessed. The new Lamp from Sony will come with the proper Wrench to remove and reinstall lamp.
Hope this helps,
Jul 03, 2009 | LG RZ-17LZ40 17 in. LCD Television
Sony grand wega kf50we620
The manual is found at and it includes the instructions to replace the bulb.
Very easy to do. Good source is Ebay.
Note - you do not need the entire housing, just the lamp itself which is cheaper. I just purchased a lamp on ebay at arounf $160 including prompt shipment.
Jun 27, 2008 | Sony Grand WEGA KF-50WE620 Television
This sounds like the lamp failed. Check your owners guide for simple instructions on replacing the lamp yourself.
Oct 30, 2007 | Sony Grand WEGA KF50WE620 Television
Open Questions:
Sony KDSR50XBR1 50 black screen, no faults! Lamp working, fans OK Sony KDSR50XBR1 50" HDTV: The light engine was working fine before the fan quit starting on it's own. After disassembly, cleaning and lubrication of the fan, I have no errors but the input display or menu options will not post on the screen. The lamp is on but seems to either be projecting a solid black picture, or not be at full brightness and there are no faults. I have a solid greed LED on top, but can get no picture. Sound is fine. What should the lamp voltage be at operating mode? I have tried reseating connectors and pushing on the wires to make sure the connectors seat. This is baffelling because the lamp fired fine for 1 second before the stuck fan issue was corrected and I have no faults now after lubricating the fan. I'm going to check connectors again today as a triple check; as I did remove the power supply. The TV has been reset per instructions in the book. Any advice would be much appreciated but I cannot believe it's the OB as it worked fine before the fan quit and it's about 14 months old. I'm thinking something may not be assembeled correctly, but everthing seems to be pretty idiot proof for re-assembly. Also the menu or input banners will not post. I have 2 new lamps, so it's not that.It seems to be stuck in somne black screen mode. The large fan does start by itself now after cleaning and lubrication, therefore no fault blinks. Please help!!!
Mar 01, 2017 | Sony KDSR50XBR1 50" Projection HDTV
Sony KDSR50XBR1 50" Projection HDTV Logo
88 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
