Question about Goodmans GPDR40 Digital Media Player
GOODMANS GPDR40 Can the GPDR40 be connected directly to a DVD player via the red,white and yellow leads to transfer films to the unit.
    Problem Solver:
  • 5 Answers
It can record anything.
Posted on Aug 18, 2007
  • 3 Answers
14 August 2007 - Yes it can be connnected like this and will record, even if there is copy protection on the video or dvd - it just ignores the protection. It would be a useless bit of equipment if it couldn't to this basic task. Regards
Posted on Aug 14, 2007
The answer is yes "But only with non macro protect DVD therefore any DVD recorded from home movies can be transfered to the hard disc you can also record off a freeview box.
Posted on Mar 09, 2007
Need installation disk for goodmans gpdr40
go to the mustek site & download the software for the h140 , it is the same software as I have both units , the only problem is neither vista or windows 7 will run the software
Apr 06, 2010 | Goodmans GPDR40 Digital Media Player
Where to get new batteries for the GPDR40 as mine will not hold charge for more than few minuets
Try this website.
Click on "Contact Us"...and the follow the directions, I am sure they will be able to help you
Good Luck,
I hope this helps
http://www.goodmans.co.uk/productdetails.aspx?pid=GPDR40&language=en-GB
Oct 30, 2009 | Goodmans GPDR40 Digital Media Player
Can i put camcorder footage onto dvd recorder
You can do this digitally on a computer using Adobe Premiere Elements.
http://www.adobe.com/products/premiereel/
Jun 22, 2009 | Goodmans DVD3000 DVD Player
Footage transfer
here....http://cgi.ebay.co.uk/AV-USB-VHS-TV-to-DVD-Capture-Card-S-Video-Grabber-Y35_W0QQitemZ120367919357QQcmdZViewItemQQptZUK_Computing_Computer_Components_Graphics_Video_TV_Cards_TW?hash=item120367919357&_trksid=p3286.c0.m14&_trkparms=72%3A1300|66%3A2|65%3A12|39%3A2|240%3A1318
that one is in hong kong, but that is what I used time an time again. Just install the software, plug in the device, connect the red yellow an white leads to the red yellow an white leads that plug into the camcorder somewhere an off you go
Jan 18, 2009 | Sony Handycam CCD-TRV68 Camcorder
Dvd player not connected properly to TV?
You might need one or both of:
RF modulator.
AV switch (perhaps from an old video game console)
The modulator accepts the RCA plugs from your DVD player (yellow, white, red) and outputs an RF signal.
You can then plug the ouput of the modulator into the aerial input of the skybox, via the switch, if desired.
Sep 28, 2008 | Cyberhome CH-DVD 300 DVD Player
Goodmans GPDR40 problem
I had the same problem like everybody else since 2005 . GOODMANS GPDR40 X-Pro personal Media Centre. After Initialise the screen freezes - MASS STORAGE
DIRECT PRINT.
I have suspected that was the battery at fault or something to do with the power.
Why?.Because i have managed to let the Goodmans work, but only for a long time when
connected to the main adaptor.
I use it to record Video from sky,Or to use the unit as a storage drive.
Here are the steps to regain possession of the Unit.
First discharge the unit by leaving the screen on when in direct print mode,
(Move the cursor down to access this mode, normally it does this automatically.)
Make sure the screen display stays on in order to help the discharging of the battery.
Having the screen on will not switch the unit off until the battery is flat.
To have the screen on press the top button again if the display revert to a blank screen.
Once the unit is discarged the the unit will turn itself off.
Now we can connect the power lead to the unit and start the unit once more.
It normally last a couple of hours or more,but it will stop again eventually.
My suspicion is that the battery charger control is not working right and
after a period of time, may be a year ore less, will cause this problem
to all these units.
I hope it works for you too, even if not as before.
Ciao a tutti!
You can contact me at this email address:
messinasergio@yahoo.com
Apr 10, 2008 | Goodmans GPDR40 Digital Media Player
PLAYING DVD
check your connections on the back of the tv and back of the dvd player. make sure you are using the proper conections on the back of the tv. if you connect the RCA (composite) cables (red yellow white) you should be going from the red yellow white on the tv to the red yellow white on the dvd player. if you have the component(red blue green) connection on the dvd connected to the red yellow white on the tv, you may get a black and white picture. If this does not work, check the manual for the dvd player and see if there is a way to turn "Progressive Scan" features off, some older TV's cannot handle a progressive scan dvd player.
Aug 13, 2007 | Koss KS2503 System
GPDR 40
1. you need to install the pc software 2. you need to connect the system to your pc via the usb cable 3. switch the system on - it should be seen as a mass storage. 4. Start PVR Console and run a disk checkup - this should run without error - run this twice. 5. Try the unit now - does it work? 6. if you still have problems you can replace the files in pvr data with the following:- http://mustek.com/product_resources/drivers/pvr-upgrades/pvrh140-datafiles/pvr-h140_restore_files.zip good luck Ian
Jul 13, 2007 | Goodmans GPDR40 Digital Media Player
Screen freeze.
Apr 16, 2007 | Goodmans GPDR40 Digital Media Player
Trouble starting up
Dec 15, 2006 | Goodmans GPDR40 Digital Media Player
Goodmans GPDR40 Digital Media Player Logo
63 people viewed this question
Top Goodmans Audio Players & Recorders Experts
Cliff itsasecret
 Grubhead
Grubhead
Tom Chichester
Are you a Goodmans Audio Player and Recorder Expert? Answer questions, earn points and help others
