Question about Air Purifiers
Ionic Breeze Quadra
Yesterday I discovered (after taking the back off) that one of the wires inside was broken. Sharper Image is bankrupt and I am wondering if I can still find replacement parts for this. Any help to this matter is greatly appreciated as I am having a hard time trying to find replacement parts.
steve
  • Anonymous Dec 18, 2008
    I have the exact same problem. I am wondering if my local repair shop can repair it, if not then I imagine that we could get some fine wire and string it between the two terminals.
  • Anonymous May 25, 2009
    my hybrid GP has two broken wires...argh.
SOURCE: Ionic breeze Quadra S1637
What is a grid and what is a grill when referring to the Ionic Breeze Quadra?
Posted on Aug 26, 2008
  • 6 Answers
SOURCE: Ionic Breeze Quadra won't turn on
Okay, after working on my Ionic Breeze Quadra I have fixed it. My problem was it wouldn't turn on even though the fins were clean.
1. Unplug
2. Turn the machine upside down (there are 4 screws holding the bottom stand on) remove the screws
3. once bottom is off there are 2 screws sideways helping the hold the 2 sides together. Remove those 2 screws.
4. Turn the machine uprgiht and remove the middle fins (the ones you clean)
5. Remove the 4 screws that are deep in the 4 holes when you look down inside (you can't see the screws, I had to feel for them with a phillips head narrow screwdriver)
(it will be easier if your screwdriver has magnetic head for next step.)
6. after removing the 4 screws gently work lose the top (part that has the little lights and turn on push switch)
7. turn the breeze on its side, you will find about 5 or 6 tiny screws holding the two sides of the outside louver case together. Remove all these screws. You will be thankful for the magnetic end, I have small fingers and still had a problem catching the little screws.
8. You don't want to remove both sides, just one side is fine.
9. Being careful of the wires (I left that side alone) I worked from the wire free side and using a bottle of rubbing alcohal and lots and lots of q-tips I gentle cleaned off all the gunk on all the little metal pieces at the bottom of the breeze (on the inside where the wires are). Clean as good as you can, you will find the metal pieces covered with what looks like tar but it comes off with the alcohal.
10. Using a can of 'canned air' like you'd use for a computer, gently blow the rest of the breeze parts getting all the dust away but being careful not to damage the electronics. (there are a lot of little computer boards). I didn't find any dust in the electrical parts in the very bottom of the breeze, just above where the fins are and some at the top where the controls are.
11. I cleaned the 1/2 I took completely off with some rubbing alcohal, gets that **** off pretty good but didn't mess with the side with the wires, just blew the dust out, gently cleaned a bit and on the outside.
12. To put back together, first I gently put the outer middle pieces together and then gently put the control top back on and replaced those 4 screws. Then I put the 10 or 12 tiny screws back into the middle, then the 2 screws in the bottom sides and 4 screws putting the stand back on. I stood it up, plugged it in (make sure its dry) and turned it on and the light came on and it is working great.
I've had mine for 3 years so I think they occasionally need a thorough cleaning. Except for the canned air I bought nothing else. Everyone has rubbing alcohal and q-tips in their homes. When I first started I didn't know how to dismantle it and tried to clean the inside with long q-tips but it was too hard. Those little metal pieces in the bottom make some sort of connection to the fins we pull out and clean so I guess they need good contact.
I hope I've helped all of you with the problem of the Ionic Breeze Quadra and I suspect any other iconic breeze type machine by sharper image pretty much comes apart the same way and may have the same problems. I don't know how to post this so that everyone can see it as a general solution. Maybe you guys at FixYa can help with that. --- Harry Potter Without the Wand (and a female to boot!)
Posted on Mar 08, 2009
localwonder
  • 6784 Answers
SOURCE: I have several ionic Breeze air purifiers that have problems
Unfortunately, there are no repair depots that are available for use since Sharp Image has claimed bankruptcy. these product are very unique in design and, the actual repair parts are no longer in stock. the suppliers went under when Sharp filed for bankruptcy.
You may be able to repair the wiring by ordering the identical gauge from you local electrician but, that's about it. most of the hardware is no longer available.
Posted on Jun 18, 2009
  • 94 Answers
SOURCE: Need Blubs for the Ionic Breeze GP
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} You can purchase a bulb for the GP on ebay for under $11, which is really a good price considering what you would have paid from Sharper Image. Installation is easy, you just pull up on the tab on the bottom of the filter and pull up. When you are looking at the bulb, turn it 1/4 turn, (2 clicks) and pull it out. That is all there is to it. Item Number: 220444965077
Posted on Jul 04, 2009
  • 94 Answers
SOURCE: Is my Ionic Breeze Quadra hopelessly broken and beyond repair?
This unit can be replaced on ebay for around $45.00 which is under any labor cost to repair the unit you currently have. You can always post your unit for sale on ebay for parts.
Hi, I have the ionic breeze germicidal air purifier floor model. One of the wires inside has broken. Can I get this fixed?. Thanks for any help you can give. Joyce Turner
Joyce, according to Sharper Image, if you purchased it online from Sharper Image after 2008, they will assist you with the repair. Call Customer Service 877-714-7444 . If that is not the case, you can either return it to the place of purchase for repair or take it to a small appliance repair shop,
Apr 21, 2011 | Sharper Image Ionic Breeze® Quadra® 4.0...
I have a sharper image ionic breeze professional series and paid a preety penny too. one of the wires inside rusted and broke, it lights up but no breeze is comming from it and the green light doesnt come...
If you're referring to one of the ionizer wires (wire that has beads on it to clean the wires) then unfortunately, I'm afraid the unit can't be repaired. As Sharper Image has no authorized repair centers or replacement parts. If you're referring to wiring in the base of the machine, then a repair could be affected by either cleaning off the wire ends and reattaching them with a small piece of wire or soldering the broken wire back to the unit itself. Sadly, many of us (myself included) spent a lot of money on these units and the only place I've found parts is a website called http://breezerepair.com/parts.html (not an authorized repair center) but of the parts they have carry, they don't have the wire you referred to. Sorry to be the bearer of bad news.
Nov 07, 2009 | Sharper Image Professional Plus Ionic...
It emits a metallic burning odor.
The trouble began in 2003 when Consumer Reports magazine published a report claiming the expensive air cleaners don't clean air. The magazine later claimed its tests showed that Sharper Image's Ionic Breeze Quadra Silent Air Purifier and four other units also release potentially unhealthy levels of ozone.
Read more: http://www.consumeraffairs.com/news04/2008/02/sharper_image.html#ixzz0VATFAuRq
Oct 27, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Broken "wire/filament' in ionic breeze quadra
This does NOT work. The electric guitar wires burn out in 1-2 months.
Jul 13, 2009 | Sharper Image Professional Plus Ionic...
Feb 19, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
How to get replacement parts for Sharper Image ionizer?
one of the electrodes broke off the botto of one of my towers.
Dec 26, 2008 | Sharper Image Professional Plus Ionic...
Ionic breeze quadra
If you are talking about the 2 thin wires inside the unit, it can be fixed if you are good with taking things apart. You have to do an almost complete tear-down of all the internal components (many hidden screws). You can replace the broken wire with a .009 or .008 gauge E string for an electric guitar. This can be found at a local musical instrument store. The string must be cut to almost the exact length. The wire has a spring tension mount on a small circuit board. If the replacement wire is too long, there will be too much slack, too short and you will not be able to put it back together. I did this and it took me hours. I removed about 80 screws to disassemble it.
Nov 03, 2008 | Sharper Image Professional Plus Ionic...
Quadra - only red light goes on.
In addition to cleaning the plates on the cartridge, also turn the unit upside down then right side up a few times. There are 2 small wires inside the housing, and each has a ceramic ball on it that cleans the wire when the unit is inverted. Also, look through the vents to make sure the wires are not broken. If they are intact, they run in a straight line, almost the entire length of the unit.
If this does not help or the wire is broken, contact The Sharper Image. I believe this unit has a 5 year warranty. When mine failed, they exchanged it for free, even without a receipt.
Jul 12, 2008 | Sharper Image Ionic Breeze GP SI720 Air...
Air Purifiers Logo
281 people viewed this question
Top Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Air Purifier Expert? Answer questions, earn points and help others
