Question about NEC Electra Elite DTU 16D-2 Corded Phone
Electra elite IPK Problem
When I log into my voice mail it gives me a busy signal How to I fix that.
    Problem Solver:
  • 13 Answers
There are several things that could be causing this and it depends on how many conversations (ports) your voicemail can handle.
1. The voicemail ports could all be busy. Dial vociemail when you know nobody is using it. If you can get in then there is nothing wrong except that your voicemail system is busy and you may need more ports.
2. If you are pressing a button on your phone, then the button may be programmed incorrectly. Using the dial pad, manually dial the vociemail and see if you can get in.
3. As a last resort, you can turn the phone system off for 10 seconds and then turn it back on. Do this with caution however and make sure nobody is using the phones. You also run the risk of defaulting the programming on your phone system. If the voicemail ports have locked up, this will clear the locked ports. If this happens again (busy) hopefully it is under warranty as either the voicemail is going bad or is misprogrammed.
Posted on Dec 08, 2008
Dtu 16d ringer is off at other stations. I need to get the phone to ring on the other stations.
Hello, That would be a system ring group programming feature. It would depend on the type of phone system you have. NEC Elite 192, Elite IPK, Elite IPK 2. There are different platforms and this would determine how to program it.
Mar 04, 2015 | NEC Electra Elite DTU 16D-2 Corded Phone
How to change from lunch to day mode
These phones work on about 8 NEC systems, but for a PRO II, an Elite, and an IPK, the standard code is Feature,80, Feature from one of the two main reception extensions. Don't know the code for a 2000, 8100, or IPK II.
Jul 11, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
How do change the outgoing "Night Mode" message in the Voice Mail System on NEC Electra Elite DTU 32D-1?
If you are using an Active Voice product (typical w/ NEC) you need to change the hours of operation on the voice mail system. "Night Mode" only changes the ringing characteristics of the phone system and where calls ring, not the greetings that play on the voice mail. The voice mail plays a particular greeting (Day/Night/Holiday) based on the time of day specified in the schedule. The system administrator for the voice mail would have to make this change.
Jan 24, 2012 | NEC Electra Elite 32D-1 Corded Phone
My voicemail has been set up, but it will not answer calls.. it rings and then rolls back into the main message for the office
Set your Call Forward Busy/No Answer to go to voice mail ext. as follows: Lift the handset, dial 4 then 3 followed by the voice mail ext. (the number you dial to retrieve voicemail messages). Hang up.
Jul 26, 2011 | NEC Electra Elite 32D-1 Corded Phone
How to change time on NEC Electra Elite IPK? I
You have to be on the root phone or "first phone".
To check various phones -Hit {feature} 4.
Should display 100= TEL 01. Once on the first phone then use {feature} 9 #.
Time will flash at top of display and can be adjusted.
If you are not on the first phone you will get error at the top of the display. Leave the hand set on the hook.
Mar 11, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
IPK II system. Voice mail
if you mean calls do not go to your voicemail try hitting speaker key then dial 43 and then enter voicemail pilot number
Dec 26, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Changing amount of rings when going to voicemail
The call forwarding was turned off. To turn on, press speaker, enter 793, press 1(for set), press extention number, and enter 300. If you have call forwarding on and are looking for more rings, do the above steps except press 2 (for clear).
Nov 19, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC Electra Elite DTU 16D-2 Corded Phone Logo
395 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
