Question about Panasonic PT-43LC14 Television
Split screen how can i watch one channel then switch back and forth between the say two fotball games using the split screen and how do i wire it to operator using this feature
  • 51 Answers
Use a vcr with a tuner or modulator so that you have two tuners for the separate channels. The tv has one tuner and Pic in Pic requires two tuners or sources.
Posted on Dec 08, 2008
What are instructions for Split-screen TV? Used before, forgot.
You are referring to a picture-in-picture function on hour TV. It is usually done by a button on your remote control marked PIP - picture-in-picture. If your TV doesn't have this function you can get it by using your SET-TOP BOX, which supplied by your TV cable company. All modern remote controls fro those boxes have that ability. In this case you will be able to watch two channels at the same time, switching them around and control them the way you want.
Nov 09, 2014 | Protron Televison & Video
Super nintendo
Original-Style Super NES RF to VCR Hookup
Installation Steps:
Locate the VCR's VHF IN [ANT, CATV, 75S(ohm)] or Cable Connector.
Disconnect the existing cable wire from the VCR's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your VCR's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire from the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
On the back of the Super NES, set the 3/4 switch so that it matches the channel of the VCR. Note on Sharp TV/VCR Combo
After the system is connected to the VCR:
Insert the Game Pak firmly into the Control Deck.
Plug the controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Slide the Power Switch to the On position.
Turn your TV and VCR on. Set up your TV and VCR the same way you would to watch a movie on the VCR.
The game image should now be displayed on the TV screen. You are ready to play!
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck using the Stereo Audio/Video Cable.
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Feb 10, 2013 | Nintendo Super NES Console
My nintendo 64 is split screen everytime i turn it on with every game - i can only see half the game . please help!!!!
Well if you are using the rf switch way it only works on channel 3 or channel 4 then.
No other channels work for it.
Mar 26, 2011 | Nintendo 64 Console
Creen splits into 2 images
Well I think that you need the av cables for it to work on a digital tv not the rf switch.
Jan 27, 2010 | Nintendo Super NES Console
Recording cable channels while warching other channels
To be able to watch one, record another, you have to split the cable when it comes into the house. Have one input go directly into the TV and the other into the Cable Box. Then hook the cable box to the DVD, then to the 2nd input of the TV. You will have to switch back & forth from your TV video inputs, rather than switching at either the DVD or Cable Box.
Jan 31, 2009 | Sony RDR-VX521 DVD Recorder/VCR
Explain function butons on remote
the only way this will work is to be on one of the channels you want then push in the numbers of the other channel you also want to watch , then there is a last or back button on the remote that will switch back and forth to those channels untill you change the channel to another , then it will switch back between those last two channels
Dec 12, 2008 | RCA DIRECTV Satellite Remote Control
TV freezes when switching to a digital channel
The problem your describing can be contributed to your cable box. Depending on your cable company there are times when the box has trouble translating the signal to the tv. You tv is operating normally. Suggest to the cable company to switch your box.
Dec 05, 2008 | LG 32LG40 32 in. LCD HDTV
Split screen
Yes I get the same problem with my Sony XBR and its Pace PVR.
The problem seems related to using HDMI interconnects; viewing the PVR through component leads allows the TV to switch modes easily, otherwise I have to turn the tv off and then back on again.
Nov 14, 2008 | Panasonic PT-52LCX66 Projection Television
No main video
It deffinitely sound slike it is a relay or transistor that is either burned out, short circuited, or not working. if you have a ny replacement parts, and feel daring enough, try replacing on of the boards that controls the PIP
Jan 22, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-43LC14 Television Logo
64 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
