Question about RCA F25442 25" TV
KEEPS POPING UP GUIDE PLUS MENU
MY TV KEEPS POPING UP THE GUIDE PLUS MENU WHEN YOU TRY TO CHANGE THE CHANNEL OR TURN THE VOLUME UP. PLEASE HELP ME
Yes i have a atc113 chassis and i have the same problem im working on the tv as we speek for my grandmother i have a few things i have found wrong and i see that u just posted so i will give u a reply in a few days or u can email me at nissanman12@cox.net my question to you is are u working on this urself
Posted on Dec 11, 2008
  • 105 Answers
Try to change all the micro switch button on the pcb board
Posted on Dec 08, 2008
Channel input displays keeps blinking
this is a faulty Main controller Board
part number : 715T2300-3
hope 2 help
www.bostonrecycling.net
LCD PARTS / PLASMA PARTS / LAPTOPS PARTS
Jun 25, 2012 | Dynex DX-LCD32-09 LCD TV
Channel wont change. the numbers change but the picture remains the same. always on channel 3. help
Look to see if "GUIDE PLUS" logo is on front of set, if so it is your problem.
Go into customer menu and setup for Guide Plus and enter area code 99999 and when it asks if you have cable box or vcr answer/select NO, the guide plus is your problem.
Try and if this resolved your problem rate this solution as VERY HELPFUL as I do this here for free.
SD TECH
Sep 21, 2010 | RCA P52926 52" Rear Projection Television
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
TV problem 46GW948 GE 48? Thomson Guide Plus GemStar
i hope this helps. on the tv, press menu, then channel up or down to "screen", then menu;
then channel up or down for adjust projection tv(6), then press menu;
then use the volume up and down, as well as the channel up and down until each of the 3 colors are lined up. press menu after each color i slined up to go to the next color.
hope this helps.
May 29, 2008 | Televison & Video
Hi I have a rca tv that has guide plus on it , But I have lost the remote and the demo keeps popping up. Is there a away to take it off without the remote control?
yes U can use volume up and down channels up and down and menu key as ok key look in the guide plus is and option to turn that of just play with if still having problems let me know and I' get the steps to get rid of
Apr 17, 2008 | Televison & Video
RCA TV won't change channels
Your set uses the 195 series chassis and you have something set wrong in your guide plus. Go into the TV's menu and do a complete set-up. Take the remote and press MENU, then "8" to enter setup, then press "1" for "begin setup now" and then press "1" for English, and so on. You must enter "set up guide plus+", then press OK on the remote to choose "setup", select "USA", enter your zip code, and then if you choose "yes" for "do you have cable?" you MUST then choose "no" for "do you have a cable box" If you choose "yes" for that choice, your tuner will lock on one channel no matter what channel you try entering. After choosing "no" for "do you have a cable box", choose "no" for "do you have a VCR?", exit the guide plus menu and then skip the rest of the steps by pressing "2", and then exit the main menu by pressing "0". Your channels will then work normally.
Aug 29, 2007 | RCA P52937 52" Rear Projection Television
Erratic behavior...
Change all the little switches (on-off, channel up etc). If just one of the switches is intermettent, or a combination of one or more, it can cause you moe misery than you can imagine. The switches are not expensive but can cause you to lose an awfully lot of time and agravation.
Nov 24, 2006 | GE 31GT740 31" TV
RCA F25442 25" TV Logo
108 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
