Question about Canon PowerShot A80 Digital Camera
Canon a80 lcd screen
My canera has just been repiared at an authorised dealer as oit wass dropped whilst on holiday. since this i have noticed that there are llines across pictures and if you touch the lcd screen on rear of camera lines go across it and it flashes as if a connection is being broken. any help please ?
  • philip warner Feb 24, 2007
    Thanks again, i have returned it,
    Novelist:
  • 107 Answers
The LCD screen's connection to the circuit board is not seated properly, or the LCD screen itself is defective. You are correct in that when you touch the screen you are affecting a bad connection. You should take the item back to the place that repaired it, or find another service center if they will not fix the problem for free. This is either a problem with their workmanship or with the LCD they installed.
Posted on Feb 24, 2007
SOURCE:
The camera is shooting, pictures are taken- however i simply get a white screen and the picture stored is also white only
Refer to this service notice from Canon. If you can see icons on the LCD, and can view photos you have taken in the past, you probably have an image sensor (CCD) failure. If Canon determines this is the problem, they will repair your camera at no cost, regardless of warranty status.
Feb 10, 2010 | Canon PowerShot A80 Digital Camera
Canon Power Shot A80 LCD screen not working.
http://www.fixya.com/support/r1237608-canon_powershot_cameras_pink_black
It seems that this is a problem with some of the canon pwershot series.
Please check out the link above regarding the same. It might help before you decide on repairs.
Please rate this solutions and thanks for using FixYa!
Mar 09, 2009 | Canon PowerShot A80 Digital Camera
LCD screen purple and distorted in Shooting mode
There is recall on this model for this problem, Go to Canon USA web site, Look up Service advisory, CCD malfunction N/C to repair.
Feb 24, 2009 | Canon PowerShot A80 Digital Camera
LCD screen doen't display the view
So camera doesn't give live view to take picture? and you can view old / stored  pictures OK, is it?
If yes, then it is problem of CCD imager in Canon A80 and this part needs to be replaced.
Canon will repair your A80 free of cost as per announced scheme of CCD imager support.
Click Canon CCD Advisory to know how to get free repair facility.
Jan 07, 2009 | Canon PowerShot A80 Digital Camera
Vertical lines obscuring image
The matrix is dead. Probably because of an intensive light got into the lense while the camera was in night mode. It's dead. Nothing can be done.
Jul 24, 2008 | Canon PowerShot A80 Digital Camera
Canon Digital Camera
are you able to see the icons on the lcd screen ( you can check it with pressing display button)
If yes, then
There may be the shutter was not opening. So you need to contact Canon authorised service center.
OR
There may be the CCD is faulty:
To resolve this problem, you need to contact Canon Authorised Service Center. They will replace the faulty CCD free of cost even the service charges are also not applicable for this perticular problem in some models.
Jan 13, 2008 | Canon PowerShot A560 Digital Camera
LCD screen broken from being dropped - just a black splodge!
Replacement parts for digital cameras are hard to come by. even if you could find one, the electrical connections inside the camera is more problematic. the best suggestion is to take it to a camera shop and see how much the repair cost would be, (probably over $100). if you do not want to invest that in a repair, there are some really good digital cameras out there for about the same price as the repair. If you want to try finding an LCD screen for your camera, try Camera Repair Japan, CRJ, located in Duluth, GA, phone # 770-849-0555. Good luck.
Jan 11, 2008 | Canon PowerShot A80 Digital Camera
LCD won't work in shoot mode, but work in playback mode
It's unusual that you can review pictures, but not see the menu. Take a picture with the camera. If this picture shows up black, then it's probably be a defective CCD imager. If so, Canon will fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Nov 01, 2007 | Canon PowerShot A80 Digital Camera
Canon a80 camera
It seems that either the image sensor or the connection between the image sensor and the processing board has been damaged or was improperly installed. If you sent it in because the lens was jammed it is highly likely that this is what has happened. See if you can get the facility who repaired it to cover the re-do, in the end it is their fault if your CCD is defective now and was not before the repair. However - if the camera was non functional after you dropped it they could very well say that the impact caused the problem. You might have no options besides either dealing with the issue or replacing the camera. David Millier Advance Camera Repair
Feb 09, 2007 | Canon PowerShot A80 Digital Camera
Canon PowerShot A80 Digital Camera Logo
94 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
