Water heater burner will not light
Pilot lights with no problem
  • Anonymous Dec 19, 2008
    pilot is on but burner is not on
  • 1,420 Answers
Make sure the thermocouple is in the pilot flame. After you get the pilot to stay on, turn the gas valve to the on position. If it still does not light, lightly tap on the gas valve. Make sure there are no other safety switches that may be affecting the heater.
Posted on Dec 08, 2008
Junkers manual gas hot water
What are you expecting to happen?
I assume the water heater and water inside it is cold (otherwise you would not be lighting it). You light the pilot. The main burner comes on and the pilot lights it. The main burner should stay on until the tank is hot, When the tank gets hot the main burner should shut off but the pilot stay on. If you draw hot water, cold water will run in and cool the tank. If yu do nothing the tank will eventually just cools off. then the main burner should come back on to reheat the tank.
Nov 05, 2013 | Water Heaters
I turned on hot water to take a bath, and it was hot. by the time the tub had filled the water was freezing. now we cant seem to get hot water out of anywhere. the pilot light is on. the knob is set to on,...
if I was a betting may I would say that this is a small water heater, what is the temperature set on, as the pilot light will be lit once the temperature is reached, but until then the burners will be lit. I would move the temperature knob and listen to see if I hear the burners kick on. Hope this helps Tim
Apr 17, 2011 | Heating & Cooling
Adjust pilot light on hot water heater
On most water heaters there is no adjustment to pilot light. About the best you can do is clean pilot and burner. If you are having trouble keeping pilot light lit then I would replace the termocouple.
Nov 16, 2010 | Water Heaters
Pilot light keeps going out
Either the pilot light orfice is dirty, and you will need to pull it out and clean it, or the thermocouple is bad. If the pilot goes out as soon as you let the button go then it is most likely the thermocouple. If the pilot stays lit for a few days or hours then you will need to clean the pilot orfice, heres how:
1 turn off the gas supply
2 unhook the main burner gas line from the thermostat, this is the line that goes to the burner
3 unhook the pilot supply line it is usually next to the main burner line
4 unhook the thermocouple from the thermostat
5 remove the burner assembly
6 take the orfice out of the pilot line and clean it out by blowing thru it, use an air compressor if needed.
7 reassemble and light pilot
Apr 08, 2010 | Reliance & 30 Gal LP Gas Water Heater
The pilot light blows out every time the main burner shuts off. It will light, the main burner comes on, everything seems ok until the main burner shuts off, then the pilot light goes off also as if the...
it's the thermocoupler ( about $20 ) that is bad replace it. if that doesnt do it it is the box with the on/off/ pilot button ( about $175 ) I found a complete unit at for $275 plus shipping ($300 total) and that is how i fixed the exact problem with mine.
Oct 07, 2009 | RTO Atwood Water Heater - 6 Gal LP
The pilot light & will stay lit. untill the burner cycles on/off
Oct 05, 2009 | RTO Atwood Water Heater - 6 Gal LP
The pilot light on my gas water heater continually goes out. I can re-light the pilot and get it going. The gas burners goes on runs for awhile. I'm assuming when that when the temp hits the desired temp...
The pilot assembly should look similar to the pic above. Depending on where you live, you may be required to hire a certified plumber to replace the parts. If not you can do it your self. Keep in mind if it's not staying lit you also need to check the thermostat and the thermocoupler before replacing the pilot assembly. There is a good chance it is just the thermocoupler going out. It is one of the first things to check when troubleshooting a pilot light problem with a gas water heater. A thermocouple determines if the pilot light is lit. If it's not lit, the gas valve fails. If that's the problem, replace the thermocouple.
  1. Shut off the gas valve on the water heater and the gas valve on the line near the heater. Remove outer and inner doors, and loosen the pilot and supply tubes and the thermocouple connections to remove the burner assembly.
  2. Step 2 Loosen the screw holding the thermocouple to the bracket. Remove old thermocouple. Bring it with you to the store to ensure you are buying the proper replacement.
  3. Step 3 Install the new thermocouple. Position the thermocouple so that the pilot flame heats 1/2 inch of the tip.
  4. Step 4 Reinstall burner assembly in the water heater. Tighten burner supply tube, pilot tube and thermocouple connections. Tighten thermocouple no more than a quarter turn more than hand-tight.
  5. Step 5 Turn on both gas valves. Check supply tube and pilot tube for leaks with soapy water. If soap bubbles, tighten connections to fix leak. Ignite the pilot light, and make sure the thermocouple tip is heating up. Replace inner and outer doors.
Jul 09, 2009 | Northern Tool Water Heaters
No hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
May 05, 2009 | Bosch & Tankless LP Hot Water Heater
Heating & Cooling Logo
164 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
