Question about Bissell 1770 QuickSteamer Upright Vacuum
Amounts of Solutions
I have misplaced my manuel and am not sure what parts of water and solution to use.
    President:
  • 1,901 Answers
From the manual:
1. Remove the Clean/Solution Tank by lifting it
straight up, then away from the Lower Body.
2. Unscrew the black cap at the bottom of the
Clean/Solution Tank.
3. Add one of the BISSELL Advanced Cleaning formulas
for Deep Cleaning machines to the formula fill
line on the Clean/Solution tank. Fill the rest of the
tank with hot (not boiling) tap water to the water
fill line. Replace and tighten the black cap.
4. Place Clean/Solution Tank on Lower Body.
The manual is available at retrevo.com, but you have to register to get it. It doesn't open up so that I can link you to it. It doesn't cost anything though.
Hope this helps!
Posted on Dec 08, 2008
How do I change the belt
turn the power head upside down. There should be a latch to open. the belt goes from the center of the floor brush to a piston on the motor. It helps if you have the old belt to get the correct size.
Feb 11, 2015 | Vacuums
Bissell instruction manuals
You should be able to get parts from the Bissell Consumer Care at 1-800-237-7691
Aug 24, 2014 | Bissell Flip-It Select Hard Floor Cleaner...
Does not dispence water and cleaner consistently.
If you have stored your cleaner with cleaning solutions in it you have a broken impeller in your water pump. The cleaning solutions separate while in storage and build up in your pump. Once you start the cleaner is breaks the plastic impeller. Its an in-expensive part but, a real pain to change.
Feb 15, 2011 | Bissell Carpet Cleaner Powerbrush Deep...
I misplaced my manual for my sunbeam model 1128 warm mist humidifier and would like to know how to clean it....there is a white powdery stuff coming out of the base, how do i get rid of this....or could a...
the white powdery stuff is minerals, use a vinegar solution to warm water 1 part vinegar to 4 parts warm water. let it soak in the humidifier overnite or during the day and rinse with warm water. You could also use clr using bottle directions.
Dec 03, 2010 | Vacuums
WATER TO RICE AMOUNTS
Here is a tip that will help you figure out about using a rice cooker...
How much Rice and Water go in the Cooker
heatman101
Sep 25, 2010 | Vacuums
I knocked my savvy over and the cannister came out. misplaced the manual.need instrucytions how to reinstall the cannister.
aline the canister with the machine, handle facing out and push it in. if you go to hoover.com you can download the manuel for this machine. just remember not to put the dash in when entering the model num.
hope this helps
Jul 31, 2009 | Hoover U8181-900 Savvy Upright Vacuum
Where do I put the water.
1. Release the handle and lay the machine
handle back to access the tank.
2. Remove the tank from the base of the
machine by lifting the tank carry handle.
3. Carry like a bucket to the sink. Rotate the handle forward
to unlatch the lid. Lift off and set the lid aside.
4. Fill up the bladder with clean hot tap water.
*Do not boil or microwave water as it can
destroy the bladder.
5. Replace the top of the tank by matching the
lid and tank edges. Handle must be in the
forward position in order to replace lid. Rotate
Note: Remember to secure the lid and test to make
sure it is secure before picking up the Tank.
6. Place tank into machine base, seating firmly in place.
Rotate tank handle back into latched position. Bring
machine handle back into upright position.
You can download the manual from the Bissell website www.bissell.com
Jan 28, 2009 | Bissell 1699 ProHeat Clear View Upright...
Leaking from bottom
It is the steamvac pump that is bad. When you fill up the tank with solutions, even though it is not running the solution leaks out, and when you turn it on it sprays up and out the sides etc. Also the attachment doen't work either, no solutions comes out. Apparently the float sticks in this. My husband fixed it once, and now he can't, need a new part. Options are take it to a hoover service dealer, or I found 2 place online that sell the part. One is http://buyitnow64.stores.yahoo.net/hostrepufor5.html and the other is http://www.sweeper-city.com/ho5brstpu.html, this site if you look at different size pumps have a description of the problem: "If your Hoover Steam Vac is leaking or water will not come out of the attachment hose, then this is the part that you probably need !!!
This part is for F5914-900 model. Hope this helps
Aug 29, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Manual for F5835900
Check the filter inside the dirty water tank. Make sure it has a 1/4 in. gap from the top to the top of the filter.
Nov 14, 2007 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell 1770 QuickSteamer Upright Vacuum Logo
119 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
