Question about Toshiba TDP-S8 Multimedia Projector
TDP-S8 only run for 20 sec.
Hi .my TDP-S8 won't stay on I trun it on it comes on show a picture then about 20 sec. it shuts off can someone help with problem Thsnks Hawkfix.
  • 51 Answers
Possible filter problem or sensor related to over heat. Might also be a bad bulb or worn out bulb.
Leaning more towards bulb replacement.
Posted on Dec 08, 2008
Cant remember password for my toshiba tdp s8
I had a projector toshiba TDP-S8 but it is used when i turned it on it required a password what can I do
thank you
Nov 09, 2009 | Toshiba TDP-S8 Multimedia Projector
It shows no signal
Toshiba TDP-S8 projector cannot communicate from my laptop, it shows no signal. how can i fix it? thank you so much...
Feb 19, 2009 | Toshiba TDP-S8 Multimedia Projector
HOW TO RESET TOSHIBA TDP-S8 LAMP
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
Feb 01, 2009 | Toshiba TDP-S8 Multimedia Projector
Laptop won't run the data projector
connect your laptop and projector simultiniously and swith on both at the same time projector will recognise automatically.
Jan 26, 2009 | Toshiba TDP-S8 Multimedia Projector
Same problem as below.
I have the same projector, and had the SAME problem.
After unplugging and taking on a trip it didn't work...it just lit up for 2 secs, and then shut off....
LEAVE it plugged in for as long as it takes for the light to stop blinking, and then it should start up on its own, or if you press the on/standby buton.
Be patient, hope this works for you too!
Sep 01, 2008 | Toshiba TDP-S8 Multimedia Projector
Aug 23, 2008 | Toshiba TDP-S8 Multimedia Projector
Toshiba Lamp Reset - How?
Not positive, but I would assume the same as my Toshiba.
With the on, input, and menu buttons held down, insert the power cable.
Hope this helps, NGK
Aug 14, 2008 | Toshiba TDP-S8 Multimedia Projector
No Power to My Toshiba TDP-S8
Console and mainboard not communicating. avalontc.com
Jun 05, 2008 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP S8 projector shuts down suddenly
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Dec 09, 2007 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP-S8 Multimedia Projector Logo
141 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
