Question about Toshiba Satellite A105-S171 Notebook
Water on spilled on keyboard
Toshiba Satellite A105-S171:  Water was spilled on keyboard when the laptop was off.  It was dried off with a towel and not turned on for weeks.  It now will start-up and run for about 15-20 minutes and then go off.  Can I take it apart and dry the insides to correct the problem?
  • 1 more comment
  • hifourteener Dec 10, 2008
    Do you have instructions for taking apart the Toshiba to dry the insides?
  • hifourteener Dec 11, 2008
    Ekse, my email address for sending the manual for this laptop is ewalter@ralstonbuttes.com
    Ekse, my email address is ewalter@ralstonbuttes.com thank you for the help.
    Ed
  • 1,879 Answers
Check this link as i don't have any plan copying the whole page or part of it and making no sense at all like what others do.
Posted on Dec 10, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, the weeks in between should be sufficient to dry whatever water is still inside. Now what is more likely is that when the water dried off internally, some of the small gaps in between the component legs were partially shorted due to accumulated dust. This dust has now caked and formed a bridge between components. With this in mind, drying is not longer applicable, rather cleaning would be more required. Perhaps opening and spraying with an electronic contact cleaner would do the job.
Perhaps this pictorial how to would be of help.
Good luck and Thank you for using FixYa. Happy Holidays.
    Sergeant:
  • 204 Answers
Nope. This will require further troubleshooting to revel the true problem. The inside should be dry by now. Also check your battery, I have the same model Laptop as you. My battery tended to last about 10-15 minutes if I was lucky. If its plugged in all the time that could be a different story. You could also try taking it apart to see if anything was fried intially. Good luck to you. Thanks for using FixYa!
Sincerely,
JC
  • 837 Answers
If you decide to take it apart .. be sure to look for "corrosion" that is the biggest culprit when water is spilled on a laptop. I have used alcohol to clean that up .. use a small brush (like a toothbrush) to gently scrub it off.
  • 60 Answers
Best thing is to send this to toshiba and see if they can diagonsis your problem. taken apart a laptop is all of things to do and alot of parts to break and your better off having the professionals deal with this being that they have the equipment!! If its under warranty!! Jus play dumb and try and get it fixed for free! If its not under warranty then jus tell them the truth!!
  • Toshiba Master
  • 13,433 Answers
Hey,
yes I have some toshiba service manuals, Can I email you one?
Whats your email?
Thanks,
Ekse
  • Ekse Dec 11, 2008
    You gave me the email address again, have you not receaved the manual? Its 7MB of size and in PDF format.
  • Ekse Dec 11, 2008
    If you haven't received the manual I emailed you, I have uploaded it for you on my file hosting service so you can download it if you don't have it already.
    http://koti.mbnet.fi/exuli/Delete/a105.P...
    The manual will be available for download only for today, I'l remove it tomorrow.
Is windows 7 compatable on a toshiba laptop a105-s171
From what I understand, windows 7 requires atleast 1 gb of ram to run properly, judging by your standard system specs you have 512 mb of ram. Unless you have added some ram or plan to add some to your system then no I dont believe you will be able to upgrade and run windows 7 efficiently.
Feb 09, 2011 | Toshiba Satellite A105-S171 (PSAA2U005019)...
Touch Pad on my laptop is not working
Follow the guide below to tear the laptop down, you are extremely fortunate that the device is even working. Electronic sircuits and water have never been a good match, and your keyboard and touchpad are essentially just large electronic circuits. There is probably some water still somewhere under the keyboard and it is probably in contact with the tochpad cable or socket. When you have the keyboard off, use a hair dryer on warm and completely dry out all components and make sure all the small flat cables are tight in their sockets.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Dec 13, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite a105-S2716 keyboard doesn't work. Soda spilled on it. External USB keyboard does work. How do I fix it?
I think your Toshiba got grounded or short circuit inside. Better also to use USB Keyboard, it works.
Aug 18, 2009 | Toshiba Satellite A105-S2716 Notebook
Replacement for toshiba satellite A105-S4244 dvd r/rw drive
Sure--the best one is e-bay!
Whenever I need something like this, I find it on e-bay. But if you really need to contact a company, try Spare Parts Wearhouse at 877-253-8898. National Parts Depot at 800-524-8338 may carry Toshiba parts.
I'd almost bet that the part you need is not made by Toshiba, though. Take it out and when looking for a replacement look for the mfg. name and the model.
Feb 09, 2009 | Toshiba Satellite A105-S171 Notebook
Can't get my laptop to display on a monitor.
Most laptops require you to press the Fn (Function) key and another key on the keyboard to activate the external video port, not too sure which button on your model it is, but it should look like a monitor.
Other than that it could be your board is fried. Which will need replacement/ repair.
Dec 10, 2008 | Toshiba Satellite A105 Notebook
System password lost
this is bios pasword or hdd password
Nov 05, 2007 | Toshiba Satellite A105-S4004 Notebook
Computers & Internet Logo
48 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
