Question about Acer Aspire 5315 Notebook
I tough that my charger was not working becouse my computer come on a shut off. i got a new charger plug it in and the computer is still not coming on. the light that would normally come on when you are charging the computer is not even coming on.
  • 51 Answers
Bad conection on the power receptical in the computer. and probably wobbley
Posted on Dec 08, 2008
Laptop is not turning on after I change my laptop charger. I remove the battery and plug in my new charger it works fine but suddenly shut off. I put the battery back and plug the charger in. No good.
You need to check the charger, I do not think it is any good as the charging power is in the charger unit not the computer. It sounds as if the battery in the computer is totally dead and that is why it shut down. Hope this helps.
Sep 15, 2015 | Computers & Internet
How do i charge my camera?
You can charge the Olympus Tough 3000 / Stylus Tough 3000 by both AC adapter wall plug and via USB using your computer.
Please let me know if I can assist you further.
Mar 01, 2011 | Olympus ? Tough 3000 / Stylus Tough 3000...
Holding charge?
If it works on the computer then there is something wrong with the charger and not the GPS. Have a close look at the wire and the plug. Perhaps compair the plug to the one on the computer.
Its likely that you will need a new charger.
May 30, 2010 | Garmin nuvi 250W GPS Receiver
Plugged in & not charging with new battery
Laptop not charging
if you have a brand new battery and it is not charging, check the charger you may have to replace the plug on both sides, check the cables.
you can take the charger to a TV repair shop and tell them to check it and see if there is any juice (charge) coming out of it. that is a common problem with chargers, we trip over the cable or pull it out of the laptop by accident and it brakes little by little. if there is no charge coming out you can star by checking the jack you may have to cut it and have them check it again.
if you don't want to go trough the whole testing, just tell the TV repairman to fix it it should cost you about 30 bucks instead of 80 for a new original charger or find a chinese one on e-bay
if it works for you don't forget to rate me
Apr 28, 2010 | HP Pavilion dv7-1130us Notebook PC
How to enable by ipod
1.Make sure your charger is plugged in to your computer, but not your iTouch.
2.Shut off your iTouch(if charged wait and then shut down)If you can't shut it down.Hold down Sleep/wake button and Home button for about 10 seconds and it will shut down.
3.Hold the home button for 10 seconds, then plug your charger in while still holding it.
4.Keep holding it until a recovery screen comes up(the same screen when you buy one)
5.Open up iTunes, (should open itself) and then click Restore ipod.
Wait around 20Minutes and it should work.
Then it should be done.
(It deletes all your applications, but still works.)
Mar 29, 2010 | Apple iPod touch
Computer will not turn on
You need to charge a battery at least overnight 8 hours for a real flat battery. During this time it must NOT be used at all. When you get it that flat, it will take some time to "Come Back" from flat. I suspect you just need to be more patient and leave on charger, when using it for at least a couple of days while working on it. After the 8 hour initial charge.
Mar 08, 2010 | Dell Latitude D510 Notebook
My battery won't charge on my laptop. It gives me a message that says: The AC power adapter type cannot be determined. But I have my AC adapter plugged in and the little blue light does come on. I can't...
There at least three possible reasons for your problem.
1) You are using the wrong charger, or
2) Your battery may be defective, or
2) If you are using the original charger that came with your laptop, it may be defective, or
3) Your laptop charging port may need to be replaced.
You need to take your laptop to a local computer repair shop to have the problem correctly diagnosed.
Feb 04, 2010 | Dell Inspiron 1318 Laptop Computer PC...
Have a Gateway Laptop Computer Model #MT6708. Previously computer had blank screen and no power. Currently purchased new battery and power cord. Computer now operating screen and power is on. However, when...
First thing check that the battery charge light is on when the battery and the charger are connected.
If it is it indicates that the power supply is charging the battery,
If it isnt it may indicate a fault with the battery or that the charger is not compatable with the laptop or that there is a fault with the charger.
If the battery is charging then try running the laptop on battery only without the charger and on charger only without the battery.
This will eliminate which one is faulty.
You mentioned that if you wiggle the cord then the light comes on again.
Check to see if the charger end plug is lose or the actual port on the laptop is lose.
If the charger plug is lose then return to seller and make sure they gave you the correct charger. if the actual port on laptop is lose then perhaps u got a bad connection and you need electrician or local laptop technician to open it up and solder properly on motherboard.
Let me know how it goes.
Oct 26, 2009 | Gateway Computers & Internet
Acer Aspire 5315 Notebook Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
