Question about Sakar Adrenaline Computer Speakers
Audio devices i have logitech speakers for my computer they have worked in the past and now dont whenever i try to use windows media player i get a pop up saying Windows Media Player cannot find the file. The link from the item in the library to its associated digital media file might be broken. To fix the problem, try repairing the link or removing the item from the library. i have no idea what to do can some one please help xxxxxxx
  • 1 more comment
  • laurie_oo Dec 08, 2008
    no i carnt even play a cd when i try it says Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device installed on your computer, it might be in use by another program, or it might not be functioning properly.
  • Nicolas
    Nicolas May 11, 2010
    Try to reinslall the drivers for your soundcard
    And try if you get the same error with another player
  • Nicolas
    Hmm, but the speakers are playing if u play a cd or?
    Try to delete the playinglists in the media library and clean the libraly if u see any files in it
    And try to uppdate windows mediaplayer
1, you have to check your file whether is currupted, if that could not help pls try and reload your music again into the music library
Posted on Dec 08, 2008
  • abeke_fash Dec 08, 2008
    the best way of solving dat problem is to load audio driver into your system that will help u
I have a set of Saitek A250 Wireless speakers and a set of Logitech speakers. I can't get iTunes to play on the Saitek speakers, but Windows Media Player and normal Windows sounds do without issue....
click start control panel sounds and audio then select audio make sure the default player is the media you want to use as your default sounds also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope this helps
May 22, 2011 | Saitek A-250 Computer Speakers
Whenever I start the computer, I dont hear any sound from window and if I try to play music from my media player, no sound at all. I can only listen to music or sound via headphone only. I have downloaded...
most system has seperate audio ports for the speaker and the headphone but they are interchangeable. try plugging the speaker on the audio your using for the headphone. if your already using the same audio jack then try using another speaker, but since you mentioned that the headphone works then its possible you might need to replace your speaker
Mar 29, 2011 | HP Computers & Internet
I have pluged all speakers but not sound on the front and rear to working when i play test they all working but not when i open a music from windows media player.
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Dec 11, 2010 | Logitech X-530 Computer Speakers
Logitech X-540 limited sound
why dont you have them all hooked up? I have the same speakers but I the model that only has 2 speakers. Try pluging your audio cable in the front where you would plug head phones in. Assuming that this is a desktop.
Jul 24, 2009 | Logitech X-540 Computer Speakers
No sound from monitor
Try to re-install your audio driver !! Also go to add and remove and remove media player and then go and re-install windows media player again( probably a newer version ) should work!!! swampratt200 AAAEEE!!!!!
Jul 21, 2009 | HP Compaq WF1907 Monitor
Speakers are not working
sounds like your audio wizard has made google your default player. Try running the wizard with your media player and make the player the default device for your system.
May 06, 2009 | Logitech X-530 Computer Speakers
WindowsMediaPlayer silent on Toshiba laptop; sound faint on Skype
GOTO CONTROL PANEL-- check the audio devices, see if its set to the default device under playback and recording device, default is realtek,,,
Feb 03, 2009 | Toshiba (P000377700) Computer Speakers
SOUND is not played during the function of any audio/vide players
  1. You need to visit the logitech web support page and download the driver for your model number at www.logitech.com allow it to install and then restart your PC.
  2. If this fails to sort it out try going:Control Panel>Hardware & Devices>Device Manager you may see a yellow triangle at sound controlers, right click it then click Drivers [tab] then click "update driver"
  3. Restart you PC
  4. Check all conections are good
  5. Try a different set of speakers to see if the fualt is with the speakers or your computer.
Jan 15, 2009 | Logitech X-530 Computer Speakers
No sound
check in your device manager that you have installed the driver successfully.
1st go to control panel
2nd click on system
3rd click on properties
4th...on device manager and select it and see the status!
Dec 08, 2007 | Logitech V20 Computer Speakers
Speakers dont work at all
Did you install the audio card drivers?
Oct 29, 2007 | Logitech R-20 Computer Speakers
Sakar Adrenaline Computer Speakers Logo
66 people viewed this question
Top Sakar Audio Players & Recorders Experts
Robert
Carlos L. Burgos
Carlos L. Burgos
Joseph Hoffmann
Are you a Sakar Audio Player and Recorder Expert? Answer questions, earn points and help others
